Old 11-26-2003, 11:50 PM   #1
9
Member#: 4074
1998 Impreza RS
RBP (one of the first!)
Default compression check questions
I'm going to do a compression check friday when I go into work, and just wanted to know what the normal compression for a 98 2.5 rs is on each cylinder. Thanks
Courtney
9 is offline   Reply With Quote
Old 11-27-2003, 12:01 AM   #2
awd4ever
Member#: 31573
I found the
meaning of life!
it should all be within 15 average
awd4ever is offline   Reply With Quote
Old 11-28-2003, 07:51 PM   #3
9
Member#: 4074
1998 Impreza RS
15? 15 what psi? I've never done one before my boss showed me how, he read the gauge while I cranked it over. He said I got 175 on 2 & 4, 125 on 1 and 0 on 3. so deffinately need to take a head off. Thanks for the help anyways.
Courtney
Old 11-28-2003, 11:51 PM   #4
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Did something happen to your motor for you check the compression, or did you just feel like doing it? Those numbers are scary... what happened?
Ruff is offline   Reply With Quote
Old 11-29-2003, 01:47 AM   #5
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Did the belt slip a coupla notches on one cam?
1 Lucky Texan is offline   Reply With Quote
Old 12-01-2003, 10:06 PM   #6
9
Member#: 4074
1998 Impreza RS
Some one talked me into taking my car somewhere to be worked on, usually I do all the work myself. I had a few bent valves, dumb mistake on my part. so anyway after this guy finishes, I get my car back and a few days later it dies. I know he used napa parts instead of subaru, if it makes a difference, and figured that the timing belt broke or something. So the next day I take the cover off and see that some teeth are stripped off the belt. then I notice that the right intake cam isn't moving, later to find that an oil passage was blocked somehow and cause the cam "guide" to not get oil and it ground the cam down reall nasty like, and also really fubared the guides on the head side. I talked the guy into paying me to fix it and paying for parts (long story), so he gets a complete head for the one side. after I fix it and get it running, and notice how rough it runs, he says " oh yeah I didn't even think about it but I bet you got some bent valves on the left side" so a compression test later and now I gotta basically do the same thing all over again. oh well it's fun to a point.
Courtney
Did Ver8 compression check. What does it mean? ebeck Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-14-2004 09:52 PM
compression check/leak down check tribalwrx Alaskan Impreza Club Forum -- AKIC 13 09-06-2004 09:01 PM
a little help with compression checking Wheeler Bement Texas Impreza Club Forum -- TXIC 4 04-01-2004 08:00 AM
Spark plug change/compression check West L.A. CMJ Southern California Impreza Club Forum -- SCIC 0 02-29-2004 05:54 PM
Compression Check Numbers? PLEASE BlueDemon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-13-2003 11:48 AM
