Old 12-05-2003, 07:17 PM   #1
Jejunum
Member#: 15773
2011 Impreza WRX
Default crank shaft pulley removal ...wrx's too!
Look what I found.
http://www.dropshippedtools.com/prod...05&1=281&3=294
makes for easy removal of your pulley...wish i had one when i removed mine! only $4 too...
Jejunum is offline   Reply With Quote
Old 12-05-2003, 09:07 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
I doubt it would work at all. Those things require that the pulley has threaded holes in them. The subaru pulleys don't have threaded holes in them so that tool is useless.
It is so easy to remove that bolt. I have done this a couple times and it works fine. Disconnect the ignition coil. Put a breaker bar on the bolt and hold it real strong and have a friend turn over the engine for half a second. Done.
To put it back on just pull the tranny inspection cover and wedge a pry bar in there while you torque the crank bolt.
Tim Sanderson is offline   Reply With Quote
Old 12-05-2003, 11:14 PM   #3
Jejunum
Member#: 15773
2011 Impreza WRX
eh? they have the holes in them. not threaded though; i thought (and the service manual has a tool and part #) of a socket type device with pointy things so the pulley doesnt turn
anyways for 3 bucks this method is sooo much better than the (imho) unsafer (not dangerous just ... sketchy) method u describe.
yah thats what i did thanks to you but eh i liek the tool method beter!
Crank Shaft Pulley Bolt Torque mrjoshm Service & Maintenance 9 01-26-2009 08:44 PM
Cam/Crank Shaft Seal Removal Trunk_Monkey Service & Maintenance 3 09-29-2008 02:34 AM
Tighten crank shaft pulley bolt Madzdad Newbies & FAQs 10 09-17-2008 12:10 PM
crank shaft pulley probs 96imprezared Newbies & FAQs 2 10-15-2006 07:38 PM
crank shaft + acces. pulley 94LegacyGTWagon Legacy Forum 3 07-10-2001 02:12 AM
