Old 11-26-2003, 10:28 AM   #1
koolaid
Member#: 43491
1997 Impreza Outback
Red
Default 3 in.
Why isnt a 3 in. CB good for high way cruising and lookin nice? I dont usually drive aggressivly
koolaid is offline   Reply With Quote
Old 11-26-2003, 10:40 AM   #2
Subaru IMP VR
Member#: 49070
1989 Toyota Camry Le
13.983 1/4 at 112Mph
This is because there is not enough back pressure having too big of an exhaust is almost as bad as having too small of an exhaust... and back pressure is what makes your turbos work properly But I don't know specificly what exhaust would be bad for you I am an Impreza guy not an outback guy My reccomendation DO A SEARCH .... and I bet it would look Killer ...... but not perform to well Not to Sure tho....
Subaru IMP VR is offline   Reply With Quote
Old 11-26-2003, 11:12 AM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Actually backpressure kills the performance of a turbo and that is why when you do have boost you want a 3" exhaust. But in an NA build you are trying to keep a really high exhaust velocity, and haveing some backpressure helps with that. If the exhaust is too big the exhaust velocity goes down and you don't get the proper scavenging of the cylinders that a well designed exhaust provides. 2.25" tends to be about right for the EJ25. If you have headwork and cams, then 2.5" is a good upgrade. But for any NA EJ25 3' is just way to big for performance...
Old 11-26-2003, 11:20 AM   #4
Swano
Member#: 19114
2002 2.5TS
Blue Ridge
Back pressure has nothing to do with velocity.
Phil =)
Swano is offline   Reply With Quote
Old 11-26-2003, 04:00 PM   #5
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
In fact, when people says that there is no enough backpressure, they're wrong. back pressure is never an advantage. however, it's better to have optimal exhaust velocity and back pressure, than no backpressure and too low gas velocity. large exhaust piping usualy mean no backpressure, but low velocity, wich is bad. the exhaust gases need to travel at a certain speed in order to create a vaccum effect for the next exhaust step. 2.25" piping is the best of both world on the 2.5 engine. bigger is overkill. smaller would need to be too much efficiently designed to be cost effective. You should always avoid sharp bent and large velocity change on a short distance. going from big to small would increase rapidly exhaust velocity, creating some kind of aerodymanic wall and causing backpressure.
NicEJ25 is offline   Reply With Quote
Old 11-27-2003, 01:36 AM   #6
2.5RSMatt
Member#: 30497
00 RSTi
FUK HDR
I have 2.5" piping and well I'm thinking of changing it to 2.25". Think it's worth it?
2.5RSMatt is offline   Reply With Quote
Old 11-27-2003, 01:53 AM   #7
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
w3rd
jasona is offline   Reply With Quote
Old 11-27-2003, 08:22 AM   #8
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
what's weird in that, Jasona? i was only supporting Matt Monson's message, and explaining the link between velocity and back pressure. have I lost some people ?
Old 11-27-2003, 12:10 PM   #9
nySulli
Member#: 32617
2008 STi
ehh, i don't know how much power you'd really gain by swapping down to 2.25", it would probably be a little quieter, but i think you'd be better off spending that money on cams or something to take advantage of the increased exhaust flow you could handle
nySulli is offline   Reply With Quote
Old 11-27-2003, 12:36 PM   #10
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
First off, the original post is for an Impreza Outback, which came in a 2.2L only AFAIK.
Thus even a 2.25 may be big. The biggest issue is finding the parts for a 2.2L.
What a few are trying to say is, the diameter of the pipe (for a NA build) is critical to the length of the pipe as well. What you want is to have the exhaust pulses exit the tailpipe and create a suction that will draw in the next cylinders charge.
If the timing is off, you can end up with flat spots in the power.
BTW, hi Matt.
Old 11-27-2003, 02:33 PM   #11
jasona
Member#: 11786
2014 OB 2.5i 6MT
I was agreeing with you. I always see people saying you need backpressure, but never feel like typing out all that for an expanation.
Old 11-29-2003, 04:03 AM   #12
gonzosquirrel
Member#: 30543
2002 WRB WRX
& 1986 VFR700F
well...for once I have no reason to hack on koolaid.
a 3 inch exhaust will be fine for your car...regardless of mods...good on ya for starting a thread with some merit...
gonzosquirrel is offline   Reply With Quote
Old 11-29-2003, 05:58 AM   #13
Paul Sakai
Member#: 2513
2000 RS Coupe
Silverthorne
Umm....no 3" would be good for yours not his.
Paul Sakai is offline   Reply With Quote
Old 11-29-2003, 09:28 AM   #14
koolaid
Member#: 43491
Red
BTW, hi Matt.
If it fits a 2.5 (RS, etc) it fits a 2.2
Old 11-29-2003, 12:12 PM   #15
ttboy19
Member#: 38043
2004 impreza rs4sale
'10 Legacy 2.5GT
I put a Borla catback(not the hush) on my RS. Didn't even bother checking the diameter of the piping. I think it's big. I was rushed into buying it because it was on sale. Anyone have an idea?
It feels a lot better than stock exhaust. It sounds BEEFY, but could I get more power with smaller piping?
ttboy19 is offline   Reply With Quote
Old 11-29-2003, 01:15 PM   #16
Matt Monson
Member#: 832
99 2.5RS, '85 911
NicEJ25,
I appreciate that you took the time to make the long explanation. My remarks about back pressure were misleading because I said you needed back pressure for exhaust velocity,when I know very well it is really that you just can't get rid of all the back pressure ans still have a good exhaust velocity.I just worded it lazily without the complete explanation and it has been restated properly And I think jasona was saying word not weird???
Koolaid,
Not true. Not every part for a 2.5l will work on a 2.2l. The EJ22 heads found on the OBS Imprezas only have one exhaust port per side, which is why Borla make different headers for them. But most everything else will work...
BTW, Hi Charlie
Old 11-29-2003, 04:11 PM   #17
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Hi Matt.
Btw, thanks for covering me.
Old 11-29-2003, 05:00 PM   #18
jasona
Member#: 11786
2014 OB 2.5i 6MT
You are correct
KW Varian 3 in stock! Track and Street all in one! RallySport Direct Suspension/Brakes/Handling 20 08-06-2007 03:08 PM
FS in CT: 3 in. SPT Catback EROCK NESIC Private Classifieds 18 06-21-2006 12:11 PM
Anyone change to aps 3.5 exhaust and or header from another brand 3 in exhaut? greysave Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-13-2006 10:02 PM
FS in CT: SPT 3 in. Catback (STi) EROCK NESIC Private Classifieds 6 03-22-2006 06:21 PM
WTT my 3 in RFL axleback with less than 3000 miles on it for cobb/stromung 3 inch mpower22 Mid Atlantic Impreza Club -- MAIC 8 10-13-2005 07:37 AM
