Old 12-04-2003, 06:47 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default What parts are needed to turbo a MAP sensored RS?
Hi, I was wondering what parts are needed to turbo a 00+ RS(other than the turbo kit and all that)...I mean the sutff for engine management...a voltage clamp? ..other stuff like that.
Thanks, Micah
Old 12-04-2003, 06:59 PM   #2
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
voltage clamp + rrfpr
OR
standalone with minimum 2Bar map sensor + larger injectors.
cRayZee is offline   Reply With Quote
Old 12-04-2003, 07:07 PM   #3
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
yeah you need a voltage clamp of some type. Either a seperate unit like the SplitSec (I have one for sale if you're interested) or some kind of engine management with a clamp built in like e-Manage, J&S version 2, or a full standalone. If you don't go with the RRFPR you will need bigger injectors which are tough to find. There's lots of debate on what fits and what doesn't.
lotusTT is offline   Reply With Quote
Old 12-04-2003, 07:24 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
how much is a voltage clamp and where can I buy one?
Take it easy, Micah
Old 12-04-2003, 07:30 PM   #5
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
PM'd you
Old 12-04-2003, 07:30 PM   #6
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
the simplest way to get a voltage clamp is to get a zener diode. Do a search for zener diode in this forum and it should provide you with more info about that and other kinds of voltage clamps
Old 12-04-2003, 10:14 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
lotus tt I read the message and am forwarding it to my friend
Old 12-04-2003, 10:19 PM   #8
dunk
Member#: 15359
You can also buy a J&S safeguard, and use the adjustable voltage clamp built into their new units. Is this for a local project?
Duncan
dunk is online now   Reply With Quote
Old 12-04-2003, 10:19 PM   #9
dunk
Member#: 15359
Duncan
Old 12-04-2003, 10:44 PM   #10
Homemade WRX
Member#: 33782
96 bastard child
possibly local...well you now know the story
Old 12-08-2003, 03:43 AM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
DO NOT use a zener diode. There is no excuse for using a $1-5 solution on an expensive RST motor!
I did extensive testing on my own 2000 RST, with ProECM's help, on voltage clamps. The zener diodes always caused the fuel to lean out as the clamp setting changed over time during an extended episode of boosting.
i.e. with zener diode, when kept under boost for several seconds from 3000rpm till redline, or in 5th gear in a run from 50 to 100mph, by the time the run was over the OBD2 was reporting the clamp had changed from being at 34inhg to 27inhg. Since the ECU was seeing less MAP pressure it was not giving enough fuel. EGT's went over 1550F in 5th gear at 4 psi vs 1400 with a proper stable voltage clamp. Imagine how high they might have gotten if the boost was held until 120-140mph! With the proper clamp, EGT never went over 1475 by redline in 5th at 4-5 psi! With the Zener we had to keep aborting the run by 100mph.
Get a Split Second, ProECM or TorqueChip voltage clamp - if adjustable (the first two above), set it so that the ECU sees close to 32-34inhg (over that will give CEL for high ABs manifold pressure). When the ECU sees the positive manifold pressure, as well as the hotter intake air temps, it will appropriately retard the ignition timing 4-10 degrees from what the chips will give on an NA car. We saw 10 degrees less timing at 5 psi and 3000 rpm (16 vs 26), and 6 degrees less timing at redline (28 vs 34) between NA and boosted.
The RRFPR with 75-80 psi of fuel pressure, and the ProECM or Torquechip should be enough fuel for 240-250+ flywheel HP on a MY00+ RST (about 175whp) - then you hit the limits of the stock injectors, which at 5-6 psi is the limits of the stock ECU ignition timing and pistons anyways.
Anything over 5 psi and you really should be thinking of the J&S or the new ProECM timing retard box anyways, especially in the MY00+ which have pistons that like to break at the valve relief with small amounts of detonation. Small variation in gas quality at the edge of high timing advance can be disasterous.
Anything over 6 psi and you will need either (1) bigger injectors (not more than 25-30% bigger than stock I am told with a MY00+ ECU or the closed loop is f u b a r - and you get CEL for being too rich cruising, or the idle suffers) or (2) extra injectors like this http://www.subaruplanet.com/sdsefi.htm
Been there, done it all, blown most of them up...
ImprezaRS dot com is offline   Reply With Quote
Old 12-08-2003, 10:26 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
thanks for the warning!!!
Old 12-08-2003, 03:49 PM   #13
insanesuby
Member#: 23494
2013 WRX
Got a split second for sale. Pm me if you are interested!
insanesuby is offline   Reply With Quote
Old 12-08-2003, 05:59 PM   #14
Homemade WRX
Member#: 33782
96 bastard child
um...I'm not the one looking to buy...my friend was wondering because he has an 01 but not anymore...it was just declared totalled...thanks anyway.
Take it easy, Micah
Old 12-08-2003, 09:05 PM   #15
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
Was that OCimportracer who rolled it 5 times? He told me about it last night...
Old 12-08-2003, 09:08 PM   #16
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
PS: The torquechip clamp is already at 32inhg, and can be special ordered as an adjustable clamp at no extra charge.
Old 12-08-2003, 09:23 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
um no he didn't roll his car...that was someone else
and as far as the Torquechip goes.....that's pretty cool...I didn't know that.
Old 12-09-2003, 09:10 AM   #18
John at J&S
Member#: 2036
2000 Intrepid
Our adjustable clamp in action. Scope photo shows input/output:
It takes more than a zener. Photo of our old standalone voltage clamp, now built into the SafeGuard:
John at J&S is offline   Reply With Quote
Old 12-09-2003, 10:04 AM   #19
Homemade WRX
Member#: 33782
96 bastard child
yeah I know that the newer safegaurds had them built in...very cool.
Take it easy, Micah
Old 12-10-2003, 12:21 AM   #20
ImprezaRS dot com
over boosted again
Member#: 1458
2006 B9 Tribeca LTD
2005 Impreza 2.5 RS
Wow, that makes the J&S the cats meow now - didn't know about the clamp in it.
2.5rs swap. what parts are needed? ILwrx Subaru Conversions 2 10-03-2005 04:58 PM
what parts are needed for 6spd? cronic Subaru Conversions 2 09-23-2003 12:51 PM
What parts are needed for Headgasket change? Cusco Service & Maintenance 3 05-24-2003 02:56 AM
what other parts are needed for turbo conversion halftendril Normally Aspirated with bolt-on Forced Induction Powertrain 4 05-14-2003 12:57 AM
What parts are needed for Autometer Ultralite A/F guage install? Robmat Normally Aspirated Powertrain 4 03-03-2002 06:45 AM
Message Board Statistics All times are GMT -4. The time now is 01:13 PM.
