Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 11-26-2003, 12:21 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Do you think this is going to cause problems?
I've had the borla header and OEM oil cooler on my RS for roughly a year if not more and previously the header had been wrapped (with no problems). It had been smoking lately due to the fact that oil had saturated the header wrap near the oil filter during an oil change so I took off the wrap.(which immediately stopped the smoking). Now my only concern is that the oil filter and the header are very close to each other. Are oil filters very heat resistant and do you think this is going to cause problems down the road. Here are some crappy pics I snapped from under the car. (The two do not touch, but are very close)
AustinSTi is offline   Reply With Quote
Old 11-26-2003, 06:01 PM   #2
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
AFAIK the outside of an oil filter is extremely heat resistant. If you give it some time and don't see any deformation I wouldn't worry about it.
Neek is offline   Reply With Quote
Old 11-26-2003, 06:02 PM   #3
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
You could also re-wrap it right?
Old 11-26-2003, 10:47 PM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
I could, but everytime I changed my oil, it would be a serious pain in the ass unsrewing and screwing the oil filter back on.
Old 11-26-2003, 11:22 PM   #5
Ahzlon
Member#: 45216
2005 Baja Turbo
I have had my Borla's on for 2 oil changes and I havne't seen any deformation or any issues with the filter with the headers that close.. so i wouldn't worry about it too much
plus if your worried about getting oil onthe "rewraped" header.. take a screw driver and poke a hole in the bottom of filter before you remove it.. and just put a bit of aluminum foil over the wrapped header before you change ur oil.. should keep it clean
Ahzlon is offline   Reply With Quote
Old 11-27-2003, 11:27 AM   #6
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
I don't see why it would mess up the filter but it can't be the best thing in the world to heat up your oil like that. The oil filter can is nothing special, just relatively thin sheet metal.
ws6fiero is offline   Reply With Quote
Old 11-27-2003, 12:13 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Maybe you could try one of the smaller filters released by Subaru for the late model turbos because the larger ones were too close to the downpipe. Just a thought, don't know if there would be any fitment or other issues.
Old 11-27-2003, 09:08 PM   #8
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
my car is NA, not turbo so I'm not sure if the filters would be compatible, hopefully they would be just in case it did result in a problem
how much $$$ do you think this is worth? Caddy Daddy Off-Topic 10 07-04-2004 02:13 AM
How much do you think this is worth? 56k = no mms4ba Off-Topic 60 03-07-2004 01:13 PM
Do you think this is for real? fliz Off-Topic 5 12-10-2003 10:31 PM
Do you think this is a good deal on a used car? AlanTheWoo Off-Topic 3 08-08-2003 11:33 AM
Do you think this is covered in the warranty? CTP Warranty Issues & SOA Problems 2 06-10-2002 03:43 PM
