Old 12-05-2003, 06:00 PM   #1
method2madness
Member#: 49115
2002 Subaru impreza
black
Default Perrin adjust short shifter
any one using this short shifter, i just bought it and i wish i went with the B&M... , i mean this shifter is ok... but its really rough into first, i bent the metal tab up so it would get clearance but you can only bend it up so much , AND it still RUBS! argh, any one else having problems with this damn short shifter?
method2madness is offline   Reply With Quote
Old 12-07-2003, 03:39 PM   #2
Brento
Member#: 24485
02 RS
if you want your shifts that short just cut a notch in the plate. take a dremel to it and go at it. that is the only thing to do. i set mine in the middle something like 52-54mm and i'm not touching the plate after bending it.
Brento is offline   Reply With Quote
Old 12-07-2003, 03:46 PM   #3
supermarkus
Member#: 6971
2008 WRX STi
SSM
Or you could bend the tabs up on the plate about 30 degrees or cut them off, and rotate the plate 180 degrees to get your clearance.
supermarkus is offline   Reply With Quote
Old 12-07-2003, 05:51 PM   #4
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
[quote]Originally posted by method2madness
you mean a kartboy LOL
the B&M shifters have the same amount of interference as the others.
my thoughts are to lower it a little bit or bend the plate more..
tom@kartboy.com
Old 12-07-2003, 06:35 PM   #5
Ride Operator
Member#: 18710
02 GDA PSM
12 Impreza Sprt Lmtd MBP
This is what I did too when I installed mine.
Ride Operator is offline   Reply With Quote
Old 12-07-2003, 06:38 PM   #6
Celly
Member#: 48724
Default Re: Perrin adjust short shifter
I just did this install on an 04...
Did you remeber to turn the stock shifter around? If you didn't. this will make it bind worse...
I felt the kartboy, and also now know how the perin feels, and it is very similar. The big thing is, with the perrin you have the worry of it coming loose, but nothing a lil red loc-tite can't fix.
The thing I liked the best? It cost me 50 bucks less than the KB.
Celly is offline   Reply With Quote
Old 12-07-2003, 06:49 PM   #7
method2madness
Member#: 49115
2002 Subaru impreza
black
lol thanks guys ..
Old 12-29-2003, 03:33 AM   #8
method2madness
Member#: 49115
2002 Subaru impreza
black
well the issue is taken care of, i took that metal plate to the wheel grinder and had a field day now its free and clear and my shifts are crisp and short, ciao
FS: perrin adjustable short shifter kit Dfence410 Private 'For Sale' Classifieds 6 06-12-2006 06:53 PM
FS: Perrin adjustable short shifter kit Dfence410 NESIC Private Classifieds 2 05-28-2006 02:06 PM
Perrin adjustable Short Shifter jeeps1998 Transmission (AT/MT) & Driveline 9 05-28-2006 01:03 AM
Perrin adjustable short shifter - problem Ottawagon Transmission (AT/MT) & Driveline 16 08-16-2005 02:43 PM
Perrin Adjustable Short Shifter WRX 02-05 Celly Private 'For Sale' Classifieds 3 12-07-2004 03:01 PM
