Old 11-28-2003, 06:19 PM   #1
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
Default Series To Parallel Fuel Delivery Modification
I just wanted to know if anyone here has done this mod?
http://www.scoobymods.com/forums/sho...p?threadid=175
NeaD is offline   Reply With Quote
Old 11-28-2003, 08:08 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
It's a little more involved....mainly because you really can't get that little adapter they used. So dealing with the fpr is a little more difficult. There are ways of dealing with it, but I decided it wasn't worth the hassle for the amount of gains or improvement on a n/a motor.
Legacy777 is offline   Reply With Quote
Old 11-28-2003, 08:21 PM   #3
NeaD
Member#: 43371
Hydra User, Blue
Well.. im about to put my turbo kit on in that is sitting my room.
I just posted this in the N/A forum becasue it's really a n/a mod.
where do i get this adapter?
Old 11-29-2003, 10:13 PM   #4
NeaD
Member#: 43371
Hydra User, Blue
bump
Old 11-30-2003, 03:58 PM   #5
Legacy777
Member#: 4800
I wish I knew where to get the adapter.
What needs to be done is the fuel pressure regulator needs to be moved. But when you do that, you either need to get an adapter for that fuel rail, or you need to use a rail from the other side and do some tweaking on the piping that goes to that rail.
You then can either use an aftermarket fpr, which would probably be best.....or do some tweaking to use the stock fpr.
Series to Parallel Fuel Mod 2TG8V South West Impreza Club Forum -- SWIC 4 05-13-2006 07:23 PM
would the series to parallel fuel line conversion for RS work on WRX? whiterabbit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-22-2004 01:16 AM
Series to Parallel Fuel Mod or New Fuel Rails? Need4Boost Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-10-2003 10:05 AM
Question on finding parts for the series to parallel fuel rail mod Legacy777 Normally Aspirated Powertrain 1 02-24-2003 09:06 AM
DIY Series To Parallel Fuel Delivery Modification thoughto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-28-2002 12:19 AM
