Old 11-26-2003, 10:19 AM   #1
Nicklbrso
Member#: 44887
00 GC6
Default Piston slap?
Well im still looking for an ej25 engine and Smacksube has one but he says it has some sort of piston slap, and may throw a bearing. Is this normal? any way for it to be fixed. Anything else I should know? Thanx
Nicklbrso is offline   Reply With Quote
Old 11-26-2003, 10:27 AM   #2
koolaid
Member#: 43491
1997 Impreza Outback
Red
To my understanding most engine (cold) have piston slap.. You could have the motor's rings and bearings checked is your worried about it
koolaid is offline   Reply With Quote
Old 11-26-2003, 10:36 AM   #3
Subaru IMP VR
Member#: 49070
1989 Toyota Camry Le
13.983 1/4 at 112Mph
This means Not to get the engine IIRC it is that the piston is not tight on the Crank and the piston is hitting the head if you buy this motor be warned head work and pistons may have to be done.....
Subaru IMP VR is offline   Reply With Quote
Old 11-26-2003, 11:10 AM   #4
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
headwork, no
piston hittng crank, no
spun bearing, no
bearings are not the issue on teh ej25, while it is possible, the problem with the ej25 is the crappy rods.
and piston slap is when the piston moves around in the cylender and the skirts of the piston hit the wall... only when the engine is cold is it normally hearable.
98s have this problem more than 99 and on because its dohc.
all the ej25s are prone to blowing head gaskits, but so are the 2.0s... the 2.2s are not bad and neigher is the 1.8
YaZahX is offline   Reply With Quote
What Piston to use to replace piston slap brett-01 Normally Aspirated Powertrain 18 12-20-2011 06:19 PM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
Piston Slap Question Kachukaa Normally Aspirated Powertrain 7 06-29-2001 01:08 PM
Piston Slap Quesiton Kachukaa Legacy Forum 3 06-29-2001 10:53 AM
MY '98 Piston slap problems Rovah Normally Aspirated Powertrain 5 11-27-2000 04:53 PM
