Old 12-02-2003, 02:59 PM   #1
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
Default Kartboy shifter slop?
First, I love my KartBoy shifter, and I've heard nothing but good things about their products. I'm just concerned about how mine feels, and wondering if it's normal or not.
I've got an 00RS with a Kartboy short shifter in there, and also the bushing. It feels fine, but sometimes, going from second to third, it sorta "hangs up" somewhere and doesn't slip right into the gate for 3rd, like it's getting caught in the guts between 1st and 3rd by 1/4 of an inch or something. That, and it feels a little "loose" at the shifter.
My car has 70k on it, 30 of which are mine, and I don't drop the clutch or speedshift, ever, since I've heard that our tranny's are a bit sensitive. Here's what I'm wondering...is there anything in there that's adjustable, or subject to getting loose? I thought the bushing would solve this, but honestly I can't notice any difference at all, and I'm even wondering if the very reputable Suby dealer that installed it even put it in, or if they just, um, lost it and charged me anyway.
Any thoughts appreciated.
subarucyclist is offline   Reply With Quote
Old 12-02-2003, 03:12 PM   #2
Defiantguy
Member#: 41268
2015 WRX
most kartboy shifters are sloppy. As for it not going into 2nd to 3rd the bolt on the shifter might be a little tight. Also, you paid a dealer to isntall a short shifter!?!?! Well its very easy to get access to the shifter. I'll use the scoobymods walkthrough:
http://www.scoobymods.com/forums/sho...?s=&threadid=4
Just make sure the nut isn't too tight and that might fix your problem. As for the looseness, kartboy shifters are like that. Mine is that way as well.
Defiantguy is offline   Reply With Quote
Old 12-02-2003, 04:22 PM   #3
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
No, I didn't pay the dealer to install the shifter! It was installed when I got the car. I'd have done the bushings myself, but I don't have a place to jack the car up where I live.
Thanks for the info, I'll take a look at the bolt and see if it's too tight, though I was actually thinking that tightening it up might take some slop out. From what you were saying, it sounds like that wouldn't work so well.
S
Old 12-02-2003, 04:30 PM   #4
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Just to clear things up, its not that the kartboy shifter is responsible for any looseness. The shifter is a metal bar. It attaches to the factory linkage that has a bit of "slop" to it. This is greatly improved by the hardened shifter bushings. You can look for yourself to see if the bushing was installed, its pretty obvious visually. Check the level of your tranny fluid, if its a low it could affect your shifting between gears. As for getting all the slop out of the shifting linkage, the STi short shifter kit includes linkage that may handle this for you. Its a bit more spendy than the good ol kartboy shifter though.
nunyo is offline   Reply With Quote
Old 12-02-2003, 09:42 PM   #5
Defiantguy
Member#: 41268
2015 WRX
the shifter bushings doesn't help much with the slop, its in the shifter linkage itself. The shifter bushings just make the shift engagement more firm.
Old 12-03-2003, 10:13 AM   #6
smacksube
Member#: 4067
01 2.5 rs
how can the linkage be sloppy...it's a metal bar. metal bars are usually stiff and rigid....
smacksube is offline   Reply With Quote
Old 12-03-2003, 11:55 AM   #7
m750
Member#: 2278
8Sti | 07 allez
White | Comp
linkages are bars w/ bushings and pivot points, if the bushings are worn, soft, or loose, that can cause slop.
m750 is offline   Reply With Quote
Shifter slop FNR32 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-21-2006 02:38 PM
shifter slop anothermbdusted Transmission (AT/MT) & Driveline 7 03-25-2006 09:27 PM
04-05 STi owners - Fix your shifter slop! Turn in Concepts Drivetrain 14 03-06-2006 07:35 PM
Shifter Slop in a 97 2.5 GT revhigh96 Legacy Forum 11 11-08-2005 12:11 PM
shifter slop austenf740 Transmission (AT/MT) & Driveline 17 04-22-2005 12:35 PM
