Old 11-23-2003, 07:38 PM   #1
Stiger
Member#: 32949
2004 STi
Silver/silver
Default Possible winter problem with SDR Rotas
I just finished installing SDR Rotas on my STi yesterday in preparation for predicted snow which would up being rain today. After driving in the rain and then parking the car in the garage, I noticed a puddle of water had accumulated in each wheel at the bottom of the trough-like area just inside the face of the wheel. Unfortunately, there is no provision for drainage of this water. It is very likely this situation will cause a problem in the winter. Water which collects in the wheels in this manner can easily freeze once the car is parked and throw off the balance of the wheel. Once frozen, it won't be simple to remove. You may want to keep a sponge handy in your car for addressing this situation if you have the SDRs. This situation could be more troublesome with the front wheels after going through deep snow since the residual engine heat in the front wheel wells will likely melt the snow when the car is parked in the garage in the evening. Then, when temperatures drop overnight, there is a good chance the water will freeze and cause the problem noted above. Not the best design for a winter wheel.
Stiger is offline   Reply With Quote
Old 11-23-2003, 10:08 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
If you put several coats of wax on the wheels, and then spray them down good with cooking spray like "Pam" or grease them, the ice will be very easy to remove.
Old 11-23-2003, 11:10 PM   #3
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
Zoso is offline   Reply With Quote
Old 11-23-2003, 11:16 PM   #4
Stiger
Member#: 32949
2004 STi
Silver/silver
If you put on enough lubricant to keep ice from sticking, you'll have the centrifugal force of the wheel spin throwing it all over the place and making a mess. And even that, at 20 and 30 below, I don't care if it's a teflon wheel covered by 10 coats of wax covered by molybdenum imbedded graphite covered by grease, the ice is going to stick. Thanks for the advice but BTDT and it doesn't make much of a difference.
Old 11-23-2003, 11:45 PM   #5
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Originally posted by Stiger
BTDT
Been there done that?
Neek is offline   Reply With Quote
Old 11-24-2003, 01:03 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
Granted, in extreme conditions, there is very little which will work.
But I grew up in the great cold north and greasing things like this does, indeed, help if for nothing else but to seal out some of the moisture and thus help prevent corrosion...
Old 11-24-2003, 04:11 PM   #7
rodon
Member#: 36372
'03 WRX Sedan
I have the SDR's, and the tendency to puddle water is a mild PITA in the warm months after you wash the car and go for a drive, all of that water splashes over your clean machine. It's difficult to mop it all out.
In the winter, I agree it could be a problem if it freezes. Hopefully the different coefficients of thermal expansion between water and aluminum will help shed the little ice cakes. Perhaps waxing would help there.
Or just carry a propane torch.
Me, I'm going back to the stock wheels for winter. But it's a good warning to those who will drive with the SDR's - if you notice a severe vibration, check for ice buildup!
rodon is offline   Reply With Quote
FS--17x8 +48 white rota torques with possibly winter tires skate enjoi MWSOC Private Classifieds 29 10-04-2008 09:26 AM
FS--17x8 +48 white rota torques with possibly winter tires skate enjoi Wheels/Tires 9 09-15-2008 02:10 AM
Possible rubbing problem with the Strano FSB z3coupe Motorsports 621 12-30-2007 11:49 PM
question and possible problem with MBC? Mr.Freeze Mid West Subaru Owners Club Forum -- MWSOC 1 04-16-2002 09:51 AM
Possible problem with St Helen meet jeffg North West Impreza Club Forum -- NWIC 0 01-18-2001 05:49 PM
