Old 11-29-2003, 02:00 AM   #1
cybin
Member#: 48667
Default Does anyone make cams for the 2.2L
Just wondering if anyone has heard of a company making cams for the 2.2L?
Stateside I'm guessing no but I'm hoping that some overseas company might have made one.
-cybin
cybin is offline   Reply With Quote
Old 11-29-2003, 08:24 AM   #2
NotAnRS
Member#: 1004
2002 Forester L
Scratch-n-Dent Blue
Question
I'm wondering why 2.5 cams wouldn't work?
NotAnRS is offline   Reply With Quote
Old 11-29-2003, 04:05 PM   #3
cybin
Member#: 48667
Did they make a SOHC 2.5L?
Old 11-29-2003, 04:13 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Yup, about 1999 or 2000 they switched to SOHC.
Could you use 2.5L cams?, good question but I would doubt it. But I never looked either.
Old 11-29-2003, 06:49 PM   #5
C17LOAD
Member#: 25488
2005 Impreza WRX STi
"Petter Solberg Edition"
why not? I have been told by a couple of shops that the "Phase II" EJ22 cams should be interchangeable with the SOHC EJ25. Not an expert though, just what I heard.
C17LOAD is offline   Reply With Quote
Old 11-29-2003, 08:10 PM   #6
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
My 00' rs manuals show that the thrust clearance, journal, and oil clearances are all the same.
The only difference is that the intake lobes are nominally
38mm 2200litre
39mm 2500litre
and the exhaust are the same on both at
39mm nominal
So I think you could use 2.5 litre cams in a 2.2 litre phase 2 head. I suppose you could even use stock cams even though you would only gain about 1mm of lift.
Good luck
Tim Sanderson is offline   Reply With Quote
Old 11-29-2003, 11:10 PM   #7
cybin
Member#: 48667
1mm of extra lift on the intake side might make some differance. Subaru makes so many parts the same, it makes one wonder.
I mean for the 2.2L you have just about everything, intake, headers, exhaust, Chip, pullys, ect. Only thing holding the 2.2L back is a set of descent cams or higher compression.
I wonder if bulkers/gude would be willing to develop a mild cam? I guessing it would have to be a regrind since milling a brand new one would be costly. Maybe we should get a group buy together.
-Cybin
Old 11-29-2003, 11:19 PM   #8
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
If the stock 2.5 cams fit the 2.2 then aftermarket 2.5 cams should fit as well. The problem lies in the exhaust port. The my 00' 2.2 heads are single exhaust port heads. A better solution would be to swap heads with a 2.5. Then you can be sure of cam fitment. But then why go through the hassle of just heads when a complete engine would probably be about the same cost. The ecu harness and ecu may not fit/work so you would be looking at upgrading those as well. But if you just do a head swap, you are still looking at a good amount of gaskets to replace. And headers.
Tough call. Good luck
Old 11-30-2003, 05:28 AM   #9
cybin
Member#: 48667
What would the 2.5L heads on a 2.2L block do to the compression ratio? I'm also wondering about valve clearance.
Has anyone done this swap?
-cybin
Old 11-30-2003, 11:33 AM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It should not alter the compression. The only differences between the n.a. 2.2 and the n.a. 2.5 are the bore and stroke. Otherwise I think the manual would specify examples of each for service.
Same valves
same rocker assembly
same springs
I would hope that someone could either confirm or deny this. The only differences are the cams and the single exhaust port. But, All I'm doing is looking in the manual. I'm not actually looking at the two and comparing them side by side.
Old 11-30-2003, 01:32 PM   #11
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Whether or not it changes compression depends on how much volume of the combustion chamber there is in the two different heads. Without taking some measurements or talking to someone who has done this there is no way to tell for sure. I have been told that the SOHC EJ25 heads have less volume than the DOHC EJ25 heads, but as for where the EJ22's sit in there is unknown to me. I know there are a couple people running around with what they call EJ2.25's. I will see what I can dig up and post back, eventually...
Old 11-30-2003, 04:03 PM   #12
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
I suggest you guys do some more homework on the head swapping. It will make a difference and change compression ratios.
http://forums.nasioc.com/forums/show...ion+ratio+EJ22
Legacy777 is offline   Reply With Quote
Old 11-30-2003, 07:18 PM   #13
cybin
Member#: 48667
I want to keep this simple. No turbo or switching ecu. (unless it's plug and pray, I mean play)
I'd like to stay with SOHC since I think you'll need to swap the ECU to go with DOHC. Staying SOHC will also keep the single exhaust port.
Options as I see it:
Get some cams from a 2.5L SOHC to fit the SOHC 2.2L in my OBS. Previous threads suggest differances in hydralic verse roller rocker valve trains.
Swap a 2.5L SOHC head onto the 2.2L block. How this will effect compression ratio and head flow? I don't know. Would the valves even clear the piston? Would the computer freak out?
I'm really hoping to find an easy way to gain 10hp or so. Nothing huge just a little pull.
-Cybin
Old 11-30-2003, 08:47 PM   #14
Legacy777
Member#: 4800
cybin,
there's quite a bit of misinformation in this thread, as well as a lack of specific information on your part as to specifics on your car/setup, etc.
All 2.5 motors have dual exhaust port heads.
The newer 2.2 liter motors (~95 and newer) are the only ones that have the single exhaust port heads.
Roller rockers can be swapped around between heads.
Old 11-30-2003, 09:20 PM   #15
cybin
Member#: 48667
1997 Outback Sport 2.2L 5sp
Pretty sure I have an EJ22 SOHC with a MAF.
Goals for my car are modest. I'm going to be traveling so no engine/ecu swaps and no parts that are not better then stock. Would like a little more grunt. 30HP added tops.
