Old 12-05-2003, 04:22 AM   #1
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Default 04 WRX/STI Antenna WIRING within + picture
From what we've found the antenna power wire remains the same for:
- Impreza 1993-2007
- Impreza 2008-2010 with factory Navigation Head Unit. Will not work on nonNAV equipped cars.
- Legacy/Outback 1998-2009, will not work with cars that have upgraded from base model stereo system
- Forester 1998-2010
- Forester 2009-2010 with factory Navigation Head Unit. Will not work on nonNAV equipped cars.
- Saab 92-x 2004-2005
Chances are if you wired up your 04 wrx or sti (and most all other 04-present subarus) you've noticed that your radio reception was exceptionally poor. There are 2 reasons why.
1. The rear glass mounted antenna unit needs to be turned on by a 12v power source. Here is a picture depicting the desired wire on the chassis side of the harness.
Aftermarket radios usually denote which blue wire is the antennas turn on by writing on it, or giving it a white stripe. Please consult your owners manual versus making assumptions on which wire is correct. The antenna will only be on when the deck is turned on by wiring it to the switched 12v line or (where applicable) to the blue antenna power wire coming from the after market head unit.
2. Do not forget to fish out the coaxial cable from behind the radio dash area and plug it into your headunit. The item looks like this.
Please make note of which wire and maybe even make this guy a sticky thread to help out others that are pulling out their hair over weak radio reception.
IA Performance is offline   Reply With Quote
Old 12-05-2003, 09:45 AM   #2
Haven
Member#: 95
2006 Wrx
Crystal Gray
Where is the harness located? Can you just connect it to the blue wire in that same harness?
Haven is offline   Reply With Quote
Old 12-05-2003, 09:48 AM   #3
jtgray_10
Member#: 26879
2002 WRX wagon
Just a guess, but behind the radio, maybe.
jtgray_10 is offline   Reply With Quote
Old 12-05-2003, 11:37 AM   #4
IA Performance
Member#: 25194
Dark Gray
that is the stock radio harness. I kind of forgot that :/
Old 12-19-2003, 01:48 PM   #5
WRC-STI
Member#: 39707
2004 STI
That wiring tip was just what I needed. THANKS! I now get good FM reception but AM is still pretty poor. Any ideas? Where is the actual antenna? Thanks for any help.
WRC-STI is offline   Reply With Quote
Old 12-19-2003, 04:01 PM   #6
IA Performance
Member#: 25194
Dark Gray
the actualy antenna is in the rear glass. It looks like the defroster but runs vertically down the middle I believe. Can't help ya with AM Sorry.
Old 12-20-2003, 02:34 PM   #7
spacemonkey
Member#: 16435
somewhat related... where are the stock wires for the read deck speakers located? is it those two wires and clip in the middle of the deck area?
thanks
monkey-
spacemonkey is offline   Reply With Quote
Old 12-20-2003, 02:54 PM   #8
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
Follow this link to Ravensblade's website. Look for the 2002 radio wiring diagram. Everything matches up to the 04 harness except for pin 14, which he has labled as not being used but is the power antenna lead on the 04 models. I used this diagram for my radio replacement and everything works perfectly. Thanks to Ravensblade for his website which has been alot of help to me. Keep up the good work Ravensblade. And good luck to anyone replacing their stock radios.
You will find the wiring diagrams in the Tech docs and informational pages on the left index.
skyhawk is offline   Reply With Quote
Old 12-20-2003, 09:28 PM   #9
brunetmj
Member#: 8023
2004 2.5 RS
The actual antenna is across the very top of the window. At least thatís what I thought I saw. I just had that section off today looking for the defrost wires. The module is made by clarion.
brunetmj is offline   Reply With Quote
Old 12-31-2003, 11:23 AM   #10
Extraze
Member#: 16980
if you remove the apilar (on the drivers side) ... there is a wire comming up on there that i dont recall seeing in the 02's ... i think that wire might be the antenna ... not sure
Extraze is offline   Reply With Quote
Old 01-06-2004, 07:38 PM   #11
2jz-gte
Member#: 22784
97 Supra TT (sold)
04 STi White/Silver
Default blue or red wire?
I have a sony head unit(CDX-c7850) and it has a blue wire labeled "ant rem max .1A". Is this the wire I should connect to the solid white wire or should I just use my 12V/ACC red wire?
Thanks
Ben H.
2jz-gte is offline   Reply With Quote
Old 01-06-2004, 08:53 PM   #12
IA Performance
Member#: 25194
Dark Gray
yup, connect your blue headunit wire to the white one.
