Old 11-28-2003, 11:51 AM   #1
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
Default What should happen if I unplug the front 02 sensor?
since yesterday, my car is doing weird thing. when I start it, it would idle ok. when I sart rolling, after a few second at constant speed, it would jerk, backfire or miss, the car is shaking just like when you try to drive in 1st and it began to bump and bump... I changed the fuel lines. after doing the pressure line and main return, it was OK, then after doing the small return line, it act like I said before. I tought it was the O2 sensor, but I unplugged it, and nothing changed. I can't rear error code since i don't have OBD2 plug installed. MY01 RS powertrain with 25K miles.
NicEJ25 is offline   Reply With Quote
What would happen if I switched the power and the ground wires to my amp? Meta4 Car Audio, Video & Security 23 09-01-2010 08:07 AM
Does the front 02 sensor ...... metoo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 05-23-2007 04:50 PM
What could happen if you overfill the Engine Oil Shikamaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-23-2005 01:49 PM
What will happen if you plug the other nipple on a Greddy Type s bov? LqSilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-19-2004 01:45 PM
What should be sound deadened after the front doors? Rich10 Car Audio, Video & Security 7 08-20-2003 05:07 AM
