Old 01-10-2001, 11:45 PM   #1
olie
Member#: 3352
Question annoying, high pitch squeaking driving me nutz!
I have a 00RS, and all of a sudden one day I noticed that it was squeaking alot. Any slight bump or ruff road and it would squeak up a storm. Its truely embarrassing. I'm just wondering if any one else has had this problem? And if so, what did you do? What was causing it? Did it stay away?... that type of stuff, any feed back is greatly appreciated. Thanks!
Jay Olson
olie is offline
Old 01-11-2001, 06:07 AM   #2
shimstock
Member#: 3002
Post
i have one that seems to come from the center armrest. I have a armrest extender and it seems to move around a lot. i haven't firgured out how to quiet it yet, but at least i know were it's coming from. I'll get to it when the weather warms up.
shimstock is offline
Old 01-11-2001, 07:04 AM   #3
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 XV, '99 RS
Lightbulb
Ahhh, someone else with the annoying squeaks that sound like a styrofoam cooler is in your passenger seat. After much investigation, I found the culprit, and a solution.
If you open your passenger door, slide the passenger fron seat all the way foreward and then look underneath the seat (from the back) you will notice two hog-ring clips that secure the back peice of fabric to the underseat frame. They clip through the fabric and around a metal mount on the seat. Believe it or not, the hog rings vibrating on the seat frame make all that squeaking.
How did I fix it you ask! Simple, I ran two small wire ties together, looped them through both hog ring clips, then tightened them up. Now that they are secured together, they don't vibrate and cause the squeak!
PM me if you have any other questions!
Opie is offline
HTML code is On
High Pitched Squeaking noise JLude7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-28-2009 11:36 PM
High pitched squeak from aftermarket intake? BrysImpreza Normally Aspirated Powertrain 11 06-30-2004 02:58 PM
Heat "ON" = high pitched squeaks JayGold Normally Aspirated Powertrain 2 12-08-2003 02:27 PM
High-pitched squeak during upshifting everbruin Warranty Issues & SOA Problems 4 02-13-2002 09:13 PM
High-pitched squeak during upshifting everbruin Transmission (AT/MT) & Driveline 1 02-13-2002 11:55 AM
