Mid Atlantic Impreza Club
Old 11-30-2003, 11:23 AM   #1
mrtrex
Member#: 12223
2005 WRX
Default Passing the NEW required OBDII Emissions test in PA Questions and Answers!!
We are now having an OBD2 scan instead of the sniffer test. Here are some questions and findings that I have found and need answered. Please post more info if you have it. Or even better if you have gotten the new test done already.
Question #1
Will altering the ECU's reading by adding a cel fix into the rear o2 sensor and a cel fix for the egt sensor fail the OBDII test?
Here is what I found.
There have been discussions mentioning that some of the fixes may prevent the OBDII readiness tests from being completed. This would cause you to fail an OBDII scan test.
From what I have herd is that you can have two codes that fail the readiness test and still pass. That's when the ecu checks the sensors and the sensor has not went through is check with the ecu. Resetting the ecu or clearing codes before the test would result in a ton of failed readiness codes and you will fail. You should drive about a week after resetting or clearing codes.
I dont see how it would fail an obdII scan. The upipe fix and the rear o2 fix makes the sensor read a value in the range that the ecu is looking for. When they do the obdII scan it will show up as one solid value all the time. I would imagine that the scan would show the same thing that obd 2 software does. It shows readings for all the sensors. When you look at the readings they will all be going up and down slightly for example rpm's will bounce from 700 to 725 to 695 and so on. The reading for the egt sensor and the rear o2 sensor will read the same. It will show up as value within the range that the ecu is looking for so I dont see how this would fail. I have data logged both sensors and on a graph they do give readings but it is a flat line with 0 changing values.
Question #2
Will a reflash from Vishnu/Cobb ect.. have any effect on the test such as readiness codes being triggered due to the tuner not using them or altering them in the tune?
I have found nothing on this subjust yet.
Question #3
Since they are not doing a sniffer and only testing through OBDII does this mean we can run huge injectors and not have to worry about emissions?
I have found nothing on this subject yet.
mrtrex is offline   Reply With Quote
Old 12-01-2003, 02:39 AM   #2
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
So does this mean no CATS have to be on the car?
I want a turbo back exhaust on my rex, but I don't want to run ANY cats at all.
Thanks,
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 12-01-2003, 07:44 AM   #3
mrtrex
Member#: 12223
2005 WRX
That means that you can run no cats if you have a pipe that looks like it is a cat but hollowed out.
Old 12-01-2003, 09:43 AM   #4
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
Thanks,
-Nigel
Search on the board... the performance difference between no cats and a high flow cat is REALLY small, it's not worth it to run with no emissions equipment...
http://forums.nasioc.com/forums/show...62#post3449864
-john
Old 12-01-2003, 09:52 AM   #5
mrtrex
Member#: 12223
2005 WRX
I want to stay on topic here but if you are running a bigger turbo + you will have nice gains from running catless. Back on topic.
Old 12-01-2003, 11:17 AM   #6
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
somewhat on topic: I ran up to PA this weekend to get inspected before the changes go into effect, and was amused to see that pre 1996 cars (with no OBD-II capibilities) have to pass a "Visual anti-tampering test" - haha, that's the one I wouldn't pass!
As far as the cobb/vishnu reflash - on Cobb's website, they say
"With the tools currently available at Subaru dealerships, it is not possible for them to detect that the ECU has been modified. We own the same service tools used by all Subaru dealerships and have verified that their function is unaltered by the AccessECU. Therefore, you vehicle can be serviced by the dealership in the same way as a stock vehicle."
anyway, if they can fool the dealership into thinking nothing is amiss, I'd imagine that the emissions scanner isn't going to be functionally much different, and should hopefully read a-okay across the board. But I guess we won't be totally reassured till someone actually goes through it and reports back
bleuquila is offline   Reply With Quote
Old 12-01-2003, 02:23 PM   #7
mrtrex
Member#: 12223
2005 WRX
Good info Keep it coming.
Old 12-01-2003, 04:36 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Any good info you can give to the few OBD-I guys, like me?
scoobyimprza is offline   Reply With Quote
Old 12-02-2003, 08:25 AM   #9
mrtrex
Member#: 12223
2005 WRX
Nothing should chang for obd1. You will still have to take the sniffer test.
Old 12-02-2003, 02:26 PM   #10
DILLIGAF Racing
Member#: 29440
2015 WRX
they just said it on the news 1975 to 1995 sniffer test
DILLIGAF Racing is offline   Reply With Quote
Old 12-03-2003, 08:26 AM   #11
mrtrex
Member#: 12223
2005 WRX
bump
Old 08-17-2004, 11:02 AM   #12
wrx034me
Member#: 44761
05 legacy 2.5gt
regal blue
now that this thread is 8 months old, any new updates?? are people passing? i'm due in next month i'm taking care of the mechanical o2 (sparkplug antifoulers) and 2.2k resistor on the uppipe today.
thanks, chris
wrx034me is offline   Reply With Quote
Old 08-17-2004, 12:32 PM   #13
iceNine
Member#: 12170
2002 WRX Sedan
Platnum Silver Metallic
I just put in the mechanical O2 fix 3 days ago after getting a couple of cat efficiency CELs (Stom. dp with third cat still in place). Out of curiousity I reset the codes and kept using my scanner to see when the readiness codes reset. I found that the individual codes took anywhere from 1 1/2 days to 1 1/2 weeks to reset (with O2 sensor readiness code taking the longest).
