Old 12-04-2003, 06:33 PM   #1
dinonet
Member#: 49854
Blue Pearl
Default Anyone have any unusual experiences with RE92s, or alignment problems with 2002 WRX?
Anyone have any unusual experiences with RE92s, or alignment problems with 2002 WRX? My left front tires are wearing unevenly on the inside edge, compared to right front. Never hit a pothole, keep pressures pretty uniform. I have 42,000 miles on them and don't know if it's a waste of money to get an alignment if I don't need it. I also don't know if the Subaru dealer is the best/cheapest place to get the alignment done. Any suggestions? I'm in Chelmsford, MA area.
dinonet is offline   Reply With Quote
Old 12-04-2003, 06:41 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
Have you been rotating the tires regularly? Assuming you did and the wear was the same, I would say it's time for an alignment. Check the regional forums. Perhaps a local member can give you advice on the best/cheapest shop in your area.
- Kean
Kean is offline   Reply With Quote
Old 12-04-2003, 06:47 PM   #3
dinonet
Member#: 49854
Blue Pearl
That's the problem. I haven't been rotating them every 7500 miles more like 15,000 to 20,000. My guess was that maybe I didn't rotate regularly enough but wouldn't they of at least worn out evenly? My left front is much worse than the right front. My dilemma is that if I spend the $80 for an alignment that I don't need that would be a waste. What do you think?
Old 12-04-2003, 07:05 PM   #4
bull3964
Member#: 48928
'02 WRB WRX Sedan
'11 DGM WRX 5dr Premium
Wait.
You got 42k miles on the original tires?
Mine were junk and dangerous and near the wear bars after 13k miles and I don't exactly flog my car on the streets.
bull3964 is offline   Reply With Quote
Old 12-04-2003, 07:09 PM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
If they had the same sort of wear after you rotated them, I would suspect that the aligment could be off. After 40k miles, it's not unusual. If you're going to be getting new tires soon, I would probably suggest an alignment regardless. It's better to pay the $80 now rather than screwing up a new set of treads. ....just my opinion. Luke from Tire Rack might have something to add.
- Kean
Old 12-04-2003, 08:15 PM   #6
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
My alignment was off from the start, different side to side by quite a bit.
The left front tire wears quicker on all WRXs I've noticed, not entirely sure why.
TyrannoSullyRex is offline   Reply With Quote
Old 12-04-2003, 08:19 PM   #7
Kean
Member#: 25187
'08 Foz Prem TGM
hmmmm. Not on mine.
Old 12-04-2003, 08:23 PM   #8
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
Default alignment question
with a newly aligned subaru on stock wheels/tires...will a nice new set of 17X7.5's throw off the alignmet?
Basically I want to know if I shoud wait until after I put on my new wheels to get an alignment.
eyeballs is offline   Reply With Quote
Old 12-04-2003, 08:50 PM   #9
stiles_sm
Member#: 47828
'04 WRX wagon
... 03 996, 00 S4
Sounds very much like your LF wheel has more negative camber dialed in than your RF. Toe tends to affect both sides equally.
I'd get it aligned...
stiles_sm is offline   Reply With Quote
Old 12-04-2003, 08:53 PM   #10
dinonet
Member#: 49854
Blue Pearl
Thanks for all your feedback guys. Do you think that there's a benefit to getting an alignment done for $80 at the Subaru dealer compared to maybe 10-20 bucks less with a Good Year or other shop? I always hate going to the price gouging dealers unless they do a better job than say a Sears or Good Year shop. What are your experiences?
Old 12-04-2003, 08:57 PM   #11
oxtox
Member#: 33740
2012 sti hatch
wrb
1. it's not uncommon that dealer alignment is not "right on" on purchase (something in transport?) 2. if you got more than 40k on re-92's youre fortunate. 3. some dealers (like mine) send the car out for alignment. 4. i agree with the getting a new alignment idea, you can find preferences here with a good serch. 4. good luck! by the way, i noticed the same thing at about 8k!
oxtox is offline   Reply With Quote
Old 12-04-2003, 09:07 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
Ronal (my wheel manufacturer) recommended it when they installed my wheels.
Old 12-05-2003, 11:59 AM   #13
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
I can't believe you have 42K on those RE-92s. Mine lasted till about 15k, and they were getting really scary those last few thousand.
As others have told you go ahead and check your alignment. I think the goodyear shops are fine. No need to spend so much more at the Subaru dealership for the same thing that they may screw up to. Plus, with the new wheels a alignment is alway recommend too if you have not had one in a while.
K
rankink is offline   Reply With Quote
Old 12-05-2003, 12:11 PM   #14
fliz
Member#: 30342
I've mine aligned at the dealer and a Goodyear shop, and the Goodyear shop was more customer friendly. They aligned it to specs that I gave them, and gave me the alignment sheet after they were done (and it was $10 less).
That way I know how close they got the alignment. "Within spec" for Subaru could be a LARGE variation for my tastes.
fliz is offline   Reply With Quote
Old 12-05-2003, 12:20 PM   #15
inchoate
Member#: 5470
2004 STi
blueish
my 2002 was delivered with a bent rear strut. it was replaced under warrenty, but it took a long time to track down the problem. that being said, if you're not rotating your tires it's not surprising that you'd have some unusual wear after 42K miles.
still you might want to get the front suspension throughly checked out to make sure there's nothing else going on.
inchoate is offline   Reply With Quote
Old 12-05-2003, 12:21 PM   #16
TyrannoSullyRex
Member#: 8891
2002 WRX Silver
'02 SV650
Originally posted by Kean
hmmmm. Not on mine.
haven't noticed yours, just the twenty or so that autocross here in Houston.
