Old 11-25-2003, 02:41 PM   #1
FatCatTurbo
Member#: 10467
DOHC 2.0 Hybrid
JDM
Default Removing the oil pan
I removed all the bolts that hold the oil pan in, even the one that holds the dipstick level. I pried and hammered away, but I can't get it to budge. Am I missing something?
FatCatTurbo is offline   Reply With Quote
Old 11-25-2003, 04:42 PM   #2
awd4ever
Member#: 31573
I found the
meaning of life!
yes, a screw driver and a hummer.
go around it tapping it until you get the screw driver in there. It's not easy to bend the lip, but watch out.
awd4ever is offline   Reply With Quote
Old 11-25-2003, 06:32 PM   #3
wawazat
Member#: 13793
2007 specB, 03 Ram
'92 SVX-5 speed
Use a stiff bladed scraper. Tap it in to the pan by tapping on the end of the handle and then tap on the blade and use it like a knife to cut through the sealant. A screw driver is more likely to damage the block.
wawazat is offline   Reply With Quote
Old 11-25-2003, 06:35 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Don't worry so much about scraping the block... as long as it isn't more then 1.5mm deep or so, then it'll fill in with the sealant when you install the new one.
Note: Use a good sealant to seal the pan on. I personally use Hondabond (yes, like the stuff from Honda dealerships).
Old 11-25-2003, 06:36 PM   #5
awd4ever
Member#: 31573
I found the
meaning of life!
Well, yea... use a flat head
If the engine is out of the car, use a scraper. I found it easier to use a screw driver, you can catch a lip of the OIL pan, and just pry it up with minor hitting.
Old 11-25-2003, 09:37 PM   #6
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I'd go for it. Then after the mixed drinks and oral sex you'll be in a better mood for auto maintanence!
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
Old 11-26-2003, 11:34 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Carl
1 Lucky Texan
keep the off topic comments in off topic please.
this is a technical forum.
Old 11-26-2003, 05:19 PM   #8
awd4ever
Member#: 31573
I found the
meaning of life!
Carl
1 Lucky Texan
there is nothing like soldering an ecu connector after 4 shots...how's the oil pan comming?
Old 11-26-2003, 09:03 PM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
y cant we joke in these forums, its so stupid, a lot of forums are un modded unless something major goes on, i think itd make things so much more enjoyable if we could say whats on our mind
Old 11-26-2003, 09:46 PM   #10
NicGordon
Member#: 24827
2008 Kia Spectra
An occasional wisecrack is usually accepted. But the 'Off-topic' forum is generally reserved for saying something that's on your mind.
NicGordon is offline   Reply With Quote
Old 11-27-2003, 12:00 AM   #11
awd4ever
Member#: 31573
I found the
meaning of life!
I think with all your bickering, that dude put a hole in his oil pan and now he's hating life... shoulda just listened to me...
Old 11-27-2003, 04:32 AM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
well usually if u can answer somesones question and make them laugh, theyll be a lot happier and be less likely to mess up workin on the car
Old 11-27-2003, 10:46 AM   #13
goobie
Member#: 8273
2006 WRX Wagon
Ahhh.. hey come on! That was funny! He just said what we were all thinking! Besides, these little jokes and friendly pokes at people is a big reason why this place is so great!
Cheers All,
Chad
goobie is offline   Reply With Quote
Old 11-27-2003, 08:35 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Cheers All,
Chad
tru dat
Old 11-27-2003, 10:18 PM   #15
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Well, it was tactless. Something I have a reputation for.(just couldn't leave a line like that laying around! besides, it may have been a freudian slip as the 'u' is miles away from the 'a' on the kbd!)
'Tact is NOT saying out loud what everyone is thinking.'
Carl
1 Lucky Texan
just dropped in new motor and all the coolant in the oil pan JT's06sti Built Motor Discussion 39 03-01-2009 03:37 PM
How does the oil drain to the oil pan? msm98lw Newbies & FAQs 6 10-29-2005 12:05 AM
How do you separate the oil pan from the block? jasona Normally Aspirated Powertrain 16 10-06-2005 04:54 PM
Whats the thread and pitch for the oil pan plug? BrysImpreza Normally Aspirated Powertrain 0 10-27-2004 06:32 PM
What is the oil pan made of? SFsube Technical Forum Archive 1 09-11-2000 03:19 PM
