Old 12-02-2003, 09:15 PM   #1
Discjoshie
Member#: 43717
2000 2.5 RS
Default ECU Reset: Which way is correct?
I have read a lot of different ways to reset the 2.5RS (2000) ECU. One of which was as simple as unhooking the negative battery terminal, waiting, replugging and idling. Another at http://www.mrtrally.com.au/performance/ (under "ECU's Info." and the Handy tip for resetting) says to plug some "ECU check" plugs together that are under the steering column (they do exist) and driving for a little while, etc.
Which method is the correct one to reset the ECU? Is there only one? If so, which is best/fastest for adjusting to new power mods?
Thanks,
Josh
Discjoshie is offline   Reply With Quote
Old 12-02-2003, 09:26 PM   #2
joubtt
Member#: 33901
04 04 STI
No AWD, Not interested
There is a note to step on the brakes to drain the last bit of power. Add this to the rest.
joubtt is offline   Reply With Quote
Old 12-03-2003, 09:51 AM   #3
WAFlowers
Member#: 23337
1997 Legacy GT Sedan
When I installed a Weapon-R intake on Thanksgiving I pulled the negative battery terminal, stepped on the brake peddle a few times and let is sit while doing some other work. When I hooked everything up again I not only had to reset the clock and radio stations but the car accelerated like a pig. An overweight pig at that.
But within days it had figured out that it could breathe and is running very nicely now. The off-the-line hesitation I'd always had is gone!
WAFlowers is offline   Reply With Quote
Old 12-03-2003, 10:49 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
lol well those stations arent stored on flashram and the clock doesnt have battery backup
Old 12-03-2003, 08:21 PM   #5
my2000rs
Member#: 20218
00 impreza rs
both methods is correct about resetting. but the easy way is to unplug neg, step on brake, plug back the terminal, start engine, let it idle w/out touching gas about 5 min, turn off car, start it again and drive like crazy so the ecu can relearn again....i use it all the time with my 2000rs
my2000rs is offline   Reply With Quote
Old 12-04-2003, 03:57 PM   #6
Discjoshie
Member#: 43717
2000 2.5 RS
Thanks guys. I guess if both methods will do the same thing just as fast and effectively, then I will just do the easier one with the negative battery terminal. Thanks again!
Old 12-06-2003, 05:02 PM   #7
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
This is the best method, but I usually will leave it unplugged for over 3 hours is all, just to be sure.
ImprezaRS dot com is offline   Reply With Quote
Old 12-09-2003, 06:22 AM   #8
alfcanada
Member#: 41909
Default help
does this method work with the new MY03 model? (after bugeye)
alfcanada is offline   Reply With Quote
Old 12-09-2003, 12:29 PM   #9
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
How often to you guys reset your ECU's?
I know you're supposed to do it after installing any mod, but it seems like I've heard that our cars "learn" to kinda detune themselves, or something like that, and resetting the ECU occasionally will make 'em run better, if only for a little while.
Is this something you do often, and if so, how often?
subarucyclist is offline   Reply With Quote
Old 12-10-2003, 12:18 AM   #10
ImprezaRS dot com
over boosted again
Member#: 1458
With a torque chip or powerchip in a normallly aspirated subaru, you don't need to keep resetting the ECU to gain power.
When I turbo'd and had a chip, the only time I would need to reset the ECU was when I would get a check engine light for "catalyst efficiency below threshhold" which initially was caused by too high fuel pressure, and later caused by running without cats. I would reset to clear the light.
Old 12-10-2003, 11:58 AM   #11
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
Thanks for the info, but what if you don't have an aftermarket chip or anything?
Old 12-12-2003, 12:50 AM   #12
ImprezaRS dot com
over boosted again
Member#: 1458
Well,
Interesting question. If you are often a mild driver, and want to keep max power for times you need it, you will find that resetting the ECU all the time will kill your gas mileage.
I would seriously consider a torquechip or powerchip someday soon - you will appreciate the thing, especially with a few mods.
Multiple boost gauges.. which one is correct? AlxSti Newbies & FAQs 3 05-14-2008 12:54 PM
Which Splitter is correct? brandon_bxtr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-30-2005 03:33 PM
first tire rotation, which way is best nySulli Tire & Wheel 5 09-26-2003 01:39 AM
brain fart- turning abc on utec which way is more/less boost M32WRXin3seconds Engine Management & Tuning 3 09-19-2003 12:04 AM
Which way is better to get rid of understeer? LiquidForce Brakes, Steering & Suspension 23 09-19-2002 01:03 AM
