Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 12-05-2003, 05:53 PM   #1
Coow
Member#: 48878
Default mod for 2.5RS engine???
hi guys
Anyone out there had mod. their 2.5RS engine?? I heard the engine itself is really weak. not strong enough for the turbo. hv anyone of u shoot a turbo to RS?? notice any problem?? thx a lot
Coow is offline   Reply With Quote
Old 12-05-2003, 05:55 PM   #2
subarucyclist
Member#: 29374
2000 2.5 RS
Silverthorn
It's my understanding that it's a good engine overall, especially the phase 2 SOHC motors. Smooth, decent torque and a good overall feel, and quite reliable.
It's just not specifically designed for the stress caused by a turbo.
subarucyclist is offline   Reply With Quote
Old 12-05-2003, 06:38 PM   #3
Hawk296
Member#: 14555
1995 Impreza L
Baja
its not designed for a turbo, thats why they dont hold up to teh pressures and temps of a turbo motor. the compression ratio is too high and the internals are too weak (pistons liek to melt) to safely turbocahrge it. You could lower compression, use beefy internals, strenghten the block (semi closed deck style).
for the price it would cost to do it right and have it not break you could do a WRX engine swap (made for boost) which would be arguably more reliable and driveable.
In stock form it is a durable, reliable engine, just as it was designed to be. You can do the stadard bolts ons and even go as far as cams and such and make it really fun to drive.
I reccomend just doing the bolt ons and suspension stuff and that sort, then learn how to drive, you will realize you have a pretty good car at that point. If your trying to make a drag car, buy a differnt car. THrowing tons of power at it (RS-T style) is probably one of the last things you do, after the viper ACRs and stuff are beating you in the straight aways.
Hawk296 is offline   Reply With Quote
Old 12-05-2003, 06:51 PM   #4
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Garnet Red Pearl 5MT
Plenty of guys on the N/A forum have modified the internals of their EJ25. If you did a search for posts by Dcoty or about his setup, you would see that he's had considerable success with his N/A build.
In terms of turboing the EJ25, you should go to the Aftermarket Forced Induction (AFI, like the band ) forum to get some more information about low compression pistons, stronger internals, etc. that could help you produce more boost safely.
It should be noted, however, that there are a whole bunch of NASIOC members who have successfully and (mostly) reliably put their stock-internal EJ25s under low amounts of boost (>6 psi) with impressive results. This usually comes with a lot of engine management, but check the AFI forum for more detailed information.
Also notable is that while you could do a WRX engine swap for the price of a well-designed turbo kit, a turbo'd 2.5 RS is much faster than a comparably modded WRX. Imagine loads of torque down low with almost no boost lag...heaven! Something in my gut tells me the install for the turbo kit would be cheaper, as well.
DrBoy01 is offline   Reply With Quote
Old 12-05-2003, 07:46 PM   #5
Snagtastic
Member#: 43809
Plz use the search button.
Snagtastic is offline   Reply With Quote
Old 12-06-2003, 02:11 AM   #6
Coow
Member#: 48878
[quote]Originally posted by Snagtastic
Plz use the search button. [/QUOT
E]
wow.............thx a TON for your great respone, your information is really help man. you know.........there so many ppl respone the same way like you which's pissed me off. if u not doing any good to the topic then why would u waste your time to respone. I just dont get.................
Old 12-06-2003, 02:12 AM   #7
Coow
Member#: 48878
by the way........thx a lot for the rest of u guys up there. I appreciated that
Old 12-06-2003, 02:35 AM   #8
PRIOR
Member#: 27524
95 Impreza L awd
2.5 swap & only 2400lbs
rice?
PRIOR is offline   Reply With Quote
Old 12-06-2003, 06:16 AM   #9
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Default Re: mod for 2.5RS engine???
No, nobody has. The entire forum is devoted to people thinking about what it would be like if they "had mod. their 2.5RS engine".
Uhhhh.... was that English? If you try typing your questions in the native language spoken here you'll probably get more productive replies. If you type gibberish, people will be inclined to say, "use the search function."
