Go Back   NASIOC > NASIOC Subaru Models > 'Old School' Subaru Forum
Old 12-06-2003, 10:45 AM   #1
simpreza2
Member#: 20381
04 Forester X
93 240sx
Default loyale lug patern
I tried searching for the lug patern and offset but I couldn't find anything. Does any one know the size to the Loyale wheels? I know there 185/70-13 but Im looking to get new wheels.
Thanks
Jon
simpreza2 is offline   Reply With Quote
Old 12-06-2003, 11:23 AM   #2
GravelRX
Member#: 42392
Default 4x140
The most common wheel swap for this model and most other subarus of the ilk would be another wheel from the same style car. Now if you are looking to get 14 or 15 inchers, nead out to the JY and try to find an older 505 Puegeot. 85-87 IIRC.
If I'm not correct someone will surely pipe up.
I have a few pictures of mine if you want to see. Email me at gravelrx1(at)cox.net
Jay
GravelRX is offline   Reply With Quote
Old 12-06-2003, 12:13 PM   #3
old school
Member#: 22647
2016 Crosstrek
CWP
The lug pattern is 4X140mm. There are some aftermarket 13 inch wheels available, 14's are gonna have to be the pug wheels as mentioned above.
old school is offline   Reply With Quote
Old 12-06-2003, 03:07 PM   #4
simpreza2
Member#: 20381
04 Forester X
93 240sx
Thanks guys...Im guna go looking for some pug wheels on Monday.
Jon
Old 12-09-2003, 07:22 PM   #5
yasafusa
Member#: 50231
1989 GL Turbo Awd
Crispy
Actually if you would like to do one better....
Make your subaru six lug ready...\
problem... there are very few wheels for the 4 lug 140mm bolt pattern...
FIX!!! Toyota and Nissan happen to have a 140mm 6 lug pattern.... 80' Nissans use the same stud type, so Nissan is easier to work with!
take out two of the lugs from the drum, so you have two that are evenly spaced apart.... mount a nissan truck brake drum on the subaru drum, drill out the four holes (BEST IF DONE BY A MACHINE SHOP) to make it now a 6 lugger!!!
Dont worry, it works!, just might have some difficutly fitting some truck rims under the fender hehe... It's pretty bad-ass once you get it done though! And everyone makes 6 lug 140mm after-market rims!!!
yasafusa is offline   Reply With Quote
Old 12-09-2003, 07:29 PM   #6
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Get some STI wheels!
http://www.cardomain.com/memberpage/319350/2
You can also do a 4x140 to 4x1XX conversion with custom wheel adapters for Russel's Machining in Gardena Ca.
mattjk is offline   Reply With Quote
Old 12-09-2003, 07:56 PM   #7
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
Question
Anyone know the offset? I've read a few peugeot articles mentioning that 505 wheels will rub very badly. ?
Old 01-10-2004, 03:33 PM   #8
mattjk
Member#: 16615
I ♥ my TE51
2009 Nissan 370z
bump
Old 01-20-2004, 10:01 AM   #9
subyfanatic
Member#: 18276
07 1990 Breadbox
FEEL THE LOVE
Call up some wheel shops and see if they can direct you towards a custom made wheel adapter. I know of one guy with a BRAT that had adapters made and now any Suby 5 x 100 wheel can be fit. The offset on the Loyale series cars should be in the 40-50mm range, not that much different than other Subies.
subyfanatic is offline   Reply With Quote
Old 01-21-2004, 03:30 PM   #10
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Go here. Scroll down a little bit, and there in front of you are about the ONLY aftermarket wheels you can get for 4-lug Subarus!
DerFahrer is offline   Reply With Quote
Need Lug Nuts for 90 Sub Loyale grizz3000 Tire & Wheel 0 11-13-2006 12:52 AM
5x114.3 lug patern? Bootleg Tire & Wheel 8 01-30-2005 01:58 PM
wrx bolts patern? Lightning Jack Tire & Wheel 2 02-12-2004 07:04 PM
Be careful, gentlemen: Paternity probs YoungWilliams Political Playground 4 02-03-2004 08:18 PM
Paternity test in progress. Hehe! Samirr76 Member's Car Gallery 6 09-19-2001 12:44 AM
