Old 12-03-2003, 12:51 PM   #1
JST
Member#: 5808
1999 RS-T/Legacy
sylver/black
Question Exhaust 2.5'',3.0'' or 3.5''
At first a want to bye a 3'' WRX exhaust to put on my 99 RS_T (8.5psi) but now i just fond a shop how did great hand made exhaust in S-S and mandrel whit the muffler a want. And they did exhaust and the DP all for 200$$$ less than a simple WRX cat-back.
The question is should a go with a big 3.5'' turbo-back exhaust or stay conservative and go with a 3'' or be a bit more conservative and keep my Lachute 2,5'' cat-back and my ASR 2.25 DP???
Need help???
JST is offline   Reply With Quote
Old 12-03-2003, 12:55 PM   #2
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
How much HP are you hoping for?
subachad is offline   Reply With Quote
Old 12-03-2003, 01:06 PM   #3
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
I would go with a 3" DP and a 2.75" cat back. the reason for this is that most of the exhaust cooling happens in the downpipe. once the exhaust cools the volume of gas decreases. You always want to run the smallest diameter pipe that won't cause backpressure. If you run a pipe that is too big your flow velocity drops off measurably and you loose alot of power. If you are only intending to run 8.5psi then a 3" DP and 2.75" cat back is very well matched.
no-coast-punk is offline   Reply With Quote
Old 01-01-2004, 07:39 PM   #4
OB2
Member#: 51500
1999 impreza rs-t
sylver
It is just becaise i saw the APS 3,5" turbo/back race exhaust and it look like a good idea!!!
OB2 is offline   Reply With Quote
Old 01-01-2004, 11:07 PM   #5
Unsung Boxer
Member#: 37196
i dont know how 3.5" can fit... i have 3" that i did myself at my work, and it was a pain in the @$$
-Jake
Unsung Boxer is offline   Reply With Quote
Old 01-02-2004, 07:01 AM   #6
Tats
Member#: 5692
WTF? YES! I am
better than you!
The bigger the better. Turbo cars do not have to worry about back pressure. The turbo itself is the engines back pressure so after it you wan the LEAST resistance. Turbos would run best with no exhaust at all but that is not an option.
Tats.
Tats is offline   Reply With Quote
Old 01-02-2004, 11:42 AM   #7
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Tats.
While your statement is true, it is also short-sighted financially. The APS 3.5" is around $1300. A TurboXS exhaust (for example) that is 3" would be right around $1000. 2.5" exhaust would probably be even cheaper and still put out enough volume.
Old 01-02-2004, 01:59 PM   #8
Soon2BturbodRS
Member#: 35868
06 Impreza OBS GG6
Corolla GT-S Hachi Broku
I agree with 80% of what Tats said. The best exhaust option on a turbo car is none, but 3.5" piping is definately overkill unless you are planning on 500+hp or something crazy like that. Here's a quote from Corky Bell's book. Great book btw.
Corky Bell - Maximum Boost
It is easy to get overeager on fitting large-diameter pipes into an exhaust system. "The larger the better" is not the case. As indicated in Chapter 5, there is an exhaust gas velocity that ought not to be exceeded...
He also has a chart which represents the general idea of how big exhaust piping should be on a turbocharged car... He recommends 3.5" piping for a 800-850hp car
Hope this helps
-ben
Soon2BturbodRS is offline   Reply With Quote
Cant Decide Between APS 3.0'' Or 3.5'' Exhaust cuoffrd2 South West Impreza Club Forum -- SWIC 13 03-16-2006 04:16 PM
2.5 inch dp or 3 inch dp? Dizzuque Newbies & FAQs 7 10-22-2005 11:01 PM
Oil change: every 3 months or 3,000mi? Kitt Service & Maintenance 19 02-05-2005 07:44 PM
Route 10 lunch meet 3/11 or 3/12 Prime Mover Tri-State Area Forum 21 03-11-2004 11:58 AM
Mini meet at my place on 3/17 or 3/24 depending on ice race. Anyone interested? Sean New England Impreza Club Forum -- NESIC 13 03-14-2002 11:20 AM
