Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 12-04-2003, 11:53 PM   #1
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Default APS TMIC install
Man, I thought this would be easy. Big mistake. First took forever to get this thing crammed in there and get the bov, turbo and TB hose to line up. This thing being heavy as hell didn't help the cause either. Then I tried to salvage my whiteline strut bar and thought I was successful, but when I started the car it started shaking because the strut bar was touching the IC which was on the motor. Then I was so happy I was done I didn't realize the IC was laying on the turbo top coolant hose. Test drive went saw, saw, psshhhh. Luckily I didn't leave the neighborhood and coasted it on home. Tomorrow I have to figure out how I can route the new coolant hose. Got any ideas. Oh and I managed to fit the APS splitter to my CF hood with a regular size scoop no problem. Just had to vent--I'm pouring a drink and going to bed
PS
I bought the IC and splitter from bikerboy a highly recommended seller. Although my back and knuckles are cursing him now.
rjrutzky is offline   Reply With Quote
Old 12-05-2003, 02:52 AM   #2
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
dunno if you have the newer version, but i do and it is a REAL pain to install.
It makes it MUCH easier to have one person on each side due the the ICs weight.
Some tips i've come up with:
- Wrap the metal AC hose with some rubber heater hose. When it's pressed up against the firewall it rattles like mad.
- Wrap the lower portion of the AC hose with heater hose where it contacts the back-side of the IC.
- Dunno how yours fits. But i bent the hell out of my wastegate nipple with the IC. Take off the passenger side bracket and put two 10mm washers under each bolt. This raises it enough to clear the wastegate. if the IC touches the wastegate hose it will eventually rub through and you will get boost spikes.
- By far the best tip, REMOVE the driver side bracket and leave it off till you get the IC in. Once the IC is in place and all the hoses are attached you can shimmy the bracket in there.
that's all i can think of....
Kwyjibo is offline   Reply With Quote
Old 12-05-2003, 09:09 AM   #3
rexmobbin'
Member#: 31373
2005 Legacy GT
Satin White Pearl
dang, i thought top mounts were a piece of cake. let us know how it drives once everything is simpatico.
rexmobbin' is offline   Reply With Quote
Old 12-05-2003, 09:58 AM   #4
WRXperience
Member#: 48721
2002 Impreza WRX
I want her back..someday!
i had the same problem with mine... just make sure nothing is touching or rubbing it. and leave the drivers side bracket off until the end. oh ya and get an extra hand... did anyone else have problems with the intercooler rubbing a hole in the ac line. cause my ac doesn't work anymore.
WRXperience is offline   Reply With Quote
Old 12-05-2003, 10:00 AM   #5
WRXperience
Member#: 48721
2002 Impreza WRX
one more thing. i had no problem with my strut tower brace(cusco) i just had to bend the ac lines a little...
Old 12-05-2003, 10:23 AM   #6
savka
Member#: 12737
MY02 wagon 325/300
MBP
I was told by people who should know that if you bend the AC lines (which are aluminum) to fit a large intercooler this will cause an imperceptible crack in the tubing (steel bends, aluminum cracks) and eventually all of the freon WILL leak out. You need to get the STi AC lines which are actually bent from the factory to accommodate the larger intercooler and lie closer to the firewall. They probably cost around $80 and of course you will have to re-charge your AC system with new freon witch will cost another $100. So for a larger TMIC you should expect to spend an additional 180-200 bucks.
I am not speaking from personal knowledge but fron the words of several folks who are in the business of Subaru aftermarket parts and installations.
sav
savka is offline   Reply With Quote
Old 12-05-2003, 12:48 PM   #7
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
the sti ac line will work...i almost did it. But heater hose wrapped around it seems to have prevented a hole from being rubbed into the pipes...and i've had the IC for about 3-4 months now.
Process West TMIC Installed & APS 65mm CAI sszyma Car Part Reviews 41 12-23-2010 07:40 PM
WTB: APS 70mm Intake, APS TMIC BOV, APS TMIC MKXIII Private 'Wanted' Classifieds 0 07-27-2007 12:41 AM
cel after installing APS TMIC with cobb 2.5 AndyWRXWG Engine Management & Tuning 12 11-30-2005 05:56 PM
Need help with install on used aps tmic hybrid gti 2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2005 09:36 PM
The APS tmic is installed. Brewmaster New England Impreza Club Forum -- NESIC 3 06-05-2003 10:47 PM
