Old 12-07-2003, 06:30 PM   #1
WRXOwner7
Member#: 20641
Default Fog Light Problem
Having a problem with the drivers side fog light on my 02 wrx. Last week I replaced the 55watt bulbs with 100watt bulbs, tested, both lights worked, no problems. Went out for a couple of hours with fog lights and headlights on, came home and drivers side fog was out. Pulled it apart, bulb looked fine, replaced it anyways with another 100 watt bulb, still nothing. Tried the bulb I just took out in the passenger side and it worked. Checked all connections on drivers side, everything looks good. Check fuses, perfect. What the heck is the problem?? I've checked everything I can think of and got no where, anyone have a similar problem or have any suggestions??
WRXOwner7 is offline   Reply With Quote
Old 12-07-2003, 10:25 PM   #2
Captain Ned
Member#: 36144
2010 Legacy2.5GT Ltd
Graphite Gray Metallic
My guess is that the excess current draw over stock has blown the fog light relay for the driver's side.
Captain Ned is offline   Reply With Quote
Old 12-07-2003, 10:50 PM   #3
WRXOwner7
Member#: 20641
Where is the relay located so that I can test it???
Old 12-08-2003, 09:10 AM   #4
Captain Ned
Member#: 36144
It's under the driver's side dash, in the general vicinity of the fuse block. It will be the middle relay of the 7 in the relay block.
Old 12-16-2003, 12:53 PM   #5
WRXOwner7
Member#: 20641
Ok, subaru dealership says it's probably not the problem and that they can't locate the relay I'm talking about. Anyone know the part number off hand so that I can order one.....also anyone with a similar problem?? What was your solution??
Old 12-16-2003, 01:12 PM   #6
bleuquila
Member#: 31922
03 wrx wagon
78 brat
a subaru dealership can't find the foglight relay? I don't know the part number, exactly, but it's B48 on Subaru schematics.
But, that's beside the point, if it /was/ the relay both lights wouldn't be functioning, as there is only one for the pair of fogs.
I presume you've checked all the connections at the back of the lights? The stock wiring harness may have melted from the excess current (note: 100% pure speculation) and if either the 12+ or ground wire connection was damaged at the lamp itself, that one would cease working. A $15 multimeter can verify this for you.
bleuquila is offline   Reply With Quote
Old 12-16-2003, 01:20 PM   #7
WRXOwner7
Member#: 20641
I'm going to che k the ground tonight.....also going to by an automotive voltage meter....thanks....lets hope it's the ground
Old 03-02-2004, 01:41 PM   #8
driftma
Member#: 22205
2002 Impreza 2.5RS
I have an '02 2.5RS and bought higher powered foglights as well, and the driver side bulb went out after a few months, so I replaced it with a new one, which proceeded to go out after two days. I haven't removed it yet, but I'm wondering if you figured out what the solution is. I'm not even sure that the second one was blown since I just assumed it was the bulb.
driftma is offline   Reply With Quote
hid fog light problem N1mxer Electrical & Lighting 3 03-19-2006 06:18 AM
fog lights problem panache Electrical & Lighting 11 07-01-2004 09:43 PM
('93-'01) HELP! '93 Fog Lights Problem MR. WRX Impreza Forum 0 11-09-2003 09:22 PM
Fog light problem...help Scoobyslack1 Interior & Exterior Modification 4 07-27-2001 08:07 AM
Head light & fog light problem White Knight Legacy Forum 4 03-29-2001 06:27 PM
