Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 12-01-2003, 11:44 PM   #1
AndyM
Member#: 3219
2004 Impreza WRX STi
WR Blue Pearl
Default P0301, P0302, PO130...Please help/look
Hey guys well got my first major CE light.
PO301 Cylinder Misfire # 1
PO302 Cylinder Misfire # 2
PO130 02 Sensor Circuit Bank One Sensor One
Have an Injen Intake, Stromung high flow cat, and cat back, magnaflow muffler. I noticed my car is hesitating between 2,000, 4,000 RPM.
What do you think it could be?
Bad gas?...I did fill my car up with the normal 93 on Saturday. I drove my car for the first time today since I filled it up.
I did throw the front 02 sensor code.
It could be that the front 02 sensor is bad and it making cylinder 1 and 2 misfire.
Could my highflow cat be messing things up?
Just would like some info and some help thanks
Andy
AndyM is offline   Reply With Quote
Old 12-02-2003, 12:47 AM   #2
AndyM
Member#: 3219
WR Blue Pearl
I think I might have found the problem already:
The whole left side (from your view) is corrorded, I cleaned it up and the wires hope that will be the end of it, wont know till tomorrow morning
Old 12-02-2003, 01:46 AM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
glob some dielectric grease on them puppies and they should stay clean for a while. Good catch.
Tim Sanderson is offline   Reply With Quote
Old 12-02-2003, 09:31 AM   #4
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
AndyM,
You should change the stock wires... just plain junk.... subaru uses the blue NGK wires.... as replacement.
Robin
Robin2 is offline   Reply With Quote
Old 12-02-2003, 11:26 AM   #5
AndyM
Member#: 3219
WR Blue Pearl
Well cleaned up the coil, and connectors. I also noticed corriosion inside the sparkplug wire. I used a small rag, and a very small brush and cleaned/brushed corrosion off. Drove it to school today and so far so good, runs better and hesatation is now gone. Cleared CE Light before the drive and it hasnt come on.
Dielectric grease is a great idae, I didnt think of that. I should get some new wires, maybe for Christmas....ha ha.
Old 12-03-2003, 01:05 AM   #6
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
if you can't find NGK's around, Beck/Arnley make a pretty good stock replacement, blue w/ Mg. cores
Cujo31 is offline   Reply With Quote
Old 12-04-2003, 02:19 PM   #7
AndyM
Member#: 3219
WR Blue Pearl
crapola, I did put grease on the coil car was ok yesterday, but notice some hesatation again and the CE light came on. Pulled the code and its PO130 02 sensor bank 1 sensor 1. It looks like the 02 sensor needs to be replaced. No other codes were thrown just the 02 sensor.
Old 12-04-2003, 03:40 PM   #8
aliengti
Member#: 30639
'01 Silver RS Coupe
Hey I notice you have a very clean engine. What product do you use to wipe it down in order to keep it clean?
aliengti is offline   Reply With Quote
Old 12-05-2003, 10:49 AM   #9
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
I sir, after months of this exact problem (yep, right down to the corroded coil pack leads, and low rpm hesitation) can guarentee you it is the front O2 sensor. Beleve me... I know... I spent several hundred dollars to find out.... replaced:
plugs
wires
fuel filter
Idle air control valve (hella expensive)
coilpack
and finally the o2 sensor.
Make sure you get the ECU re-program for the dealership, as the ECU is what is causing all these o2 sensors to fail in the first place.
Out of warranty? : them: $200+ you: $80, 20 minutes of your time.
My car threw every code in the book EXCEPT the o2. be happy that yours is so obvious.
ChosenWon is offline   Reply With Quote
Old 12-05-2003, 10:55 AM   #10
m750
Member#: 2278
8Sti | 07 allez
White | Comp
plugs
wires
fuel filter
coilpack
I could have sworn you were going to start spouting off about running low on gas killing his 02...
m750 is offline   Reply With Quote
Old 12-05-2003, 01:38 PM   #11
AndyM
Member#: 3219
WR Blue Pearl
thanks guys for your advise
Chosenwon thanks man really. I figured it was the front 02. After having the car for almost 3 years it was only a matter of time before the front 02 went out after reading tons and tons of threads regarding the 02 sensor going bad so early.
Thanks again I have about 2 months of warranty but my exhasut is all aftermaret. So Im not going to even try to get it covered. As for the recall for sure I gotta do that. I got the letter just never got it in, because I hate going to the dealership.
Old 12-05-2003, 02:36 PM   #12
ChosenWon
Member#: 2236
2000 Audi S4
No problem glad to help. BTW they make a specialized tool to help change out hte o2. I found this out AFTER I did it the old fasioned way. I did mine form the top down vs most people doing it form underneath. If you have any questions on getting it changed out, let me know, although it sounds like you know what you're doing anyway.
It does I tell you!!! I think low gass is the straw the breaks the camels back.
WTB: Please help! Looking for Cbr 1000rr White with carbon fiber shadymilkman129 Private 'Wanted' Classifieds 4 06-23-2008 01:52 PM
PLEASE HELP! Looking for a particular STi pic - for a billboard!!! subarusales STi Forum Archive 6 03-12-2003 12:57 PM
Please Help---Looking for a RS. sandy lam Vancouver Impreza Club Forum -- VIC 35 10-15-2001 05:23 AM
please help looking for used turbo kit coolguy Vancouver Impreza Club Forum -- VIC 3 04-29-2001 01:59 AM
urgent please help, looking for part Delicious Tuning Bay Area Impreza Club Forum -- BAIC 6 03-22-2001 01:50 AM
