Notices
Old 11-27-2003, 07:32 PM   #1
mrchau
Member#: 44649
Arrow Unorthodox Pulley help
happy turkey day!
i got my car used, and the previous owner included some parts including spark plugs, brakes, and a unorthodox pulley. i don't know much about pulleys, so i'm asking for info about this one. i am wondering if its underdriven, and if it is, do i have to worry about charging and other electrical issues? and is this worthwhile to put on my car? the only thing i know about this is that it's made by unorthodox racing (it says so).
edit: also, if its underdriven, that means i would need new belts as well?
i included some pics of it:
mrchau is offline   Reply With Quote
Old 11-28-2003, 12:45 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
What's the diameter of the pulley? measure the circumferance or get a rough diameter measurement.
Most likely, it's underdriven.
As for it being bad.....I wouldn't say it's bad....but it'd be better if you had a stock sized pulley.
Legacy777 is offline   Reply With Quote
Old 11-28-2003, 05:59 PM   #3
mrchau
Member#: 44649
it is about 11 cm in diameter. to install this would i need a new belt also? are there any websites that explain installing this?
Old 11-28-2003, 07:27 PM   #4
SubyBean
Member#: 4367
1999 IMPREZA 2.5RS
Black :-( with dings
hey man check out scoobymods.com there is plenty of info there
Brian
SubyBean is offline   Reply With Quote
Old 11-28-2003, 08:09 PM   #5
Legacy777
Member#: 4800
yeah, it's underdriven......if you can't find any info on belt sizes, I can try and get mine.
Old 11-29-2003, 12:49 AM   #6
Blindeye_03
Member#: 4418
2016 Focus ST
Its going to destroy your car. Dont install it.
I am sorry if you believe that garbage like most people will tell you.
Ive been 'underdriven' for over 50k miles on an autocrossed RS and I have had NO problems so far.
Ill see if I can remember to see my belt sizes too, and post em up.
-justin
Blindeye_03 is offline   Reply With Quote
Old 11-29-2003, 02:39 AM   #7
mrchau
Member#: 44649
thanks guys, so given these belt sizes, i would be able to order these belts by themselves somewhere right?
Old 11-29-2003, 11:26 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Take your stock belt to an auto parts store and have them give you a couple choices of each. Take them home and try them out. Keep the two that fit the best and take the rest back.
Tim Sanderson is offline   Reply With Quote
Old 12-03-2003, 10:49 PM   #9
audiofreak
Member#: 42238
1998 impreza L
acadia green
Gates: Micro-V K040340 14mm X 875mm
Gates: Micro-V K050336 18mm X 870mm
audiofreak is offline   Reply With Quote
***HELP, unorthodox pulleys advice*** vnap13 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-12-2008 06:18 PM
$180 Good for Unorthodox Pulley?? BrysImpreza Normally Aspirated Powertrain 2 04-10-2001 11:44 AM
unorthodox pulley IMPREZA GUY Normally Aspirated Powertrain 4 03-30-2001 09:52 AM
Unorthodox pulley subymamma Newbies & FAQs 21 11-02-2000 09:27 AM
Loss of A/C at idle with Unorthodox Pulley? Impresario Technical Forum Archive 4 05-16-2000 07:18 AM
