Welcome to the North American Subaru Impreza Owners Club Sunday October 23, 2016
Old 12-01-2003, 07:03 PM   #1
Turbo Tin Can
Member#: 18383
Default Using a usdm ej20 block with jdm ej20 bottom end, whats the block diffrence with sti
Ive got a good deal on some jdm sti parts, crank, bearings, rods, pistons basically the whole bottom end cause the block was dropped and split. I want to use these parts to rebuild my busted ass usdm ej20. What are the major block differences between a 2002 wrx block and an sti block? The deck is different but is that it? Little help
I also have the option of using a jdm wrx engine with avcs instead, but i need to buy an ecu to control the stupid avcs Thoughts?
Turbo Tin Can is offline   Reply With Quote
Old 12-01-2003, 11:23 PM   #2
Axis Power Racing
Member#: 30860
If the pistons are the right letter code, everything will be a drop in. Just make sure to use new correct bearings, don't reuse the old ones no matter how slightly used.
Axis Power Racing is offline   Reply With Quote
Old 12-02-2003, 03:13 AM   #3
Member#: 14970
1997 GF8
for some pictures and a small wite-up go to www.wrxworld.com and look around.
SJwrx is offline   Reply With Quote
Calling all EJ257 (04-05) STi owners with a built bottom end bugeyesubie Built Motor Discussion 9 09-11-2008 12:37 PM
03 USDM EJ20 -> 97 JDM EJ20 swap marksWRX03 Subaru Conversions 10 06-09-2004 08:13 AM
Whats the diff? UK spec STi wheels vs. JDM spec STi wheels FutureWagon Brakes, Steering & Suspension 13 09-10-2002 06:52 PM
Super AFC into 1.8 ecm with jdm ej20 motor aigburth Normally Aspirated with bolt-on Forced Induction Powertrain 0 05-11-2002 04:44 PM
ive read and searched, whats the MAIN diffrence in chips? DangeRS Normally Aspirated Powertrain 2 02-25-2002 04:14 PM
