Old 11-26-2003, 10:25 PM   #1
essogas
Member#: 35703
2004 WRX STi
Blue/British Black 18's
Default Any good links to suspension knowledge?
I read the FAQ's but it is somewhat limited. I want to learn more about the suspension system. For one thing, I'm nost sure what endlinks are? Trailing arms? lower front and lower rear sway bars are self explanatory... strut mount bars, I know what they are. The big question is how much Value do you get out of these components?
Value = big gains, reasonable money.
Value does not = little gains for big money.
Maybe a good way to go about this is to rate each component on a scale from one to ten on how much "bang for the buck" you get with these....
essogas is offline   Reply With Quote
Old 11-26-2003, 10:54 PM   #2
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
OK - this might be long.
Endlinks- the connector between the swaybar and the suspension arm/upright.
Trailing arms- The suspension member that runs front/back in the rear suspension of Subaru's (generally).
Here's a rundown of what makes the biggest difference per dollar as far as handling. On a scale of 1 to 10 with 10 being best bang for the buck. Note- this is just my opinion and may not agree with some people's thoughts on the matter.
sway bars- as long as you balance the front with the rear and don't go to large (26mm is too large)- 10
End links- stiffer the better- 3
Bushings- depends on how you want the ride to be- 4
Struts- Depending on setup (stiffness of springs/ damping/rebound settings)- 7
Coil overs- Same stuff as struts, but more performance oriented (worse ride, most of the time)- 6
Strut tower braces- They look cool, but on a Subaru they don't do enough to be worth it (excluding the rear brace on a wagon, especially pre-2002's)- 1
So that's what I've seen/felt in the last few years. If you have any specific questions PM me.
speedyHAM is offline   Reply With Quote
Old 11-26-2003, 11:51 PM   #3
essogas
Member#: 35703
2004 WRX STi
Thanks, I just educated myself at wrxtuners.com. So sway bars (underneath) have way more effect than the top strut braces? I thought this might be the case.
endlinks and bushings just to get rid of that last little bit of flex.
Old 11-27-2003, 02:37 AM   #4
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
nhluhr is offline   Reply With Quote
Old 11-28-2003, 12:14 AM   #5
essogas
Member#: 35703
2004 WRX STi
^^^ wow, great link above. Thanks!
Old 11-28-2003, 01:34 PM   #6
olappa
Member#: 48126
2004 STi
blue/gold
yes, but you have an STi. i have found that the best gains have come from the Pink springs (an 11!) and STi hardened strut mounts (9). Strut bars are probably a 10 if you use them in conjunction with the first two. GET ALL OF THE ABOVE. they work great together in this car.
I would assume that upgrading the bushings would help also, but I have not done so yet.
olappa is offline   Reply With Quote
Old 11-28-2003, 01:35 PM   #7
olappa
Member#: 48126
2004 STi
blue/gold
oh, and that said, swaybars arent needed.
just moved to Biloxi, MS area... any good shops to get work done anywhere near here? 280hp_REX South East Region Forum 0 02-01-2007 12:00 PM
Bored at work, any good links? Undepelo Off-Topic 0 03-14-2006 11:06 AM
Anyone have any lateral links to sell? Diode663 Tri-State Area Forum 2 08-17-2005 11:05 AM
Any good links for STI parts? Vampyr Newbies & FAQs 4 07-28-2005 01:26 AM
