Old 11-30-2003, 06:01 PM   #1
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Wink Cyl 4 misfire, no drivability concerns...
Kinda just putting this here for reference untill I figure it out..
98 RS
109,XXX
I get a cylinder 4 misfire, only on WOT pulls in 3rd gear to redline.
No drivablity concerns, stumble, buck hesitation.
I havent really looked into to much, other than changing the original wires and bosch plugs that were in the car when I got it, to subaru OEM wires/plugs.
I got the misfire before and after doing the plugs/wires.
Ill have to check the compression when I get a chance, and probably replace the coil for good measure...after all it does have over 109k on.
It seems like It started after I put the intake on...but I dont know, and im too lazy to put the stock stuff on to make a comparison
performance mods
jcsports intake w/pipecross filter
borla headers
stroumung midpipe
scoobysport back box
Jay
Old 11-30-2003, 10:50 PM   #2
Blindeye_03
Member#: 4418
2016 Focus ST
my rs has the SAME issue, but only @ WOT in 4th gear - not 3rd.
I replaced my plugs and wires and its still there (the flashing cel).
Im going to get stock plugwires and throw them on there (possibility)...but I heard a lightweight flywheel causes this too?
My coil pack had corrosion on #3 (closest to firewall on pass side), So I got aftermarket wires...Vitek wires.
Mods:
lw flywheel/clutch (exedy)
UDP
ganzflow intake
decat cat pipe/2.25" apexi n1 'catback'.
replaced plugs and wires @ 60k miles & now I am just over 66,500 miles.
-justin
Blindeye_03 is offline   Reply With Quote
Old 12-01-2003, 12:36 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I get misfires on all 4 cylinders, which I believe is attributable to my Fidanza flywheel. For whatever reason, cylinders 3 & 4 always trip first, so depending on how soon I hook up my PocketLogger sometimes I get just 3 & 4 and sometimes I get all 4.
I have horrible hesitation/bucking issues at low RPMs, sumthin' just isn't right. I'm not sure what to think, though, because once it hits about 4000rpm the timing all comes back and the car comes to life. Very strange.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-01-2003, 12:45 AM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
This is pretty common to have a terminal corroding... you might want to check/clean that as it's a pretty good canidate to causing a misfire.
Old 12-01-2003, 01:09 AM   #5
Blindeye_03
Member#: 4418
2016 Focus ST
When I saw the corrosion on the pack, I used sandpaper to take the white/green corrosion off, and got rid of the 'fouled' wire(s).
I am thinking that I cought the corrosion too late and it caused a failure inside the pack (intermittent problem).
Also, when I am idling, Ill rev the motor to 3000 or 4000 rpms, and once it drops back to idle, the car wants to stall ...I believe the exedy flywheel is 12-13lbs, making it heavier than the fidanza flywheel IIRC.
BTW Pat, Where did you get your pocket logger?
-justin
Old 12-01-2003, 03:38 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
jay i get them intermittently on cold start warm ups
Old 12-02-2003, 02:29 PM   #7
Pocon
Member#: 17479
1999 Impreza WRX
Silverthorn Metallic
My car sometimes starts on 3 cyl.
I haven't taken it to my mechanic. He points to the follwing:
1)Vaccum leak
2)Faulty coil/wires/plugs
On startups from standing still, let's say at a stop light, I hear a pop sound on the engine. A misfire no doubt. I don't get CELs though
Mods: CAI, Lightned pulley set, highflow exhaust and ECU tune + S-AFC.
Pocon is offline   Reply With Quote
Old 12-03-2003, 12:37 AM   #8
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
www.pocketlogger.com . I haven't visited the site in a while, don't know if it's still up. Pretty handy little tool, the only downside is that Subaru's apparently send pretty low data rate to the OBD2 port. I only get 6 samples/sec, so if I datalog the maximum 6 parameters I'm only sampling each parameter once per second. Not that great if one is trying to catch the cause of a momentary hesitation. Most of the Pocket Logger users seem to be DSM types, and I seem to recall reading that they see 18-20 samples/sec.
Pat
Old 12-03-2003, 02:38 PM   #9
Markcjr
Member#: 3973
1998 2.5RS mass hole
Arcadia Green
my 98 RS with 92000 miles on it is still misfiring on cyl. 4 as well, with no drivability issues. it pulls strong. replaced the coil pack , wires and plugs, and it still misfires. i saw blue sparks on the coil pack and wires as well, and they are both brand new. going to the dealer tomorrow to see what they have to say. but, as there are no drivability isssues, (doesn't hesitate etc.) is it bad to keep driving with the blinking CE light?
mark
Markcjr is offline   Reply With Quote
Old 03-28-2004, 02:47 PM   #10
kmin
Member#: 28968
1997 BG Outback Ltd
black riding on MR.
hmm, my '97 outback just threw me a CEL too - P0303 and P0304, 3rd and 4th cylinder misfire. The CEL was flashing intermittently last night for about 5-10min, but it's stayed on since then w/o flashing.
It hasn't affected drivability at all either... car feels normal... Any ideas? I cleared the CEL light at Autozone, but will the dealer still be able to read the problem via the OBDII port? I'm going to ask them to look at the coilpack, check for corrosion, any other ideas?
oh, and mods:
K&N filter
snorkusectomy
grounding kit
all of which have been on for thousands of miles with no problems...
kmin is offline   Reply With Quote
Old 03-28-2004, 03:30 PM   #11
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
All I can say with mine was it stopped when I didnt have the borla headers on.
as soon as put them back on, back came the misfire.
Jay
Old 03-28-2004, 10:48 PM   #12
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
My Legacy's been hitting an 0301, and I can get it to trip most of the time by going WOT in 4th, around 75 mph. The coil terminal is nice and clean. 53k mi.
I've got a COBB CAI and NGK Iridium plugs. The CEL was happening before the plugs, and was my inspiration to change them out in the first place.
I see mention of the flywheel... mine is stock, but my clutch is starting to slip some, and will undoubtedly need replacing soon. Any possible connection?
LetItSnow is offline   Reply With Quote
stumped by cyl 4 misfire. KurtP Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-02-2010 08:55 PM
HELP!! Cyl. 4 Misfire...? SubieStylez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 04-16-2007 03:38 PM
Cyl 4 misfire simpreza2 Normally Aspirated Powertrain 3 03-18-2005 12:48 AM
CEL P0304 - cyl 4 misfire, want people's thoughts edkwon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-19-2004 04:44 PM
Cyl 4 misfire only with borla headers munkis Normally Aspirated Powertrain 9 02-17-2004 11:10 PM
