Welcome to the North American Subaru Impreza Owners Club Friday February 27, 2015
Old 12-04-2003, 02:02 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default aftermarket turbo inlet hose, solid intake elbow, intake... will something break?
will be running an ARC air induction box, zerosports intake elbow, perrin turbo inlet hose... basically replacing everything that had an accordion on it. with everything being rigid with no flex... will something go bad/break?
Benjamin Tang is offline   Reply With Quote
Old 12-04-2003, 02:18 PM   #2
Uncle Scotty
OK Houston
we have an Uncle
The Perrin inlet hose that I have is silicone....and IIRC the Zerosports piece has a silicone piece included in it somewhere...
SO....I don't think you'll have a problem....unless it's your wallet being real thin after buying all this stuff...
Uncle Scotty is online now   Reply With Quote
Old 12-04-2003, 03:17 PM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
well... my zerosports elbow has only the w silicone hose connectors but there is still hard contact between the pipe openings... my arc is in transit to azscoobie for dyno testing... i'm shopping around for an inlet hose and was looking at a used perrin.
who makes the best inlet hose? sti? perrin? samco? prodrive? turboxs? does it matter?
Old 12-04-2003, 03:35 PM   #4
Uncle Scotty
OK Houston
we have an Uncle
You could get an MRT or AVO(they are identical) and not use the Zerosports at all...
The above are one piece units which replace the elbow as well as the rest of the inlet.
I, personally, would prefer this option.
There should be no 'hard contact' between any of the elbow pieces when everything is installed correctly.
Old 12-04-2003, 04:12 PM   #5
mkultra69
Member#: 34402
2002 WRX AP stg 2+
WRB 4EAT and proud of it!
Originally posted by Benjamin Tang
well... my arc is in transit to azscoobie for dyno testing...
Kinda interested in this box, could ya post your results when you get them?
mkultra69 is offline   Reply With Quote
Old 12-04-2003, 04:19 PM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
i think azscoobie will be doing a writeup on it... unless it gets lost in the xmas rush
Old 12-05-2003, 01:20 PM   #7
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
AVO was a bitch to install. I think mine may have been molded wrong 'cause I had to cut the nipple for the PCV off the AVO hose and move it where it wouldn't rub against the intake runners (drilled a new hole and used some epoxy to hold the plastic nipple). If you use a regular hose clamp on the turbo side of the hose, make sure you fold the end over with your screw driver after you tighten the clamp. Mine kept loosening up and the hose almost slipped off the housing on several occasions. BUT.. it's a much smoother path for the air to travel and if you already have a free flowing intake system (Rampod Unifilter or something to that order) you'll notice a "smoother" sound during spool up. I love it and I'd recommend the AVO/MRT style.. hopefully no one will have the problems I did.
PeteDucati is offline   Reply With Quote
Old 12-05-2003, 01:25 PM   #8
Benjamin Tang
Member#: 4496
2009 Forester
red
what about the intercooler hoses? are they as important as the inlet hose in terms of airflow/vaccum/etc? can't afford to buy everything at once... going at it a little bit at a time.
Old 12-05-2003, 01:34 PM   #9
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I don't know about the other aftermarket TMICs.. but the Hyperflow came with new silicone hoses. So if you plan on dropping the grand for a different intercooler.. it MIGHT come with them. The intercooler hoses might be considered MORE important since they'll suffer from positive and negative pressures. Personally I don't think any of these hoses are too important unless you're running higher than stock boost or you're digging for every last bit of bolt on power. Some write these upgrades off as preventative maintainence..
Old 12-05-2003, 01:44 PM   #10
Benjamin Tang
Member#: 4496
2009 Forester
red
i am running:
arc induction box
jdm sti tmic
sti injectors/fuel pump
fujistubo sti exhaust manifold
deadbolt monster vf39
turboxs stealthback w/cat
prodrive wr axleback
azscoobie ecutek reflash
all my hoses are wrx with the exception of the y-connector that came with the tmic (sti).
Old 12-05-2003, 01:58 PM   #11
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Maybe you should wait until you have enough loot to buy ALL of the hoses.. I'm 99% sure you've gotta remove the IC to install the intake hoses.. and of course you need to remove it to install the IC hoses. I remember the chicken little's screaming how important it is to change the intercooler hoses 'cause they'll leak or crack, but I don't recall hearing any actual failures.
Try finding them used, too. There's gotta be guys who went from TMIC to FMIC who are selling some silicon IC hoses.
Old 12-05-2003, 02:31 PM   #12
Benjamin Tang
Member#: 4496
2009 Forester
red
still trying ... i am getting the perrin inlet one used. can't find anything else... u mentioned cracking, etc... what about collapsing or blowing off under full vaccum?
Old 12-05-2003, 07:40 PM   #13
Beam
Member#: 29742
2011 Ah Subaru.
I missed you.
The only thing I noticed about running silicon hoses is it's much harder to get parts on and off, there's no accordion to flex in the I/C hoses, or the intake hose (goes from the airbox to the inlet pipe.), this last one making it a royay battle anytime I have to do anything that requires moving the airbox...
Beam is offline   Reply With Quote
Old 12-05-2003, 07:53 PM   #14
Benjamin Tang
Member#: 4496
2009 Forester
red
i went with the perrin because it hypes how everything on it is relocated for easier install.
Old 12-06-2003, 09:32 AM   #15
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I haven't heard of either.. but everyone still says it CAN happen! Do YOU want to be the one stock on the side of the road with no tools and a broken car!?! I'll bet your answer is "no", so you should invest in some expensive silicone hoses!
I doubt the plastic hoses would collapse or blow off due to vacuum or boost.. the silicone would be just as likely to blow off, too.
Old 12-06-2003, 10:31 AM   #16
cronic
Member#: 9749
Ths stock inlet is known to rip.. It hapened to me causing a bunch of problems.. I swapped it out for the perrin and all is good..
cronic is offline   Reply With Quote
Old 12-06-2003, 11:57 AM   #17
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
I have ripped my turbo inlet and a few others numerous times. Its a piece of crap and not flexable at all.
I have also blown it own numerous times with high boost pressure.
This has happened to MANY MANY people.
The stock inlet hose is not made to handle high HP apps and high boost.
BT: You will be fine. Nothing will break at all.
Need4Boost is offline   Reply With Quote
Old 12-06-2003, 12:03 PM   #18
Benjamin Tang
Member#: 4496
2009 Forester
red
thanks guys... bought my used perrin from mauromotorsports today... now it's a waiting game.
Old 12-06-2003, 12:34 PM   #19
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Finally some testimonials reassuring my suspicions that I did NOT waste money on expensive intake and IC hoses.
WTB: Aftermarket Turbo inlet hose. Djcal Private 'Wanted' Classifieds 1 04-23-2007 02:56 PM
WTB: STi or aftermarket Turbo Inlet Hose Robstunner Private 'Wanted' Classifieds 2 12-20-2006 10:36 AM
WANTED: Aftermarket Turbo Inlet Hose - Perrin, Samco, etc. etc. AFTERMARKET ONLY Rally_WRX1 Private 'Wanted' Classifieds 4 09-05-2006 10:59 PM
aftermarket turbo inlet hose clamp BlackoutWRX General Community 4 02-17-2006 09:20 AM
WTB: aftermarket turbo inlet hose metbluWRX Private 'Wanted' Classifieds 3 10-29-2004 07:44 PM