Old 11-30-2003, 10:24 PM   #16
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
As I understand those threads posted by Josh - putting EJ25 heads on an EJ22 will LOWER CR. That might be OK if you're gonna and forced induction but otherwise I can't see an advantage.
maybe I'm wrong. anyone?
1 Lucky Texan is offline   Reply With Quote
Old 11-30-2003, 10:44 PM   #17
Legacy777
Member#: 4800
As I said before, read the threads I posted, there's some very good info in there.
lucky texan, you're correct in your diagnosis.
cybin,
What'd I'd probably recommend is not bother with a head swap. Per the threads I posted....putting EJ25 heads on will lower CR, which you don't want to do. Other option is the older style EJ22 heads with dual exhaust ports, but that will give you smaller valves....again you don't want to do.
So that leaves you the option to stick with your current heads.
I'm not sure if your model came with roller rockers. They can be had from around the 95-96 legacy 2.2's....so maybe yours has them. If you don't have, I'd suggest them. As for cam....you can get custom grinds on cams by paeco, or maybe cobb has something they can do. Other thing you can do to heads if have them ported and polished.
I suppose with the porting & polishing, cams, & roller rockers, you may be able to get 30 additional hp....depending on how you set the cam up.
That would be my suggestion for what you should look into.
I trust the guys that posted the info about swapping the heads & what will happen to CR, so I wouldn't bother with any of that.
josh
Old 11-30-2003, 11:26 PM   #18
Slack
Member#: 17548
Josh, it seems like you aren't quite answering what cybin is asking. He wants to swap the CAMS not the heads from the SOHC 2.5 . What I'm wondering is if you could get the cams from any later model subaru with the P2 SOHC 2.5: Forester, Legacy or RS? There are a lot more Legacy's than RS's, so it would be easier to obtain the cams from those cars. Correct me if I'm wrong, but we are just looking for modest gains with the least amount of work and/or money spent.
<ocl
Slack is offline   Reply With Quote
Old 11-30-2003, 11:41 PM   #19
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Well I am sorry of Any of the info I posted is incorrect. Again I am refering to the service manuals for 2000 model year only.
Old 11-30-2003, 11:53 PM   #20
cybin
Member#: 48667
So wait, there is a newer 2.5L SOHC engine?
My referance for 30hp is with headers, intake, bla, bla. So I guess I'm only looking to get 10hp from the cams. Another thing I'm not taking into account, is that I'm probably going to have to pull the motor anyway to replace the cams. So maybe swapping head won't be so much more. I'm still thinking in inline terms.
Anyway thanks for all the help to everyone. I'm happy to see so much support on these boards.
-Cybin
Old 12-01-2003, 09:45 AM   #21
Legacy777
Member#: 4800
I'm sorry, I must have misread the info about just the cams. I was figuring he'd have to pull the heads anyway....
I don't know the cam profiles on the SOHC EJ25 motors, so I couldn't tell you if or how much gains you would see by swapping stock cams into the EJ22. I would think they would probably work fine, but I would recommend talking to some tuners to verify that.
Old 12-01-2003, 09:47 PM   #22
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Cybin,
Why not just swap the whole engine for a DOHC 2.5l from a 1997 to1999 Legacy. Get the ECU too. It is plug and play. Go read up in the Conversions forum. Figure $1500 for a good engine and ECU and a few bucks of labour.
Its been done. Your ECU will run it too but the idle will not be great.
linsavy is offline   Reply With Quote
Old 12-02-2003, 12:43 AM   #23
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
The point of the thread was whether or not 2.5 litre cams would fit into 2.2 litre heads. Yours is a good suggestion, but not the kind of info he was looking for.
Old 12-02-2003, 05:26 AM   #24
cybin
Member#: 48667
I'm trying really hard to avoid a engine swap. I've done them and the cars never quite seem the same. Most run really well, but it's just not the same after. I want to take this car for an extened road trip. Like from wisconsin to alaska to Portland, OR then to San Deigo then home. So I'd like not to have to explain to some backwoods mechanic that the engine is from a legacy but the car is an impreza. Ect. ect.
I'm going to do some searches but does anyone know of a good company making SOHC 2.5L cams. If any?
Old 12-02-2003, 08:37 AM   #25
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Try expanding your search to include the archives at www.usmb.net and check www.obsportal.com
You will find there is just not much left in the 2.2l that Subaru isn't already getting out of it. Lighter pulleys, some say, are good for up to 9 more ponies. intake and exhaust may only get a few more ponies. Lighter flywheel might help. Higher lift/greater duration cams may yield a few ponies but the idle may be crap, the fuel economy might suffer, you could get close to needing a piston swap for clearance issues. More grunt down low and better handling could come with just smaller tires. So what if the speedo and odo are off a few percent.
I've read a LOT about the 2.2l as I am shopping for an older OBS and there really isn't anything for it short of forced induction, or nitrous. "Spend the money on pulleys, lighter flywheels, tires, rear anti-sway bar, maybe some KYB adjustable struts." That's the 'mantra' you will get. Sad
Does anyone make dampers for the 08 WRX (and soon to be 09)? BIGSKYWRX Brakes, Steering & Suspension 51 02-17-2010 08:42 PM
Does anyone make projectors for the 2005 STi's sti.2005.blk Interior & Exterior Modification 10 12-23-2007 11:18 AM
TWE cams for the 2.2L ? 99subi Normally Aspirated Powertrain 18 04-08-2005 01:00 PM
Does HKS make cams for the WRX? chopaholix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-30-2004 09:11 AM
Does MRT make springs for the 2.5RS? JC Brakes, Steering & Suspension 1 08-12-2001 12:20 AM