Old 01-06-2004, 09:19 PM   #13
jaypride
Member#: 33424
2004 STI
Blue/Gold
thanks
monkey-
There are no speakers in the rear deck. The rear speakers are in the back doors. The Legacy's have a single sub in the rear deck, but I don't think any Impreza's do.
jaypride is offline   Reply With Quote
Old 04-21-2004, 12:54 PM   #14
chaddeus
Member#: 56624
2004 Subaru WRX STi
Hey guys. I am receiving FM signal but still not satisfied compared to my previous BMW where I get excellent signal on all the channels I listen to.
Could this be a problem OR simply just a lousy antenna provided by Subaru?
Based on the picture shown above, must I actually connect the white wire and the red wire together???
- Charles
chaddeus is offline   Reply With Quote
Old 04-21-2004, 01:12 PM   #15
robmarch
Member#: 18713
06 CRV
04 STi
- Charles
do you have metallic tint?
robmarch is offline   Reply With Quote
Old 04-21-2004, 02:21 PM   #16
chaddeus
Member#: 56624
2004 Subaru WRX STi
I am not sure if mine is a metallic tint. I use HuperOptik and its supposed to be the type of tint that would not interfere with onboard radar detector.
So I am not sure if this is the problem.
- Charles
Old 07-26-2004, 09:27 AM   #17
rich728
Member#: 40328
2004 WRX STi
BSP #728
Originally Posted by East Coast Scooby
Chances are if you wired up your 04 wrx or sti you noticed that your radio reception was exceptionally poor. Reason being it needs to be amplified via a 12v power source. Here is a picture depicting the desired wire
The antenna will only be on when the deck is turned on by wiring it to the switched 12v line.
I just want to make sure this is correct. Has anyone done this?
rich728 is offline   Reply With Quote
Old 07-26-2004, 10:40 AM   #18
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
I don't think so. I think it is the front glass, at the bottom. At least in MY04 WRX there are a series of 'wires' in the bottom of the front windshield. But really this is besides the point. I forgot to hook up this wire at first as well but thanks to your thread (I searched) I corrected it.
conker69 is offline   Reply With Quote
Old 07-26-2004, 11:21 AM   #19
robmarch
Member#: 18713
06 CRV
04 STi
it's in the back glass. I believe at the top, I'll check though.
the wires in the my04 WRX are heated wipers for the winter package, perhaps?
Old 07-26-2004, 11:22 AM   #20
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
I'm going to have to say yes.. many many people with the 04 sti's have put radio's into their cars and have figured out that this is the wire to the powered antenna, but I think east coast scooby was just making it more public knowledge. plus east coast scooby wouldn't lie... or would they..
-- Steve
SLKWrx is offline   Reply With Quote
Old 07-26-2004, 11:24 AM   #21
SLKWrx
Member#: 8247
2004 STi JBP
1973 914
The wires for the antenna are the top 2-4 wires of the rear glass. The front wires are a defroster for your windshield wipers a la cold weather package.
-- Steve
Old 07-26-2004, 11:31 AM   #22
conker69
Member#: 59692
WRB-Gold
-- Steve
Cool. Thanks for clearing that up. Everyone else ignore my other post. Sorry...
Old 07-26-2004, 11:38 AM   #23
Vidiotgamer
Member#: 17504
2002 Impreza WRX
Blue Mica
wow,didnt know anyone used the radio in the subie,hehe,i watch tv or listen to cd's .
Vidiotgamer is offline   Reply With Quote
Old 07-26-2004, 05:44 PM   #24
STiMULi
Member#: 59381
Ceramic tint is available now with the same properties of metalic except the RF loss. I had this problem and it was resolved with ceramic. Metalic will kill AM reception and it also distorts the frequencies of high powered stations.
Ceramic is usually lifetime tint...
STiMULi is offline   Reply With Quote
Old 07-26-2004, 07:20 PM   #25
rich728
Member#: 40328
2004 WRX STi
BSP #728
how could i tell if it were activated from the trunk?
besides hearing the radio.
could i check for power somewhere?
WTB: 2008 WRX/STI antenna Diabolus Private 'Wanted' Classifieds 1 03-18-2009 05:01 PM
WTB 02-04 WRX complete motor/wiring harness nukem2.5rs Private 'Wanted' Classifieds 6 02-25-2004 01:47 PM
STi antenna wire - where? das Car Audio, Video & Security 7 08-09-2003 03:56 PM