Pat Olsen
'97 Legacy 2.5GT sedan
Old 12-06-2003, 01:58 PM   #10
DrBoy01
Member#: 20444
2006 Outback 2.5 XT
Originally posted by PRIOR
rice?
Funny , and I know where that came from, but that doesn't help the topic at hand. The guy asked an honest question so he deserves an honest answer. He's trying to be productive. Let's try and keep the flaming to OT, guys.
Old 12-06-2003, 02:19 PM   #11
PRIOR
Member#: 27524
95 Impreza L awd
i thought it was subtle enough not to be too bad, but yeah... your right
Old 12-06-2003, 11:59 PM   #12
Coow
Member#: 48878
okok...alright, i'm sorry for my english, gibberish.....whatever!!!
English is my second language ok, Thank you!! try to learn another laugage see if u can speak or write fluent within 2 years
Old 12-07-2003, 12:02 AM   #13
Coow
Member#: 48878
but that's ok.....you excused. American stupid anyway, can't even do basic algebra. No....I mean you guys can't even do fraction add fraction. Gosh.............
Old 12-07-2003, 12:09 AM   #14
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Huh
??? Stupid Americans? Where this come from? This topic is getting out of hand mods.
Kevin Thomas is offline   Reply With Quote
Old 12-07-2003, 12:09 AM   #15
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
[quote]Originally posted by Coow
E]
Don't forget, you were the guy that came in and called our Subaru's rice for putting on rally stuff and said stuff like that belongs on a Civic.. last week in the Member's Gallery. YOU deserved that.
Mirage is offline   Reply With Quote
Old 12-07-2003, 12:15 AM   #16
Coow
Member#: 48878
Rice?? did I say rice?? I own a 2.5RS too. I just can't stand that 2 extra fog light, come on....2 are enough, does it look good if your woman got 4 breasts?? can't even do little design, no wonder u guys DESERVED a brain can't do fraction.
Old 12-07-2003, 12:24 AM   #17
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Um.. yeah.. do the word "Offiicial Rice Thread" ring a bell?
If looking at a car gives you wood, u have issues dude. Fogs serve a function when you rally.
Old 12-07-2003, 12:35 AM   #18
Coow
Member#: 48878
rally?? oh come on......2 fog lights give him enough to do the rally?? I can't even say it out loud for my Evo8 to do the rally thing. RS??? come on......... the definition of rice for me is if you guys not own a STI or WRC, then stop putting in STI part or pretend as a rally car. this is so rice.
anyway........I'm here not for arguing with you Mirage, if you have that much time, go practice your fraction cos finals is coming dude
here some......
4/7+ 9/12
12 + 5/13
Old 12-07-2003, 12:48 AM   #19
Mirage
Member#: 155
01 RS Coupe/Silver
00 SiR/06 ZX-6R
Good God.. U think like the new STi owners that have no clue and respect for what the RS or the WRX is.
Just so u know, Canadian Patrick Richard is now in the WRC, and he started it all from his 98 RS, doing amateur rallying, that was only 5 years ago.
Finals? Get outta here kid.. I'm done here.
Old 12-07-2003, 12:57 AM   #20
Coow
Member#: 48878
awww............you done?? but can't even do a fraction. aww.........I'm sorry, maybe my questions are too damn hard for you. try this then....3+5
Old 12-07-2003, 01:00 AM   #21
Coow
Member#: 48878
gosh......why am I wasting time here to arguing with moron like you. "Suby".........."Rally"..............."STI"....... get a life man
Old 12-07-2003, 01:02 AM   #22
imp2.5
Member#: 11354
Ok, so he asked a very obvious question. When I first got my RS back in '01 I thought the same thing. Coow, my suggestion is not go get mad at people and just spend some time looking at what's on the forum. There is so much information that is brand new and there is also so much that people have previously talked about. I honestly love the search button, it saves so much time and can get you what you want. For the "rice" thing. I wouldn't agree with you at all and I hope you don't take an offense to it. But for rallying those extra lights do help when you have night stages because some of them point to the side so you can see where you're going when you are sideways at 75 mph. I rally-x my RS all the time and these cars do have tons of potential. I frequently beat wrx's just because our cars are not turbocharged (low end torque rocks! ). So please just understand that we are not all american punks that don't know how to do math (believe me, I passed calc II, not fun ). So I hope everything will be alright and you guys can both have a good night and not worry about it.
