Old 11-30-2003, 07:00 PM   #1
Mike4kz
Member#: 47324
Default O2 Sensor readings
Hi everybody,
I have Subaru OB '97 with about 115K. I have never replaced Oxygen sensors and I'm wondered if I should just do it.
I'm having a pretty low MPG (~200-210 miles per 12 galons) for mixed city/highway driving. With "only highway" driving I'm getting 230-240 miles for 12 galons (i.e. 20MPG maximum).
Recently I have bought CarChip to check ECU readings and this is what I found:
1. From time to time I have 0.0V readings on the O2(B1,S1) sensor. It's not for long, sometimes for 10-15 seconds, but it's below 0.1V. I read in some technical manuals that you should never get readings below 0.1V on Oxygen Sensors.
2. My sensor never gives me readings above 0.8 Volt. And I'm getting 0.8V readings pretty rear. Most the time it's 0.1-0.6 which tells me my engine runs leaner it should be most of the time.
I read quite a few articles which say that for all cars from '96 and newer it's recomended to replace O2 sensors every 100K even without warning light from the computer. They tell that sensors may just become "weaker", but not enough to tell to ECU that it's "completely bad".
Any experience / thougths on this case?
Regards to everybody...
Mike4kz is offline   Reply With Quote
Old 11-30-2003, 08:42 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
it would probably help to replace the o2 sensor on your car.
You can get generic ones and splice them into your harness @ www.oxygensensors.com
as for the readings, they should bounce around a bit, and usually under full throttle acceleration is one of the few times you'll get a constant reading.
Legacy777 is offline   Reply With Quote
UTEC Q: does UTEC intercept stock O2 sensor readings? happasaiyan Engine Management & Tuning 6 12-10-2004 12:29 PM
o2 sensor reading? DangeRS Normally Aspirated Powertrain 14 04-15-2003 01:30 AM
Translating the O2 Sensor Readings TurboRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 12-03-2001 05:37 PM
Stock MY98 EGT and O2 sensor readings! R Diamond Technical Forum Archive 8 09-10-2000 11:56 AM
O2 sensor readings for MY99s efoo Technical Forum Archive 3 07-25-2000 07:05 AM
