Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 12-02-2003, 10:54 PM   #1
WRXTuner
Vendor
Vendor Sales Rating: (0)
Member#: 17778
WR Bluw
Default Water injection group buy $300 Shipped!
We will be selling the water injection kit in this group buy for 10 people.
The kit will be $300 shipped, if you need the pressure switch because you don't have a UTEC or way to control the solenoid it is an extra $25 also you can add the water level switch for another $25.
Please post here and send a deposit of 50% to sale@WRTuner.com through PayPal or call 1-866-WRTuner to pay by phone.
All kits will ship after this group buy, and all payments have been recieved.
Group buy will run 2 weeks. or until we have at least 10 people we will extend the amount if we have a large enough call for the kit but not to exeed 20 kits.
You can now add a wide-band to your order, for those that have already purchased the kit you can add it too! The unit is usually $350 and we are offering it with any water injection kit for only $300! We need to have at least 10 people to get this price but it is well worth it!
WRXTuner is offline   Reply With Quote
Old 12-02-2003, 10:59 PM   #2
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Just to get you started...
I know you will probably have a lot of questions so I did the search for you already and here is the link to all the water injection posts on the forum
Water injection search
Also cllick here for the link to our site with some more info on the kit
Old 12-02-2003, 11:10 PM   #3
Axan
Member Sales Rating: (14)
Member#: 17569
2011 Impreza WRX STI
any chance of getting some extra parts like water level sensor?
Axan is offline   Reply With Quote
Old 12-02-2003, 11:54 PM   #4
WRXTuner
Vendor
Member#: 17778
WR Bluw
Yes you can for an extra $25 you can add the level switch to the kit
Old 12-03-2003, 04:36 PM   #5
Axan
Member#: 17569
one more question, is it possible to run water/methanol(80/20 or so) mixture on your system? or will it cause corrosion to the pump/water nozzle ?
Old 12-04-2003, 12:49 PM   #6
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Actually
We actaully recommend using 20 Below washer fluid it has a mixture of 50/50 water and methal alchohol and it keeps the system clean
WRXTuner
Old 12-11-2003, 03:50 PM   #7
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Holiday special!!
Old 12-13-2003, 02:50 AM   #8
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default Wanted to add this info...
Old 12-13-2003, 04:25 AM   #9
kaos200
Member Sales Rating: (72)
Member#: 2692
Im very interested, but it looks like it uses the windeshield washer bottle? am I right?
I dont have that so do you offer a canister of some sort that the pump attaches to?
kaos200 is offline   Reply With Quote
Old 12-14-2003, 10:34 PM   #10
wgknestrick
Member Sales Rating: (4)
Member#: 32576
04 STI
Could this be installed to the STIs IC water tank in the trunk? I really can't loose my washer fluid and don't want to risk running out. IC water spray tank is huge too.
wgknestrick is offline   Reply With Quote
Old 12-17-2003, 12:54 PM   #11
wgknestrick
Member#: 32576
04 STI
Is this still going on? If so I'm in.
Old 12-17-2003, 05:12 PM   #12
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default YES!
Yes it is still going on and we have the kits in stock so no need to wait more then a couple days to ship
www.WRXTuner.com
Old 12-17-2003, 09:18 PM   #13
kaos200
Member#: 2692
A couple ?s
Wondering what size thread the nozzle is?
Also, I have a controllable output on my ecu, so does the solenoid just need a power to be switched to it? Or does it have a relay that gives it power?
Old 12-18-2003, 12:41 AM   #14
WRXTuner
Vendor
Member#: 17778
WR Bluw
Originally posted by kaos200
A couple ?s
1. The nozzle uses a 25/64ths drill bit to be installed
2. The solenoid we recommend that you power the solenoid and use a switched ground to operate it
I hope this helps.
www.WRXTuner.com
Old 12-21-2003, 02:31 AM   #15
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
can i still get in on this for my christmas present?
I'd like a kit and the water level switch. How does that work? Also I already have a bunch of switches in there, can I use one of them to control WI master ON/OFF ? Possibly control power to the pump? Lastly, could I hook up some LEDs to view water level, pressure, or actively spraying conditions, etc?
Oh, and one more thing, I can just tap my FMIC pipe right before the throttle body, right?
Thanks, I'll paypal, as soon as I hear from ya!
ScreaminFast is offline   Reply With Quote
Old 12-21-2003, 10:31 PM   #16
pfhlipwrx
Member#: 19319
This still going on?....
want to join in the fun of water injection......
pfhlipwrx is offline   Reply With Quote
Old 12-22-2003, 12:47 PM   #17
WRXTuner
Vendor
Member#: 17778
WR Bluw
Default YES!
It is still going on if you are interested please give us a call and we will get it out for you ASAP!
Call us at 321-206-6228 to place your order over the phone.
WRXTuner
Old 12-22-2003, 12:57 PM   #18
WRXTuner
Vendor
Member#: 17778
WR Bluw
Originally posted by ScreaminFast
can i still get in on this for my christmas present? YES
I'd like a kit and the water level switch. How does that work? The water level switch is an electro maginetic pressure switch it work very simply you run a small hose out of it into your resivior and when the fluid level gets low it releases the switch and completes the circiut.
Also I already have a bunch of switches in there, can I use one of them to control WI master ON/OFF ? YES
Possibly control power to the pump? You will get a harness that will allow you to control both the pump and the solenoid's power.
Lastly, could I hook up some LEDs to view water level, pressure, or actively spraying conditions, etc? YES and I we can walk you though it.
Oh, and one more thing, I can just tap my FMIC pipe right before the throttle body, right? that is correct
Hope this helps all answers were provided by WRXTuner
Old 12-23-2003, 01:44 AM   #19
ScreaminFast
Member#: 24399
2003 White WRX
89 240 / 90 240
i'll be calling first thing tomorrow
I called earlier today before you guys posted this, but no one was there. I'll try to call around 1pm or so tomorrow to order. Thanks guys, and I look forward to you helping me get a hot custom setup going for the WI
Old 01-14-2004, 08:49 PM   #20
my02wrx
Member Sales Rating: (3)
Member#: 15972
2002 wrx
my02wrx is offline   Reply With Quote
Old 01-21-2004, 12:32 AM   #21
M32WRXin3seconds
Member#: 36797
bump...just ordered one now...it appears its still going on!
M32WRXin3seconds is offline   Reply With Quote
Old 01-28-2004, 02:55 PM   #22
M32WRXin3seconds
Member#: 36797
just received mine! yey. the kit looks very nice. thanks again nick
Old 01-28-2004, 06:25 PM   #23
cdvma
Member Sales Rating: (11)
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Did you pay the group-buy price or the $350 listed on the site?
cdvma is offline   Reply With Quote
Old 01-29-2004, 12:07 PM   #24
M32WRXin3seconds
Member#: 36797
group buy price + the level meter...
AEM: Water Alcohol/Water Injection Kits $370 Shipped! No Limit Motorsport Engine/Power/Exhaust 10 09-14-2008 02:26 AM
CoolingMist Water Injection Group Buy!!! Insane Specials!!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 73 09-25-2006 09:53 AM
CoolingMist Water Injection Group Buy!!! Insane Specials!!! IMPORTIMAGE Vendor 'Group Buy' Classifieds 77 04-26-2006 01:48 PM
Snow Performance Water Injection Group Buy ! F1DYNO Vendor 'Group Buy' Classifieds 8 11-08-2005 05:24 PM
Water Injection kit group buy $275 + shipping WRXTuner Vendor 'Group Buy' Classifieds 107 10-22-2003 08:45 PM