Old 12-05-2003, 01:04 PM   #17
Kean
Member#: 25187
'08 Foz Prem TGM
I'm not dismissing your claim, just saying I didn't notice that problem on mine.
Old 12-05-2003, 02:53 PM   #18
TheWake
Member#: 11186
2002 WRX sedan
WR Blue Pearl
K
I have well over 50K on my RE-92s, and while they are quite worn, they got me through the snow today without any trouble.
TheWake is offline   Reply With Quote
Old 12-05-2003, 11:23 PM   #19
Ian
Member#: 7274
2002 WRX Wagon
Stealth
I've got 44K mi on the first RE92's now. Of course they are super dangerous now, but xmas is coming! 20K of that was freeway miles tho...
I ran these crappy tires on my Taurus SHO twice (it came to me with almost new ones the first time) and got 15K if I was lucky.
Must be the AWD ;D
Ian is offline   Reply With Quote
Old 12-06-2003, 07:38 AM   #20
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Tires don't just magically wear unevenly. If there's clearly a difference in wear between your left and right side tires, then the alignment is off, end of story. (That assumes, of course, that you're doing normal driving. If you're driving entails nothing but doing clock-wise circles in a parking lot then it's entirely normal for the left side tire to have uneven wear. ). Based on my personal experience and from talking to Subaru-owning friends, Subarus seem to come from the factory with a pretty random alignment. My sister's WRX had grossly mismatched toe and camber up front - the mismatched toe is the killer when it comes to tire wear.
It would take a lot of camber mismatch to make a noticeable difference in tire wear. It would probably be visually apparent looking at the two sides of the car.
Just curious what you mean by that. Toe on each side of the car can be adjusted independently, so it's entirely possible to have proper toe on one side of the car and messed up toe on the other side, resulting in one tire wearing faster than the other. I would be willing to bet that dinonet's problem is a toe mismatch.
As for where to get the car aligned, I would most certainly go to an alignment shop before I went to the dealer. As someone already suggest, check your regional forum - the NESIC guys will certainly be able to direct you to a good shop.
Not unless the new wheels and tires are so hosed up that you shouldn't be buying them.
I'd be curious to hear Ronal's technical explanation of why an alignment would be necessary for new wheels and tires. Did you buy your wheels and have them mounted at a Ronal dealer or something? If so, that would explain their recommendation - more $$ in their pocket!
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-06-2003, 11:25 PM   #21
aznfoos
Member#: 40725
Platinum
I fuond my front right wheel wearing down more onthe inner than the outer edge. Then I took it over to MIDAS to get it aligned and they said that the control arm was bent. For some reason, Subaru doesn't cover this on my 2002 WRX that hasn't really gone through anything unusual.
Anyway, I bought a new control arm and aligned it perfectly. Cost me $150 labor and $100 control arm.
The subaru guys say that they have the best slignment and argue that "laser" alignment is needed for uor AWD, but I think that is bogus.
Anyway, my tires are done after 30k esp since one of the tires is overworn. It is worthe the $ to save your tires.
aznfoos is offline   Reply With Quote
Old 12-06-2003, 11:33 PM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
I think most modern alignment shops use laser alignment machines. I can't say I've ever seen a dealer that had one, but if they do then it can't hurt to have them do the alignment (assuming it doesn't cast any more than any other shop, which is highly unlikely).
Pat
Old 12-08-2003, 12:04 AM   #23
Kean
Member#: 25187
'08 Foz Prem TGM
Pat Olsen
I bought my wheels directly from Ronal USA. They are the distributor for Ronal GmBH here in North America. They're not set up like the usual wheel/tire shop you would walk into. It's a large distribution whse. However, if you buy the wheels and tires from them (and can drive in locally), they'll mount them for you using a small lift they have in back of the whse. To make a long story short, I was able to get a discount on the wheels and on a set of Pirellis. I read about the alignment recommendation on their website and they suggested it to me when I had the wheels installed. Regardless, they don't offer those types of services so there is no profit to be had by them. I beleive their reasons may be purely as a precaution to keep your new tires from wearing improperly (I don't know since I never asked). I didn't feel it was necessary on mine sine my car was practically new at the time.
- Kean
Old 12-08-2003, 02:13 AM   #24
Roamin'Coyote
Member#: 24562
05 9-2X Aero black
I have uneven wear on my driver's front also. First noticed it on my original stockers at 16k (I think there was a rotation in there). It's really weird also and just on the inner set of blocks and not across the whole tire's width. I guess I need an alignment but that'll have to wait until springs in Spring. For now, I'll just have to rotate them a little more often...I guess.
-wYlie
Roamin'Coyote is offline   Reply With Quote
Old 12-09-2003, 10:33 AM   #25
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
> wear on driver's front can be due to taking highway ramps (both on and off) at high speeds. you'll notice most of them entail right hand sweepers.
on the subject of toe wear being non-symmetrical, that would have to mean that one tire is side-slipping more than the other.
jm2c
ken
Anyone Have Any Wagon Experience With This RalliTek Kit? RexTexWagon Brakes, Steering & Suspension 4 03-29-2008 04:42 AM
ANYONE have any Xbox 360 memory cards or hard drives?!? bobturismo SWIC Private Classifieds 6 12-21-2007 07:40 PM
Anyone have any unusual Holiday traditions? Ferg Off-Topic 21 12-12-2002 03:41 PM
Anyone have any good experience with high-flow cats? trhoppe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 10-01-2002 12:12 PM
Anyone have the STi New Age Impreza Shift knob on their 2002 WRX? Mr. Ixnay Interior & Exterior Modification 0 04-22-2001 04:47 PM
