Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 12-01-2003, 02:36 PM   #1
RedP1
Member#: 44967
Default closing the deck
Check this site out. www.cgperformance.com
The guy closes the deck on USDM NA EJ25 adds forged parts in internal and can build crazy high HP turbo charged EJ25's.
RedP1 is offline   Reply With Quote
Old 12-01-2003, 03:13 PM   #2
QuickDrive
Member#: 1126
91 Legacy Turbo
Grey
Very Interesting,
I never knew the difference until now...
Luckily I own an already closed deck EJ22T and have a spare one just in case
QuickDrive is offline   Reply With Quote
Old 12-01-2003, 06:17 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Cobb's been doing that for years. That's what a stage III Cobb bottom end is...Same thing you find in Conebasher.
Old 12-01-2003, 07:02 PM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
there are a few guys that do this.
subiekid is offline   Reply With Quote
Old 12-31-2003, 05:51 AM   #5
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
even longer with the Honda people
mattjk is offline   Reply With Quote
Old 01-13-2004, 05:44 PM   #6
morgie
Member#: 3836
2002 Impreza WRX
you could also use semi-closed deck setup
morgie is offline   Reply With Quote
Old 01-13-2004, 09:53 PM   #7
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
How much psi can you run on a ej25 with a closed deck, new pistons, and rods?
NeaD is offline   Reply With Quote
Old 01-14-2004, 09:23 PM   #8
morgie
Member#: 3836
2002 Impreza WRX
probably a lot if you get good tuning and fueling and a big turbo
Speed cost money, how fast you want to go ?
Old 01-14-2004, 09:28 PM   #9
NeaD
Member#: 43371
Hydra User, Blue
I was just doing research.
Old 01-15-2004, 03:08 PM   #10
Matt Monson
Member#: 832
99 2.5RS, '85 911
http://cobbtuning.com/impreza/engineblock3.html
On a Cobb block they claim 2 bar (30psi) boost making more than 600hp...
Old 01-22-2004, 11:18 PM   #11
kaos200
Member#: 2692
they say 30, because its resleeved. Closed deck and resleeving are two different things. Do both, and man, talk about bullet proof
kaos200 is offline   Reply With Quote
Old 01-23-2004, 10:08 AM   #12
NeaD
Member#: 43371
Hydra User, Blue
thats what i like to hear.
Old 02-11-2004, 11:54 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If sleeving and closed deck makes it bulletproof, then many of us already have bulletproof blocks.
The EJ22T is fully closed deck and has sleeves cast into the block (not machined and slid in). Its stronger than these aftermarket 2.5l built blocks.
Drift_King: Where you being funny or serious?
Old 02-12-2004, 10:11 AM   #14
legacy92ej22t
Member#: 42659
92 Legacy turbo5mt
All go and no show...
I hope he was trying to be funny, because if not...well, you know.
legacy92ej22t is offline   Reply With Quote
Old 02-12-2004, 08:51 PM   #15
kaos200
Member#: 2692
Originally posted by Drift_King
bnullet proof ha
closed deck is a gimik notin more nothi less
ps and its for loserz
for someone who says "closed deck is for loserZ" how do you take them seriously?
Old 02-12-2004, 08:52 PM   #16
kaos200
Member#: 2692
by sleeving I mean aftermarket thick cast Iron sleeves. Not the thinner oem units.
Old 02-12-2004, 09:53 PM   #17
ciper
Member#: 15543
90BJ Legacy LS ABS
kaos200: Its common for people to speak worse than that online, why wouldnt I?
"aftermarket thick cast Iron sleeves. Not the thinner oem units."
That are still machined/pressed into the block after the fact. Other engines have them press fit. The EJ22T are cast directly into the block. You should check the thickness of the EJ22T sleaves, I swear it was 6mm. I was this close to sleaving my block when I found they would be weaker in some ways to the stock units (like the ability to twist and warp).
Old 02-13-2004, 12:24 AM   #18
kaos200
Member#: 2692
if they really are that thick and its not the iron AND ally part thats 6mm, then thats great
Old 02-14-2004, 01:52 AM   #19
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
The ej22s have the thickest liners... but a good solid liner like axis or ispeed uses will hold better. I dont think anyone has ever ovaled a ej22, I think you would blow a head gasket off before that, so its a silly point to bicker over....
The ej257 has one of the thinest liners of any subaru motor...
Old 02-14-2004, 10:05 PM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
personally I am not worried about the sleeve slipping. I plan on overboring my EJ22 having it resleeved. As long as it is done by someone who knows how to build a race engine there shouldn't be any issue in my mind...
Old 02-15-2004, 01:16 AM   #21
totoherbs
Member#: 7321
.... 122 IggPoints
Have you found a place yet?
Old 02-29-2004, 12:40 AM   #22
slingshot
Member#: 44668
'07 M5
Originally posted by QuickDrive
Very Interesting,
Me neither. Learn somethin new everyday.
slingshot is offline   Reply With Quote
Old 03-22-2004, 07:59 PM   #23
neversatisfied
Member#: 42631
03 Subaru WRX
Silver T67 equipped
Great info. The EJ22T gets more appealing the more I read about it.
neversatisfied is offline   Reply With Quote
Old 03-23-2004, 08:47 AM   #24
totoherbs
Member#: 7321
.... 122 IggPoints
http://forums.nasioc.com/forums/show...highlight=ej22
Old 03-25-2004, 04:30 PM   #25
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
For even more info, read this.
IronMonkeyL255 is offline   Reply With Quote
Is the FXT sub powered from the deck? swingkid Forester Forum 20 03-13-2004 01:42 AM
Anybody close their deck themselves? kenshiro Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 09-22-2003 05:43 PM
To fill up the space after installing the deck psaeko Car Audio, Video & Security 5 07-27-2002 10:17 PM
Closing/Semi-Closing the deck Imprezer Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-12-2002 02:38 PM
Closing the deck.... EJ25 Normally Aspirated Powertrain 20 10-30-2001 09:41 AM
