Old 12-01-2003, 10:32 AM   #1
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
Default help, undriveable! problem solved...
My 2.5 is giving me headaches these days. before the weekend, it started jerking when driving at steady speeds. then now it does that whenener there's no real load. if i'm flooring it, it will accelerate normally, but as soon as it get near from steady speed. it will jerk. if I push the clutch when it's jerking. it will stall for sure. it seem to be very rich. I changed the 02 sensor. nothing happened. I unplugged the TPS, nothing happened. disabled the fuel pressure regulator near the engine (still using the one near the tank), nothing happened. Fried ECU ? please help !
NicEJ25 is offline   Reply With Quote
Old 12-01-2003, 01:39 PM   #2
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I've read that this can sometimes be a temp. sensor. Basically the ECU thinks the car is cold and pumps too much fuel into the system.
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
Old 12-01-2003, 01:57 PM   #3
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
are you talking about too much fuel (rich) or way too much fuel (drowning to death) ??
where is located the engine temperature sensor ?
Old 12-01-2003, 06:03 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
spark plug wires
Old 12-01-2003, 06:17 PM   #5
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
I am 99.9% sure it is your first O2 sensor. Try unplugging it and see if the car behaves any better. I say this from experience. The RS uses the first O2 sensor for partial throttle closed loop operations. When it goes open loop near full throttle it does not use that sensor anymore.
scoobiejosh is offline   Reply With Quote
Old 12-01-2003, 07:31 PM   #6
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
the new one is there actually. and it did not changed anything. even unplugged, i would not change a thing. when the car is cold, it's ok (temp around freezing point here). after a minute or do, it will start jerking, wich make me think the temp sensor is the next thing to check.
Old 12-01-2003, 08:45 PM   #7
Keith Cournoyer
Member#: 16764
Default ndrivability
Hey, just a thought, my car drove behaved similar with a malfunctioning knock sensor and 2nd O2 sensor shot. Are you pulling CEL codes?
Good Luck, Keith
Keith Cournoyer is offline   Reply With Quote
Old 12-01-2003, 11:26 PM   #8
Ahzlon
Member#: 45216
2005 Baja Turbo
well i realize this was on an older bronco.. but my coolent temp sensor made my 351W go abloslutely bannanas... high revs.. herky jerky acceleration.. try replacing that.. usualy a really cheap fix.. and the computer would never throw a CEL either.. and my gas milage went to crap too.. might wanna check that
Ahzlon is offline   Reply With Quote
Old 12-02-2003, 11:59 AM   #9
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
I hope i'll find time and help to install my OBD2 plug this week-end. then i'll read the code.
Old 12-08-2003, 03:58 PM   #10
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
I didn't had time to wire my OBD2 plug yet, but I found the problem. Since I've changed rear fuel lines for hose (because of leaking rusted lines), my car was going bad. well, it was since I changed the last small return line. in fact. MY01 fuel pump cover have 3 hoses connector. MY93 had only 2. I assumed there was a Y to join both return line. I was damn wrong. In fact, the MY93 tank small return line connector is somewhere in the middle, unreacheable from both opening. So, this morning, in the last attemp to make my car run well, I put a Y on the small return line under the round opening, and connected the small return line to both old tank connector, and MY01 fuel pump cover connector. Then, no jerk, no stalling, nothing bad. In fact, in jerked once. I make my discover my tank was empty (my guage isn't working yet). so, if you have a leak in your tank, or a restricted return, you're most likely to get jerk, stall, and impressive 175 km out of a 50L tank. 25L per 100 km, or 8 mpg...
Need Turbo Help!!!!!! 07subywrxtr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-05-2010 03:52 AM
HELP HELP HELP Need help diagnosing a clutch problem.... redoktober_99 Tri-State Area Forum 9 02-06-2007 10:28 PM
Help Help Help Help Diehard Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 11-08-2006 03:42 PM
idle hesitation, undriveable 20g 05 lgt wichitalegacy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 09-29-2006 08:44 PM
light weight/undrive pullies,do they work??? subrandon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-15-2004 03:54 PM
