Old 12-02-2003, 10:46 AM   #1
ScobyWRX
Member#: 49690
2006 WRX limited
Gray
Subaru Stars rear swaybar end links
has anyone broke their factory endlinks with Perrn or cusco rear swaybars ??
ScobyWRX is offline   Reply With Quote
Old 12-02-2003, 10:59 AM   #2
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
i can't answer that for you, but I will tell you the endlinks are a very nice upgrade. I had them on before I installed my swaybar, and the difference vs. the stock links was definately noticeable.
If you can afford it, I recommend them.
eyeballs is offline   Reply With Quote
Old 12-02-2003, 11:09 AM   #3
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
i had my whiteline bar on before the endlinks... it worked fine...
but eyeballs is right... adding the endlink did make a difference.
good luck
SD
suby_dude is offline   Reply With Quote
Old 12-02-2003, 11:11 AM   #4
Rich10
Member#: 14934
I asked this question a while back. The consensus seems to be that they don't typically break but an aftermarket rear end link will give better steering feel.
http://forums.nasioc.com/forums/show...hreadid=413083
Rich10 is offline   Reply With Quote
Old 12-03-2003, 10:53 PM   #5
subiefan
Member#: 17553
2004 STi
Default What about Whiteline endlinks??
I drove into my driveway this evening and heard a big "THUNK" like I had just run over a huge rock or something. So I get out and take a look. . . sure enough, no rock. But then, I took a closer look at the rear swaybar to find that my left Whiteline HD endlink had snapped in two.
BTW I've been running Prodrive springs, Whiteline F&R swaybars with the rear running full stiff. I was a little annoyed at first but I have almost two dozen track days on that set-up so I guess something was bound to break. Perhaps it was the combination of the track days and the recent cold weather.
Does anyone else think that the endlink failure was a little premature?
Jon
subiefan is offline   Reply With Quote
Old 12-03-2003, 11:00 PM   #6
Moondongle
Member#: 39552
2003 WRX Wagon
Check out this thead on endlink discussions. There's some great information on the stresses that endlinks typically experience. Jim from Whiteline admits they had some issues with their endlink material for the wire links. I don't know if you have the new aluminum ones or the old wire ones. Anyway... you can find out from Whiteline directly to see what they say.
http://forums.nasioc.com/forums/show...k&pagenumber=3
Moondongle is offline   Reply With Quote
Old 12-04-2003, 02:15 AM   #7
subiefan
Member#: 17553
2004 STi
Moondongle: Thanks for the link. Very interesting reading. I do indeed have the wire endlinks. I will be contacting Whiteline in the morning.
ScobyWRX: Sorry, I didn't mean to hijack your post but I thought your actual choice of endlinks would be pertinent to your post. It looks like the aluminum endlinks are going to be the way to go. After my experience I wouldn't recommend the wire type Whitelines. After all, I was only pulling into my driveway, at about 5 mph.
Jon
Old 12-04-2003, 05:09 AM   #8
Moondongle
Member#: 39552
2003 WRX Wagon
Good luck getting things resolved. I have Perrin links myself, but the RSB walked and I cobbed a bar lock together. I did see an interesting set with a bushing setup on one end and a spherical bearing on the other. Maybe the best solution. I can't remember if it's Poltec or Noltec. If I find them again, I'll post it.
Old 12-04-2003, 05:12 AM   #9
Moondongle
Member#: 39552
2003 WRX Wagon
Old 12-04-2003, 08:10 PM   #10
oxtox
Member#: 33740
2012 sti hatch
wrb
i've been happy with kartboy links...you may want to check them out...serious improved stearing vs. stock links.
oxtox is offline   Reply With Quote
Old 12-04-2003, 09:49 PM   #11
Eggas
Member#: 43214
2003 Stage should
have bought a house
It is those damned Spokane roads that broke your end-link.. I was up there for turkey day and my god those things are ass.
Eggas is offline   Reply With Quote
Old 12-04-2003, 10:48 PM   #12
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Jon
Whiteline offers an upgrade deal for wire endlink owners. You provide proof that you own the wire ones(I took a couple pic's of mine installed and email'd 'em) and they will sell you the new ones(KLC26) for a nice price. Contact them and see about it.
I just got mine for ~$US75 shipped.
HTH
Old 12-06-2003, 02:47 AM   #13
subiefan
Member#: 17553
2004 STi
Wow, thanks Scotty. That's good to know. Unfortunately, I've already got a set of Kartboy links coming to me in the mail. I think I'll just send Whiteline my busted wire link and see if they'll send me some solid links that I can sell or something.
Yeah, Eggas the roads here are pretty crappy. Damned studded tires!! If you don't pay attention when driving on the interstate you can get bounced to a different lane pretty quickly because of the ruts.
06 WRX STi FRONT and REAR swaybars+end links MatyCross Suspension/Brakes/Handling 3 03-30-2009 09:46 AM
Wanted: Stock STI rear swaybar end-links. AZRally SWIC Private Classifieds 1 03-08-2007 04:53 PM
FS OR: Perrin PSRS and Rear Swaybar/end links Gixxerjb Suspension/Brakes/Handling 1 03-08-2007 01:22 PM
Hotchkis rear swaybar end links Eaglesfan2422 Private 'Wanted' Classifieds 2 01-30-2004 12:59 PM
Whiteline Swaybar End Links Steve E Technical Forum Archive 7 10-11-2000 10:30 AM
Message Board Statistics All times are GMT -4. The time now is 10:50 PM.
