Old 12-04-2003, 12:49 AM   #1
JenisonWRX
Member#: 6049
02 WRX & 99 RS
Default Oil in sparkplug lip
Hey all.
So I replaced mywires when I bought the RS cause they were constantly falling off. So I got a set of Macnicore. And I replaced the plugs.
So anyway, they are now poping off at random. Also, on the passanger side there is oil in the lip on the valve cover. Oil is NOT puddling in the bottom. I made sure of that.
replace the valve cover gasket?
JenisonWRX is offline   Reply With Quote
Old 12-06-2003, 02:26 PM   #2
JenisonWRX
Member#: 6049
02 WRX & 99 RS
anyone ... anyone?
Old 12-06-2003, 04:07 PM   #3
atabert
Member#: 45107
1992 Legacy L
Green
Default leak
yup, thats what you would need to do to stop the oil leak from getting any worse, you would need a v/c gasket, 2 spark plug gaskets and 5 groumets for the bolts which hold the valve cover on, per side, but you can only do the side that is leaking, and it will get worse before it gets better , good luck
atabert is offline   Reply With Quote
Oil in sparkplugs jensht Service & Maintenance 6 06-24-2006 12:36 PM
Oil in sparkplug cylinder. P0304 again. Need help please... Siper2 Normally Aspirated Powertrain 8 11-23-2004 06:23 PM
Oil in the sparkplugs soso3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-06-2004 04:52 PM
Oil in Sparkplug wells? skidplatez Normally Aspirated Powertrain 8 02-25-2004 09:57 AM
engine oil in the sparkplug hole ? DEVO-2nd GEN Service & Maintenance 3 10-18-2002 01:20 AM
