Old 12-06-2003, 04:28 PM   #1
raydadick
Guest
Member#:
Default help! ej22t short block swap into a 98 rs
i am buying a complete 91 legacy turbo motor, everything comes with it. im just swapping the block in with my heads (apparently this is a really potent combo). i know ill need an exhaust and some form of engine control but what else would i need and anyone know about making it pass an emissions check? im in ohio and their e-check is changing for obd2, they are hooking up to the computer and reading the cars sensors instead of the sniffer test.
Old 12-07-2003, 01:38 AM   #2
EJ22TGC8
Member#: 49678
1996 Impreza Brighto
'91 legacy turbo
you are in the same boat as I am. I've got an '91 Ej22t going in to an '96 impreza and face that obdII bull****. I've talked to a bunch of people about it and some people say I'm screwed and others say that if you claim that your odbII is broken they will do the old sniffer test. I'm not sure which is true but for my sake and yours I'd hope that we can jsut get by with saying the odbII is broken.
-John
EJ22TGC8 is offline   Reply With Quote
Old 12-28-2003, 04:59 PM   #3
raydadick
Guest
Member#:
what i think would make sense would be a stand alone would provide all the readings they are trying to pull out of the ecu right there on the laptop. why wouldnt that be enough?
Old 12-29-2003, 12:39 AM   #4
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
search in the conversions form..
subiekid is offline   Reply With Quote
Old 01-14-2004, 12:18 AM   #5
NeaD
Member#: 43371
1998 Impreza 2.5RS-T
Hydra User, Blue
NeaD is offline   Reply With Quote
How likely is a 5eat swap into a 98 RS? GC8ScoobieBoy Transmission (AT/MT) & Driveline 1 04-14-2008 05:03 PM
Short block swap help austenf740 Normally Aspirated Powertrain 5 03-02-2007 11:21 PM
97 legacy block swap into a 98 RS perfectly? austenf740 Subaru Conversions 1 03-27-2006 08:39 PM
STi short block swap into WRX pegdrgr Subaru Conversions 97 07-20-2004 07:43 AM
UTEC map help needed for 2.5l short block swap LiquidForce Engine Management & Tuning 3 04-20-2004 10:51 PM
