Old 11-29-2003, 12:05 PM   #1
orndog
Member#: 34670
If she smokes she
pokes
Default engine tapping/ticking
It's more of a ticking sound. I did a search, but haven't seen a thread for a new car doing this. It only has 9k miles on it, and I change the oil every 3k. It's been doing this for a while, mostly after being warmed up. I use 5w30, and never even take her to redline. Anybody know if this is normal? I don't recall my old Legacy ever making this noise, but it was a 90 model.
orndog is online now   Reply With Quote
Old 11-29-2003, 12:42 PM   #2
8Complex
Member#: 922
04 FXT
Red
Is it a high-pitched ticking or a low-pitched tapping? If it's high-pitched, chances are it's just valve noise. If it's low-pitched, it could be piston slap (unlikely) or a timing belt tensioner (semi-unlikely, but not unheard of).
Old 11-29-2003, 08:24 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Are you sure it's the engine and not the heat shoelding on the header/exhaust? Check it out
Tim Sanderson is offline   Reply With Quote
Old 11-30-2003, 09:24 AM   #4
orndog
Member#: 34670
If she smokes she
pokes
I'll check that... as soon as it warms up a bit
Old 11-30-2003, 12:21 PM   #5
orndog
Member#: 34670
If she smokes she
pokes
It's a ticking sound, coming from both sides of the engine. It's faint, but you can hear it with the hood closed at 15 paces.
Old 11-30-2003, 07:43 PM   #6
codger
Member#: 13486
06 Legacy GT wagon
Try a side by side comparison with another EJ25. You might not notice much difference. I didn't notice any unusual sounds when I first bought my OBS, but I found that as time went on and I got more familiar with my car, I picked up on sounds that were always there.
I also had a rattling bent heatshield ticking sound once.
codger is offline   Reply With Quote
Old 11-30-2003, 08:20 PM   #7
orndog
Member#: 34670
If she smokes she
pokes
Another EJ25... lol, here in BFE (that area between Memphis and Nashville, TN) I might as well be looking for an Enzo.
Old 12-01-2003, 10:28 AM   #8
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
i have the same ticking. I believe its a normal sound of the car. codger might be right though becuase I didn't notice it at first either. My other car was a noisy POS so the ej seemed like a whisper. after time i started to notice it.
moogoob is offline   Reply With Quote
Old 12-01-2003, 12:04 PM   #9
MrHorspwer
Member#: 4063
The noises I hear on my EJ25...
Piston slap when cold. It goes away just about the time the temp gauge starts to move. Normal.
Valve clatter. Louder when cold, always present to some degree. I can hear this outside the vehicle with the hood closed. Normal. A solid valvetrain (as the EJ25 is) will make ticking noises. I think this is what you're hearing.
Other engine noise only heard when the hood is open. Normal. Injectors ticking, belt whirring, etc.
I've heard pretty much all those noises since it was new. I'm at 45K miles now.
Noises I have NOT heard...
The infamous belt tensioner. From what I have gathered from others, this is a heavier noise. Not quite a knock, but heavier than piston slap. It also goes away as the enigne comes to temp.
MrHorspwer is offline   Reply With Quote
Old 12-01-2003, 12:13 PM   #10
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Hydraulic Lifters? Try switching to a heavier weighted oil and add a quart of Rislone or GUNK Oil Treatment in place of a quart of oil at next oil change...
marcus12 is offline   Reply With Quote
Old 12-01-2003, 12:34 PM   #11
8Complex
Member#: 922
04 FXT
Red
No, Subaru stopped putting hydraulic lifters in heads around 1997-1998.
Old 12-01-2003, 03:06 PM   #12
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
I knew I should've bought an RS...ahhhwell
Old 12-01-2003, 07:53 PM   #13
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Ditto, MrHorspwer. I have the same noises that occur in the exact same situations that you described. I have aboot 13k on my 4EAT. From what I know, what you've mentioned are normal suby sounds and are nothing to be concerned about.
I also have a little bit of extra whirring noises from the lightened crankshaft pulley I installed, but otherwise, no major problems...(I hope)
DrBoy01 is offline   Reply With Quote
Old 12-01-2003, 08:03 PM   #14
orndog
Member#: 34670
If she smokes she
pokes
I was thinking it sounded like the solid lifters on my 69 Camaro...
Old 12-02-2003, 08:44 AM   #15
2004TS
Member#: 49214
2006 Impreza Outback
black and gray
I think that is pretty normal sounds. I just bought mine about 2 weeks ago, and now that I am getting used to it, I am starting to hear all the sounds that the engine makes, ticking, knocking. I had my friend listen to it, and he just said, sounds like a boxer to me. So, I am not going to worry about it, it only has 500 miles on it. It is just the fact that if any other engine sounded like a boxer, it would have 175,000 miles on it and be on its last leg. It is just hard sounds to get used to, especially on a new car.
