Old 06-28-2000, 08:30 AM   #1
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Cool Stock Harness Mounts???
I just got my 2000rs last night. It is great I have been trying to get this car for 3 years and everything finally fell into place. I love IT.
But, I digress, I noticed 3 tie down points on the back deck (this may be 2000 only as I have never heard anyone else mention it). They look like attachment points for a 4/5 point harness. Is this possible? I looked underneath the rear deck, in the trunk and they are bolted into tabs on the rear seat cross member with grade 8 bolts and the tabs are fully welded to the crossmember not just tack or spot welded! What's Up? Could these be stock attachment points for a race harness?
skidplatez is offline
Old 06-28-2000, 08:38 AM   #2
Ryouga
Member#: 268
2000 Impreza 2.5RS
Blue Ridge Pearl
Talking
First of all, congratulations on buying the car.
I guess you haven't gotten around to reading the owner's manual all the way through yet.
Those attachments are for child safety seats.
Ryouga is offline
Old 06-28-2000, 08:42 AM   #3
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Post
Wow! I feel really dumb! I got in at 1AM last night and haven't even opened the manual yet!
Old 06-28-2000, 08:43 AM   #4
Eric
Member#: 48
1999 Impretza 2.5
Post
Actually, those are for child seat tethers. The harnesses tie into the seatbelt bolts. For my Schroth Rallye 4 I used the two mounts for the bottom of the left rear seat belt. This is what the instructions from Schroth said to do. I think the angle of the belt would be a bit to straight it you went straight back to the rear deck with it. Its real easy to put in a harness, 3 of the 4 mount points took a combined 10 minutes to put in place, the one on the inside of the drivers seat took a little longer because it is so tight to work in there. Smaller hands could get it done in a total of 15-20min, start to finish (if that).
Eric
Silver 99 RS
Eric is offline
Old 06-28-2000, 08:47 AM   #5
skidplatez
Member#: 1575
2011 WRX Premium
Blackest Black
Post
well could these points be used for the shoulder straps of a harness?
Old 06-28-2000, 09:50 AM   #6
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
those points should definitely NOT be used to mount a harness. They may hold the weight of a child, but not that of a grown person!!
Strepto is offline
Old 06-28-2000, 10:09 AM   #7
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Skidplatz,
I think you may not have understood Eric. To mount a four-point harness all four pints get bolted to stock seatbelt locations. The two "lap" belt points get bolted in with the regular driver lap belt hardware, the two shoulder points get bolted in with the hardware of the rear-drivers-side lap belt. This is the safest location since the harware at these lacations is designed for this use. The angle the shoulder straps makes with the seat back is within the recommended limits. There are dozens of people (including me) who have it set up this way and it works. Hope this helps.
Tony
[This message has been edited by Tony (edited June 28, 2000).]
Tony is offline
Old 06-28-2000, 10:31 AM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Can you easily convert a 4-pt harness to a 5 or 6 pt harness? & where's a good place to buy these? If I get some, I'll be sure to do a documented installation to make things easier for everybody.
~G
RidinLow is offline
Old 06-28-2000, 01:39 PM   #10
Eric
Member#: 48
1999 Impretza 2.5
Post
I dont know about converting a 4 to a 5. Maybe if its already set up like that and you can simply plug in the extra belt. There are definitly 5's available, but the 4 works just fine. And unless you are thinking about hitting a wall head on, the antisubmarine crotch cramper belt really isnt necessary and is more of a pain in the you-know-what than it is effective at keeping you planted in the seat. And my 4 point has a setup that acts to the same end (on paper atleast). I got it more to keep me in the seat while racing, not for the pure crash protection it provides. Cones tend to flop over rather than stop you in your tracks like a concrete wall does.
Eric
Silver 99 RS
edit-call/email rallispec. I bet if its out there, they can get it for ya. www.rallispec.com
[This message has been edited by Eric (edited June 28, 2000).]
Eric is offline
HTML code is On
Harness mounting HW bbbradley New England Impreza Club Forum -- NESIC 1 03-05-2002 10:42 AM
harness mounting points Freeskier Interior & Exterior Modification 4 09-27-2001 11:56 PM
Harness Mounting Points Fritz Motorsports 10 04-06-2001 05:27 AM
5 pt harness mounting Hondaslayer General Forum Archive 4 03-24-2001 07:52 AM
