Old 11-26-2003, 01:21 PM   #1
Nicklbrso
Member#: 44887
00 GC6
Default wheel rub or something?
I've noticed within the last week or so that at real low speeds(1-5mph) That there is some sort of rubbing noise on the drivers side rear tire. I've looked around in this area but there is nothing visible that could be rubbing and it is only this tire that is making any noise. Im not sure what it could be. Any ideas? Thanx
Nicklbrso is offline   Reply With Quote
Old 11-26-2003, 02:21 PM   #2
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
probably in need of a new wheel bearing
AustinSTi is offline   Reply With Quote
Old 11-26-2003, 09:33 PM   #3
Nicklbrso
Member#: 44887
00 GC6
They are brand new wheels though I bought this past September. Anyone else have any ideas?
Old 11-26-2003, 10:50 PM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
I could be wrong but what I'm talking about is not apart of the actual wheel/rim.....its the part in the middle of the rotor. When they go bad (AFAIK) they make a weird whurling noise thats hard to describe
Old 11-27-2003, 09:18 AM   #5
Nicklbrso
Member#: 44887
00 GC6
Thats what I figured you mean after I posted a reply. I will check it out this weekend. Thanx.
Old 11-27-2003, 12:51 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Yup, jack up the car and rotate the wheel and listen carefully.
Also grab the wheel at the top and bottom (6 and 12) and try rocking it. Worn bearings will let the wheel move. Check the other rear wheel as well to compare.
A bad bearing sounds like a bit of a rumble that changes pitch with speed.
Old 11-27-2003, 09:13 PM   #7
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
I was told that spinning one wheel (manually) was bad for either AWD cars or maybe just ones with LSD? Im not too positve on the validity of either, but a mechanic who speciallized in VR4's said it.
Old 11-28-2003, 09:18 AM   #8
Nicklbrso
Member#: 44887
00 GC6
Mines only a FWD so it should'nt be a problem
Wheel bearing or something else? xcdhridr Brakes, Steering & Suspension 9 04-29-2009 12:59 PM
WTB stock wheel + tire or something cheap vrgs VIC Private Classifieds 3 07-31-2007 03:04 AM
Wheel rubbing or someting at 5mph and below Acejam2k Legacy Forum 5 07-31-2005 12:23 AM
Wheel rubbing or someting at 5mph and below Acejam2k Legacy Forum 14 07-05-2005 11:14 AM
18" Wheels = rubbing or not? Kickz107 Brakes, Steering & Suspension 4 10-24-2002 04:50 PM
