Go Back   NASIOC > NASIOC Archives > NASIOC Archives > General Forum Archive
Old 10-05-2000, 07:36 AM   #1
Fido
Member#: 1867
Post Manual Tranny RS 4WD, not AWD!?
I just read through that FAQ post, and now I'm totally puzzeled. My Manual Tranny RS is constant split power to all wheels (50/50) and is not automated due to changing weight transfer and such? So when I accelerate hard, my power is still 50/50?
Sorry if this makes anyone annoyed because this was 'answered' in the FAQ post, but I just don't get it...Subaru sells them saying that there's transfer of power...Can someone please quiet my fears of getting somehow jipped?
Fido is offline
Old 10-05-2000, 07:40 AM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
It's 50/50 until something starts slippin.
RidinLow is offline
Old 10-05-2000, 07:47 AM   #3
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Cool
Yes there is power transfer in the stick - it uses a viscous lockup from front to rear instead of the auto's electronic clutch. I really can't see why they don't use the viscous for everything - it really seems to be a much simpler setup. I believe the power transfer on the stick is 50-50 until the wheels start slipping then it transfers more to the non-slipping wheels. In the auto, I think it's more like 60-40 favoring the fronts until slip occurs. Anyone with more info?
Mike Smith is offline
Old 10-05-2000, 07:49 AM   #4
Fido
Member#: 1867
Post
ah, well I'm not unhappy with a 50/50 split normally, as long as the system reacts quick enough to keep me from slipping. There was once I was at a stop on a little hill and it was wet out, and I decided to see if I would slip or not, so I let off the clutch and gave it the gas...Only a very slight bit of hesistation and off I went...I actually felt the point where I /would/ have slipped had I not had AWD...My corolla would have just sat there spinning, slowly going backwards down the hill
Fido is offline
Old 10-05-2000, 07:49 AM   #5
Sean
Member#: 518
762 PGT Impreza L,
Silverado EXT, Yaris
Post
Sean is offline
Old 10-05-2000, 07:49 AM   #6
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
I thought the auto was 90/10? & I think the auto's clutch transfers power much faster than the manual's viscous system.
Hey Mike, when are you on the air again?
RidinLow is offline
Old 10-05-2000, 07:50 AM   #7
Nat
Member#: 759
2004 WRX
2000 SV650
Post
Also, since my 99 has open diffs front and rear, power really only goes to one front tire and one rear tire, right? As I percieve it, powere only goes to one tire without limited slip, correct?
Nat is offline
Old 10-05-2000, 07:53 AM   #8
Fido
Member#: 1867
Post
Lemme get my MY01 brochure and see what it says.
Edit: My MY01 Brochure says that 2.5RS has as standard a Viscous limited-slip rear differential.
It also says that Manual transmission models have a viscouse-coupling locking center differential, automatic transmission models have an electronically managed continously variable transfer clutch, and 2.5 RS models have the VLS rear diff.
Nowhere does it say that the AWD doesn't do exactly as they market it as. Distribute power from front to rear, and to and from each rear wheel as needed. In fact, in the MY00 brochure, it has cool little pictures of the power transfer ala techincal drawing.
[This message has been edited by Fido (edited October 05, 2000).]
Fido is offline
Old 10-05-2000, 07:54 AM   #9
Em
Member#: 1697
Post
Isn't the front differential of a car always limited slip?
Em is offline
Old 10-05-2000, 07:55 AM   #10
Mike Smith
Member#: 744
00 BRP RS Coupe
Post
The 2000s have a rear viscous LSD in addition to the center unit. I can't say as I've ever "felt" mine engaging - but then I am a male and therefore insensitive, right?
G - I'm still on every morning from 6-10 - 98.5FM or at www.wnyr.com
Old 10-05-2000, 07:56 AM   #11
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Can I call in to chat about Subies?
RidinLow is offline
Old 10-05-2000, 08:00 AM   #12
Fido
Member#: 1867
Post
Edited my above post to include information from Brochure.
Fido is offline
Old 10-05-2000, 09:18 AM   #13
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The latest issue of Drive talks about both AWD systems extensively (at least more so than subaru.com or the owner's manual) but they DO NOT say what torque bias ratios the MT supports.
Knowing how the MT works though, with the front differential driven off one end of the output shaft and the center diff hanging off the other end... I would be inclined to agree that it's 50/50 with only enough slippage to get around corners without binding.
ColinL is offline
Old 10-05-2000, 09:20 AM   #14
cakagan
Member#: 251
1998 Impreza 2.5 RS
Post
If I remember correctly, the diagram in the brochure for the '98 RS shows the power transferred to the rear wheels on acceleration, and to the front during braking...
-Kagan
cakagan is offline
HTML code is On
manual tranny AWD v.s. automatic eXotek Transmission (AT/MT) & Driveline 2 12-15-2008 01:05 PM
How's the manual tranny in 99-01 RS/OBS ? nimaxpro Transmission (AT/MT) & Driveline 4 09-22-2004 06:39 PM
2004 Maxima - V6, AWD & Manual Tranny NYCshopper Off-Topic 17 12-31-2002 12:46 AM
Are 2.5 RS manual trannys no good? driver Normally Aspirated Powertrain 2 06-12-2001 05:37 AM
Differences between 98, 99, 00 RS manual trannys? yebokmj Normally Aspirated Powertrain 8 05-30-2001 12:53 AM
