Old 12-05-2003, 09:07 AM   #1
Zephyr
Member#: 3362
1985 I've wired a
Few cars in my day
Default WRX harness through the firewall on an RS swap
I know several of you have already done swaps as have I but all the swaps I've done so far I've used the stock downpipe. My concern is that when upgraded to a aftermarket DP at a later date it is gonna be really realy close to the harness. What has everyone else done to combat this issue?
Any input would be appreciated and photos would be even nicer.
Z
Zephyr is offline   Reply With Quote
Old 12-05-2003, 12:06 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
You happen to have a pic of your stock downpipe in your car and a pic of the stock downpipe in a WRX?
Also, the stock downpipe is fairly large and gangly. It might be that an aftermarket downpipe requires no additional room.
-Jon
Old 12-06-2003, 04:04 PM   #3
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
aftermarket downpipe is actually much less room taking. oem has giant cats and heatshields and the like. perhaps wrap the harness in the aluminum foil type heat shielding like the PS lines have
h
electricpork is offline   Reply With Quote
Old 12-06-2003, 09:26 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
I looped my harness "OVER" the AC line....that way it has some extra clearance to combat the heat...Plus I put heat shielding over the harness to help also...then Electrical tape...then loom...
Bill
Best place to thread the battery power lead through the firewall? Patu Car Audio, Video & Security 10 04-26-2007 09:36 AM
Whats the best place to route wire through the firewall Psyk Car Audio, Video & Security 8 09-01-2005 11:58 AM
help with the starter on an ej20g swap smacksube Subaru Conversions 5 12-13-2003 10:20 AM
WRX Head To Cat Sytem On An RS SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 23 03-27-2003 06:47 PM
Where should I run wires etc. through the firewall? scootr Normally Aspirated with bolt-on Forced Induction Powertrain 2 10-22-2001 12:22 AM
Message Board Statistics All times are GMT -4. The time now is 12:36 AM.