imp2.5 is offline   Reply With Quote
Old 12-07-2003, 01:08 AM   #23
Coow
Member#: 48878
thx a lot, this is what I called human language
Old 12-07-2003, 02:01 AM   #24
Reckon
Member#: 19216
2002 WRX Red/Carbon
USE THE SEARCH FUNCTION
Man. I think these guys are just trying to say that you can learn a lot from doing a search on this forum, instead of posting another thread asking the same question 2 or 3 or more other threads have already answered and answered by knowledgable individuals who invest a few valuable minutes doing so and would like to avoid doing so again. Plus by using the search engine you get the information you're looking for right away, giving a few minutes to sift through some of the material - instead of having to wait.
Also, there are some guys out there who do beginner-amateur rallying and needing a couple extra lights; maybe everyone has a different understanding of rice, but from how I see it, if it's functional and not flagrant it's perfectly fine.
And to answer your question, from my research it seems that our blocks and pistons are prepared for our current compression ratio and so it would not be too good an idea to simply bolt on a turbo. Now, if you want to do some engine modding then obviously you'll have to decide what route you wanna go. I'm sure you know already that taking your subaru the N/A route is going to involve cams, flywheel, heads, pulley, headers, intake, and other what nots. If you want to go aftermarket turbo, then change up the block and pistons, cams, etc.
One more thing. This isn't OT and so try to be professional and refrain from insults and what not. When you do this people are less inclined to help you out and more inclined to continue with a flame war. You'll find that you have less crappy messages like this one here cluttering your thread.
Oh, and by the way, the answers to your fraction questions are
161/13, 111/84, and 8
Reckon is offline   Reply With Quote
Old 12-07-2003, 02:06 AM   #25
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
OK, here's the scoop. Yes, you can do a number of mods to a 2.5L engine, but if you want to make significantly more power than stock you're going to have to spend some $$$. (Or whatever the money symbol is in your language ).
Yes, people have turbo'd 2.5s, and there's a whole forum (aftermarket forced induction) devoted to those turbo kids. I've heard mixed reports about what the engines can handle. Apparently some variants of the motor have pretty weak pistons, and the early 2.5s had weak head gaskets (I blew mine twice on a naturally-aspirated car).
I personally chose to stay N/A and there are only a few guys on the board here who've gone beyond what I've done. My thought with staying N/A was that I would avoid the heartache involved with tuning a turbo motor - a few of my friends have turbo'd 2.5s and it seems like the tweeking never ends. In the end, I've ended up with a car that is significantly stronger than stock (dyno'd about 40hp over stock at the wheels), but significantly less powerful than a turbo'd 2.5, and I think my ECU is pretty confused because low RPM performance is often herky-jerky. I haven't done much to fiddle with it, but one of these days I'm gonna have to figure out a "fix".
Good luck.
Pat Olsen
Need forged internals for 2000 2.5RS engine 63Alpine Private 'Wanted' Classifieds 4 07-06-2004 07:18 PM
Looking for 2000 2.5RS engine the spacecowboy Private 'Wanted' Classifieds 10 03-01-2004 03:04 PM
2.5rs engine, tranny and ecu are going for sale impresacoupe2000 Private 'For Sale' Classifieds 15 09-09-2003 01:46 AM
2.2 to 2.5rs engine swap soupedscooby Normally Aspirated Powertrain 3 10-01-2002 08:41 PM
EJ20 Engine Swap for 2.5RS JDMSubaruWannaBe General Community 7 02-13-2002 02:44 AM
