Old 12-07-2003, 03:11 PM   #1
Nicklbrso
Member#: 44887
00 GC6
Default Cai
I went to install my intake today and I am pretty sure I have what is considered a "cold air intake" because the cone filter is right on the fender tubing, drawing in cool air from the fender, instead of the warm engine air. Is this considered a CAI or am I missing something. Any pics of CAI's would be appreciated. Thanx
Nicklbrso is offline   Reply With Quote
Old 12-07-2003, 03:25 PM   #2
Defiantguy
Member#: 41268
2015 WRX
ya sound about right. If its drawying air from outside the engine bay or if it has like a heat sheild.
Defiantguy is offline   Reply With Quote
Old 12-07-2003, 11:33 PM   #3
SjYankee006
Member#: 33943
sounds like a CAI to me... here's a pic of my COBB if you need confirmation.
SjYankee006 is offline   Reply With Quote
Old 12-08-2003, 05:36 PM   #4
Nicklbrso
Member#: 44887
00 GC6
Well my cone filter is still in the engine bay although the opening on the top of it is right in the fender hole/tubing, not all the way inside the fender like yours is. So would mine be considered a CAI? Thanx
Old 12-08-2003, 05:46 PM   #5
ratt_finkel
Member#: 46218
06 EVO 9
Nope, but it wouldn't be hard to fabricate a box that isolates the filter from the engine bay, and allows the air to be drawn from the fender.
ratt_finkel is offline   Reply With Quote
Old 12-08-2003, 08:51 PM   #6
Nicklbrso
Member#: 44887
00 GC6
What if I put some aluminum/metal sheet material between the filter and the rest of the engine. Would this help draw in more cold air, and therefore be considered a CAI? Thanx
Old 12-08-2003, 11:21 PM   #7
That Guy
Member#: 23212
2002 Impreza RS
Try some ABS plastic (not PVC). You could probably fabricate something cheaply to make yours look like SjYankee's (sorta, it might be ugly). Stop on down to Home Depot or Lowe's and see what you can come up with.
I wouldn't get too caught up with lables, but if you want a "true" CAI, you'll need to pull air from outside the engine bay because it's hot in there. Truth be told, your intake is probably fine as is. Have you noticed a difference with it?
If you're looking for a cheap alternative to spending a bunch on a new CAI you could either make one yourself from the afore mentioned ABS (do a search for DIY intake in this forum). Or the folks at PDM said they would have parts in for their CAI sometime in January. It's only $50 and uses the factory air box.
That Guy is offline   Reply With Quote
Old 12-08-2003, 11:33 PM   #8
nySulli
Member#: 32617
2008 STi
just get a garbage can and cut it to fit, i know at least 1 person here has done that, theres pics floating around somewhere
nySulli is offline   Reply With Quote
Old 12-08-2003, 11:53 PM   #9
Pakin
Member#: 17315
MY95 Impreza 207C
MY05 Forester 257X
I did a "wannabe" CAI with the factory box. Needless to say, no noticable performance gains but it made a cool sound at 2.5K rpm.
-paK +2
Pakin is offline   Reply With Quote
Old 12-09-2003, 03:22 PM   #10
Nicklbrso
Member#: 44887
00 GC6
I havent been able to really try it because after I installed the intake it was snowing and could not test it out real well, and now my subie has been put away for the winter It is sorta a CAI because there is an opening on the top of the filter and that is sticking right against the fender opening although the filter is still in the engine bay. I would probably not consider it a CAI but it sucks warm engine air and some cold air from the fender.
Old 12-09-2003, 04:05 PM   #11
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
So you have a cone filter in the engine bay, yes? If you look on scoobymods, I think it was peaty, he has a pic of a cone filter + heat shield. It should give you something to work on over the winter
kami333 is offline   Reply With Quote
Old 12-09-2003, 09:04 PM   #12
Nicklbrso
Member#: 44887
00 GC6
Peaty, Do you happen to have that pic of the heatshield? Could not find it on scoobymods. Thanx
Old 12-09-2003, 09:19 PM   #13
kami333
Member#: 22068
00 GF4, 00 GM6
93 GF2
It was by kastle
I've seen others using various materials, including cardboard with aluminum foil.
FS: (HR) Subaru STi and WRX parts - exhaust, dp, uppipe, FMIC, UTEC, CAI, etc. azrakain MAIC Private Classifieds 71 06-02-2011 08:21 PM
CAI = Run Lean? Injen CAI? Spt CAI? .A.W.D. Newbies & FAQs 3 01-25-2008 10:02 AM
Injen CAI/COBB Tuning CAI Timdog82001 Proven Power Bragging 2 08-19-2002 04:03 AM
Injen CAI or AEM CAI? KillerRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 02-24-2002 12:18 AM
Isn't APS/Cobb Tuning CAI similar to AEM CAI? blackwrx127 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-30-2002 09:33 PM
