Old 11-26-2003, 10:21 PM   #1
dangerousimpreza
Member#: 36754
2008 2.5i
Rally Blue
Default injectors???
Hi, I have a 2003 impreza ts and like anybody I'm looking for horsepower. I'd like to know if I would increase my hp with some better fuel injectors and pump and what kind should I buy?
Thanks
dangerousimpreza is offline   Reply With Quote
Old 11-27-2003, 12:19 AM   #2
HoOn
Member#: 43270
2004 Impreza WRX
You won't get any gains with those without some sort of Engine management.
- John
HoOn is offline   Reply With Quote
Old 11-27-2003, 01:09 AM   #3
dangerousimpreza
Member#: 36754
2008 2.5i
Rally Blue
Ok but what kind of engine management should I get? Should I change my ecu or should I get a device like an apexi S-AFC piggy back fuel computer?
Old 11-27-2003, 01:51 AM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Thanks
You will not increase your horsepower with some better fuel injectors and pump unless you have done a mod to increase the amount of airflow to your engine. Then even though you have increased the amount of airflow to your engine, you have to know whether the increase of airflow is so much that the car runs lean despite the stock ECU's map at wide open throttle (WOT).
In this case a better pump and fuel injectors will benefit.
Kevin Thomas is offline   Reply With Quote
Old 11-27-2003, 02:23 AM   #5
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
Short answer: No, you won't get any gains.
Intake and exhaust should be your 1st concerns. Let it breath at higher RPM. My TS picked up a full second on the strip with intake and exhaust.
jasona is offline   Reply With Quote
Old 11-27-2003, 06:33 PM   #6
dangerousimpreza
Member#: 36754
2008 2.5i
Rally Blue
The thing is that I'm looking for the next step after the exhaust and the intake. I tought a better fuel injection would do the job. What should I look for then?
Old 11-27-2003, 09:53 PM   #7
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Well
For one, you could get lighter components for the car or lighter rotating mass (Ex: lightened flywheel, lighter rims, pulley, etc). Or you can get a fuel controller (Apexi SAFC, Hyper Field SAFC, etc) and get to a dyno to try to modify your fuel settings for power instead of the stock 'economy' mode. When I say modify your fuel settings for power, I'm saying adjust your fuel settings on a dyno to 12.5 air/fuel ratio for peak power (or whatever other tuning technique the dyno operator/friend suggests). Just a thought.
WTB: STi pink injectors/ 07 STI injectors/ 06 WRX injectors bwco VIC Private Classifieds 8 06-19-2013 11:40 PM
FS/FT : 650 injectors LT_DAN0690 Engine/Power/Exhaust 4 06-03-2010 09:26 AM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 19 11-24-2007 11:30 PM
SoCal:STi injectors, JDM STi pink injectors and 05 WRX injectors BlueFish Engine/Power/Exhaust 25 11-12-2007 05:36 PM
Injector Pulse Width to Injector Duty Cycle SonicWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-19-2002 10:36 AM
