Old 12-01-2003, 05:32 PM   #1
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Subaru Stars Won't rev over 4100RPM - HELP!
Okay, 1995 Impreza L AWD Coupe with a 2.2L engine in it and a 5 speed manual tranny. When I got this car in April, it would rev up to the limit (6K rpm? i think) and now it won't. It only revs up to 4100RPM. I've tried to replace the O2 sensor, the MAF sensor and neither have worked. Could it be the TPS (ummm...hey Peter, I'm gonna need you to check out that Throttle Positioning Sensor)???
I'm stumped and would appreciate any help provided.
only modification is a cat-back stock WRX exhaust.
thanks
//marcus
marcus12 is offline   Reply With Quote
Old 12-01-2003, 05:38 PM   #2
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
if you have CEL, get the code pulled, it will pinpoint the problem.
vehicle speed sensor failure is most likely to indroduce Fail-safe mode (engike cutting at 4K)
NicEJ25 is offline   Reply With Quote
Old 12-01-2003, 05:41 PM   #3
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
so my ecu's in Limp Home mode?
Old 12-01-2003, 06:00 PM   #4
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
theyre's no way the engine would cut steadily around 4K rpm other than the "whatever called" ecu safety mode
Old 12-01-2003, 06:33 PM   #5
scoobiejosh
Member#: 3139
2001 Dodge Pikumup
& 08 Triumph Speed Triple
Agreed, If your car has a Check Engine Light and you can get the code and description it will help. It definitely does sound like a limp mode. I have see it happen when the car looses the speed sensor signal for example.
scoobiejosh is offline   Reply With Quote
Old 12-02-2003, 02:26 PM   #6
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
gotcha...the code is 23 - which when referring to the Chilton's manual, it's the MAF sensor. But I JUST replaced that...
Is there a way to reset the ECU?
Old 12-02-2003, 02:35 PM   #7
NicEJ25
Member#: 26155
2008 WRX 5dr
Dark Grey
unhook the negative pole of the batt. press the brake pedal a few second, a few times, wait 15 min. rehook the batt
Old 12-02-2003, 02:42 PM   #8
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
cool...I'll go out and do that right meow...
Old 12-02-2003, 03:00 PM   #9
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
nada...maybe I need to *dum dum dum* take it to a dealer???
after new year when I have $$$
Old 12-02-2003, 10:36 PM   #10
Evan_Ng
Member#: 45548
2004 Impreza
SIlver
what is the point of pressing on the brake pedal when you're resetting your ECU?
does it do anything
thanks
Evan_Ng is offline   Reply With Quote
Old 12-02-2003, 11:44 PM   #11
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Maybe nothing - but some cars may have some 'capacitance' in the system that stores the 12V and only discharges slowly. Cuts having to wait like an hour or something. YMMV
Carl
1 Lucky Texan
1 Lucky Texan is offline   Reply With Quote
Old 12-02-2003, 11:46 PM   #12
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I know you mentioned the exhaust as the only mod - but do you also by chance have an Amsoil or K&N type filter?
Old 12-03-2003, 11:40 AM   #13
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
I HAD a K&N CAI filter, but I removed it recently...
Old 12-03-2003, 02:57 PM   #14
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
They have a rep for killing MAFs. The oil gets on it and corrodes, interferes with it. Try cleaning the MAF with some brake cleaner , reset the ECU, or you may need ANOTHER one.
Carl
1 Lucky Texan
Old 12-03-2003, 05:59 PM   #15
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
brake cleaner, huh? I'll give that a shot. I'm still unsure as to how to reset my ECU...I tried what was suggested (disconnect neg battery, pump brake, etc...) but should I just wait a while longer than 15 mins?
Old 12-03-2003, 09:15 PM   #16
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
I'm no expert here but if you lost you radio presets or your trip odometer it probably reset the ECU. Doesn't hurt it let is sit overnite if its convenient. Also, may take a few tankfuls of gas to 're-learn' the car and your driving style. Good idea to do after any mod or repair I guess.
Carl
1 Lucky Texan
07 sti won't rev over 2500rpm k_duraman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 11-06-2009 06:28 PM
Finished Swap, Motor won't turn over. Please help :) snowcrzy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 07-23-2007 08:59 PM
95 Impreza L w/ 2.2L engine won't rev over 4100 RPMs - any thoughts? marcus12 Normally Aspirated Powertrain 12 11-17-2004 02:07 PM
P1544 and motor won't rev over 2K rpm? KJR Engine Management & Tuning 4 09-17-2004 11:50 AM
Book leak, won't get over 18psi. Help! KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-04-2003 07:47 PM