Dale
iceNine is offline   Reply With Quote
Old 08-17-2004, 01:46 PM   #14
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
i'm also interested to know if i'll have to change my 2.2k and MIL resistor mods on my car (which is catless) or whether i have to make some changes before going in for emissions. if anyone has any more info or experience with this please let me know.
bryan
TROLL is offline   Reply With Quote
Old 08-17-2004, 07:00 PM   #15
bleuquila
Member#: 31922
03 wrx wagon
fastAr than sound
I went in a month ago, passed no problems. I have stock uppipe, catless dp, stock 3rd cat, ghetto-fabulous catback and Cobb reflash. the reflash widens the 02 parameters enough that I don't get a CEL. They plugged in the car to the OBD-II, got a good-to-go signal and slapped on the pass sticker. The car was up on the lift and everything for the full state inspection, and they didn't bat an eye at the obviously tampered with exhaust. This was a Midas/Monro/somethingoranother. YMMV.
Old 08-17-2004, 07:53 PM   #16
Basil
Member#: 743
MY02 WRX Wagon
TXS Stg 2 - 242 whp
Wrinkleboi - as long as you don't have any CELs and have your fixes in place, you can pass the emissions test whether you have cats or not. So yes, a completely catless car can now pass PA emissions OBD-II tests.
Basil is offline   Reply With Quote
Old 08-17-2004, 09:59 PM   #17
DILLIGAF Racing
Member#: 29440
2015 WRX
Partially wrong there. They still "have" to do a visual check.
Old 08-17-2004, 10:19 PM   #18
DJ 9iron
Member#: 11349
2016 Mustang GT
Emissions my ass. Let us put what exhaust we want... Let us do what we want to our ECUs... :monkey: the man!
DJ 9iron is offline   Reply With Quote
Old 08-17-2004, 10:56 PM   #19
DILLIGAF Racing
Member#: 29440
2015 WRX
if only it was that easy
Old 08-18-2004, 08:38 AM   #20
Basil
Member#: 743
MY02 WRX Wagon
TXS Stg 2 - 242 whp
Actually, that's incorrect - the visual check goes on a county by county region - if your county had a visual check before the implementation of the OBD-II standards, then yes, you need a visual. But since most of PA hasn't required ANY type of testing up until now, there is no state mandated "anti-tampering" check for cars that qualify for the OBD-II test - strictly a gas cap and an OBD-II test.
Old 08-18-2004, 08:58 AM   #21
silverstipa
Member#: 42271
2004 STI - FPgreen
Enjoyed by a new owner
Correct. Where in Shrewsbury are you? I live in Stewartstown.
silverstipa is offline   Reply With Quote
Old 08-18-2004, 09:59 AM   #22
Jard
In the silly seat
Member#: 34935
SPB- 2013 Dadcore
Emission Test Results
The following tests may be required for your vehicle:
County: Cambria
Year: 2004
Vehicle: Car
Tests: Visual Check and Gas Cap Check
Note: Brand-new vehicles and vehicles driven under 5000 miles annually may qualify for an exemption sticker. Ask your service provider for more details.
Effective: Feb., 2004
Disclaimer: Gasoline-powered motor vehicles with a model year of 1975 and newer with a GVWR of 9,000 pounds or less and registered in an I/M county or region are subject to an emission inspection. Actual test requirements based on make and model, drive system, vehicle weight, etc. The regulations in Title 67 Pa. Code, Chapter 177 shall determine the test type for any individual vehicle.
We had no emissions testing until this took effect in Feb.
Jard is offline   Reply With Quote
Old 08-18-2004, 02:29 PM   #23
EdsWRX
Member#: 13881
08 spec b
07 335xi
I just had mine checked and I am running a catless DP and the stock STI catback. At first I had failed because my battery had died while I as out of the country and I tried to have it tested within a few days, the OBD-II scanner ready my ECU as not ready and I had to come back after driving it around for a few days, but once I went back a few days later I passed in about 5min.
EdsWRX is offline   Reply With Quote
Old 08-18-2004, 02:50 PM   #24
Siper2
Member#: 1134
2007 BMW 328xi wagon
I think the whole concept is absurd. In NH, we had basic inspections.
But here, they see fit to charge people a stupid amount of money on cars that run cleaner than the old ones.
Seriously: put 25 new cars next to one '70s clunker, and I guarantee the clunker has more emissions, than the 25 new cars put together. Yet the old cars have no penalty.
What a racket.....
Siper2 is offline   Reply With Quote
Old 08-18-2004, 03:35 PM   #25
Basil
Member#: 743
MY02 WRX Wagon
TXS Stg 2 - 242 whp
I live right by the borough line on 851, heading to Railroad.. Holy crap your STI is putting some power down..
To me, this emissions testing is nothing more than a stealth tax. Everything in PA was fine until some arsehat group sued the Commonwealth - I just made an appointment to get my girlfriend's 2003 Tiburon inspected, emissions tested, and oil change - the tab? $90.. That's ridiculous. A brand new car doesn't require a yearly $30 emissions test, or, for that matter, a yearly $20 safety inspection. It really makes me not so happy, to say the least..
Electric CEL Fix and OBDII Emissions Testing lbleiweiss Mid West Subaru Owners Club Forum -- MWSOC 9 11-29-2008 03:40 PM
Catless UP and DP and emissions testing in PA mgoss79 Mid Atlantic Impreza Club -- MAIC 13 02-12-2008 09:18 AM
Passing Mass OBDII Emissions Testing with UTEC scubyslacker New England Impreza Club Forum -- NESIC 7 04-05-2006 12:20 AM
Anyone with the ECU reflash pass OBDII emissions test? Camperguy Engine Management & Tuning 0 02-20-2003 10:50 AM
Anyone with a ECU reflash take the OBDII emissions test? Camperguy New England Impreza Club Forum -- NESIC 0 02-15-2003 09:49 AM