2004TS is offline   Reply With Quote
Old 12-02-2003, 12:20 PM   #16
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
My 2000 RS does the same thing, almost like an exhaust leak, especially when it's cold. I noticed it this weekend (this is my first real winter with the car) and was a little concerned, but it seems to go away after about 15 minutes. After that, the motor is still on the noisy side, compared to honda and toyota motors, but some motor types/manufacturers make more noise than others. At least I'd say it's an *even* noise, it doesn't sound like it's struggling or leaking anything
subarucyclist is offline   Reply With Quote
Old 12-02-2003, 11:22 PM   #17
evo2rex
Member#: 40843
w/ 07 6mt DCCD Pro
To my knowledge, all subarus do it. I have a 97 Obs and an 02 WRX.... they both do it. The WRX (48k miles) actually taps louder at idle than the OBS (150k miles), go figure.
evo2rex is offline   Reply With Quote
Old 12-02-2003, 11:24 PM   #18
codger
Member#: 13486
06 Legacy GT wagon
Yeah, I bought an 83 Celica in 1985. It ran so quiet, that even with the hood up, people would ask if it was running. By the time I sold it 300,000 km later, it sounded more like a John Deere......or my Subaru.
Old 12-03-2003, 08:15 AM   #19
orndog
Member#: 34670
If she smokes she
pokes
My 90 Legacy didn't, that's why I asked.
Old 12-22-2003, 09:19 PM   #20
MixStix
Member#: 30684
2004 WRX Wagon
Outback Sport
Whew!!! These "normal" noises have always made me nervous since about 12K on my 02 OBS. I don't recall my 99 OBS making as much noise and it had more mileage before trade. My drivetrain warranty is just about up so I wondered if it was a good time to pick apart any last minute concerns I had about the engine with the dealership. Time to put those worries aside I guess.
MixStix is offline   Reply With Quote
Old 12-23-2003, 12:52 AM   #21
atabert
Member#: 45107
1992 Legacy L
Green
Default ticking
What about those things called injectors , they make a ticking noise constantly, and it is pretty loud, but its also possible that your car might need the valves to be adjusted, the t-belt tensionor is a low knocking and it is not a steady/constant knock, it can come and go and change in loudness, but to me it sounds like your probally hearing your injectors turning off and on? just a though, let me know what you come up with?
atabert is offline   Reply With Quote
Old 12-26-2003, 05:21 PM   #22
Kreeger
Member#: 37558
2003 TS wagon
JDM bukkake white
Default Re: engine tapping/ticking
I had the same concerns but realized that it was just because I had put a Borla header on... The shrouding of the stock exhaust manifold muffles the normal "clicking" of the valvetrain. The Borla (or any) header has thinner guage steel and no shroud, therefore emitting more noise. It immediately became apparent when I compared my car next to a stock TS.
This, of course, is if you have a header.
Kreeger is offline   Reply With Quote
Old 12-26-2003, 08:54 PM   #23
orndog
Member#: 34670
If she smokes she
pokes
No header... yet...
Thanks though
Old 02-17-2004, 12:10 AM   #24
FLaBrit
Member#: 19135
2002 RS
My 02 RS makes a ticking nosie that is almost to the point of irritating me enough to take it to the dealer but then I think of the 50 mile drive + wait and I turn the stereo up I don't remember my wifes Outback making the came nose but it had sound insulation under the hood etc. that may have made a difference, anyway, she hated it and made me buy a POS SUV for her so I can't compare the 2 directly.
FLaBrit is offline   Reply With Quote
Old 02-17-2004, 11:26 AM   #25
Matt
Allergic to turbos
Member#: 181
Two Subarus and
a truck
Hmm...
At 11k miles I had my dealer replace a timing belt tensioner on our '02 OBS. The car sounded like it was tapping, then eventually sounded like a diesel. It was very noticeable and came from the front of the motor.
Just a thought.
Matt is offline   Reply With Quote
Terrible tapping/ticking/clicking on 02 WRX GTScoob Service & Maintenance 6 06-25-2007 04:55 PM
Erratic tapping, ticking from engine bay. scooby1220 Factory 2.0L Turbo Powertrain 19 11-09-2006 12:02 AM
Engine tapping/ ticking Nicklbrso Normally Aspirated Powertrain 4 02-21-2004 07:21 PM
my engine is ticking ? strange sound, is it normal? vapore0n Factory 2.0L Turbo Powertrain 16 03-28-2003 11:11 PM
It's cold outside and engine is ticking shippy1 Factory 2.0L Turbo Powertrain 6 10-06-2001 03:48 PM
Message Board Statistics All times are GMT -4. The time now is 08:17 PM.
