Old 11-25-2003, 02:17 PM   #1
Ahzlon
Member#: 45216
2005 Baja Turbo
Default Bore/Stroke.. Port n' Polish
This thread has proabably been beaten to death... But here it goes anyhow...
I have a good chance on getting my hands on a nice ej25 out of a wrecked subaru that is a SOHC .. now if I Bore/Stroke this thing and do some head work on it.. could i just swap it out with the ej25 SOHC that is in my RS and use the stock ECU even after the modifications to the engine and not have to reflash the ECU??
Ahzlon is offline   Reply With Quote
Old 11-25-2003, 11:26 PM   #2
atabert
Member#: 45107
1992 Legacy L
Green
Talking swap
well im in the process of doing that right now, ive got a 2.5l shortblock and im using 2.2l heads which ive ported and polished,a 2.5l intake plenum so i can use the 2.5 injectors while using the stock 2.2l/92 legacy wiring harness which im going to put it into. i dont think it will make it any worse than stock, i just think it will probaly change when and how long you make power, your engine size isnt changing your just changing the powerband and you probaly will make a few ponys but not enough to fell without manipulation of the electronics.but just making the engine breathe better will definitely help. i am going to be gaining .3litre so i might have a bigger horsepower change, i plan on dynoing before and after to see what the difference is, let me know your opinion
atabert is offline   Reply With Quote
Old 11-26-2003, 01:23 AM   #3
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Ahzlon - You're pretty close to being max bore and max stroke size. To bore the block anymore, you'll have to press in some heavy duty sleves. To stroke the EJ25 more, you'll need a different stroker crank.
Drop the guys at TWE an email, I'm sure they'll have something that'll suit your needs.
GTBGUY is offline   Reply With Quote
Old 11-26-2003, 01:38 AM   #4
Ahzlon
Member#: 45216
2005 Baja Turbo
thanks GTBGUY.. ill drop them a line
Port n Polish and Boring, need advice. Crash477 Normally Aspirated Powertrain 5 01-21-2005 10:26 AM
('93-'01) Bore, stroke, compression, please explain! cakagan Impreza Forum 36 09-16-2004 07:22 AM
Power Enterprise PE1818 turbo Ported n' Polished/Ceramic Coated djdorazio Private 'For Sale' Classifieds 18 02-25-2004 07:47 PM
pictures of my ej22, bored, stroked, sleeved STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 35 04-23-2003 12:45 PM
port n' polish? scubaracer Normally Aspirated Powertrain 8 04-11-2001 05:06 PM
