Old 11-24-2003, 12:16 AM   #1
subarally
Member#: 37005
yup.
Default Too light a Pulley?
OK, I think I searched enough...
My question is, I pulled the A/C out of the car and was wondering if a pulley made for JUST the Alt./PS exists.
A quick blurb in Vishnu's sight said "light- but not too light"
So can it be too light? I was kicking around the idea of machining the A/C chunk out of the pulley...any opinions?
Planning on kicking the wee out of this engine 'til it goes, then put in an engine with enough power that random ideas like this are not neccesary.
Back to the drawing board?
subarally is offline   Reply With Quote
Old 11-24-2003, 07:52 AM   #2
QfactorRS
Member#: 30495
you could just take A/C out.... loose close to 30Lbs from that.
then get a Mr.josh and machine that down so it is a single belt pulley.
Q
QfactorRS is offline   Reply With Quote
Old 11-24-2003, 10:09 AM   #3
koolaid
Member#: 43491
1997 Impreza Outback
Red
you might want the AC though.. it defogs
I dont think you can have 'too light' of a pully.. Otherwise why would people run LW Pully and Flywheels together?
koolaid is offline   Reply With Quote
Old 11-24-2003, 01:04 PM   #4
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Actually I've heard you can throw some wierd ce lights with too light of a pully and or a 9lb fw. Appearantly the crank accelerates too fast. Yes I find it odd, but it's been mentioned. I don't have the details, you might try to search on lightened flywheel, that what I was doing when it happened.
AO
m750 is offline   Reply With Quote
Old 11-24-2003, 02:53 PM   #5
jasona
Member#: 11786
02 TS
Black on White
Default Re: Too light a Pulley?
Make sure you keep it balanced...
jasona is offline   Reply With Quote
Old 11-24-2003, 03:26 PM   #6
dcoty
Member#: 3149
01 V7 GC/R32 sky
My pulley never caused me any problems, and now its coupled with a 9lb flywheel and a lightned/balanced/knifegded crank and I have no problems to speak of. The car revs very very fast and you do get a bit of vibration in the clutch with a very light flywheel since it not able to dampen vibrations as much as a stock flywheel of a 14 lb flywheel (which I had with no vibrations with).
Dan
dcoty is offline   Reply With Quote
Old 11-24-2003, 03:52 PM   #7
koolaid
Member#: 43491
Red
Fast revs + winter = teh suck
Old 11-24-2003, 03:53 PM   #8
Subaru IMP VR
Member#: 49070
1989 Toyota Camry Le
13.983 1/4 at 112Mph
heh..... Weeeee isn't that the beauty of AWD tho..?
Subaru IMP VR is offline   Reply With Quote
Old 11-24-2003, 10:23 PM   #9
subarally
Member#: 37005
yup.
Thanks for the advice everybody!
Most of this just kind of came up fooling around with ideas...
(Guess that's how anything goes)
I KNOW for sure that my little sub-2 litre will not make any real firepower, but it's fun to try struff on an engine you don't care TOO much about...
If something spectacular happens, I'll be sure to tell ya'.
Old 11-26-2003, 11:26 AM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Dan
Do you have a cel?
I have light/under crank pulley..light accessory pulleys worth it? kaisersouse Normally Aspirated Powertrain 2 10-21-2005 04:04 PM
Lightweight flywheels, how light is too light? Petrus Transmission (AT/MT) & Driveline 15 07-23-2005 02:38 AM
How light is too light? Santo Domingo 2.5 RS Normally Aspirated Powertrain 7 02-07-2003 11:37 AM
Ultra light crank pulley for Legacy DRACULA Legacy Forum 3 11-16-2002 05:22 PM
Is the light weight pulley worth it? TurboRex Factory 2.0L Turbo Powertrain 1 07-26-2001 12:50 AM
Message Board Statistics All times are GMT -4. The time now is 08:12 PM.
