Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 12-07-2003, 10:24 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default climate confusion is now "what the hell"
when going up a hill in my GL it switches from defrost to just the front vents then when i level out it goes back
is there just a weak flap in there or something thats controlling the air? does it mean anything bad? does anyone know
let ME know
thanks
alex
Old 12-07-2003, 10:52 PM   #2
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
the flaps work on vacuum, so u either have a vacuum leak somwhere or if your car has a 'vacuum ball' or 'can' it may not be connected still. if there is a loss of vacuum the flaps will all open. like driving WOT while pumping brake, after the 3rd pump pedal is hard as a rock.
YaZahX is offline   Reply With Quote
Old 12-08-2003, 12:45 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
****, so hows the easiest way to detect where the leak is commin from??
Old 12-09-2003, 03:45 AM   #4
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
well...the car was surgin today, goin down the road and had an eradic idle rpm i pulled off the road turned it off, and tried to start it again it was doing the BUMP BUMPGURGLE sounds a car does when its misfiring like a biatch
and it wont start now, my temp gauge was fine so was oil
headgasket?
fuel pump and a vacuum leak?
Old 12-09-2003, 02:07 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
OK!?
i went to tow it today and put it in neutral, just cranked it over for the heck of it, started right up, drove totally fine until about 3 min after it hit operating temp then started surging again, im not seein any clouds of smoke or steam from the exhaust what the heck is goin on?!
Old 12-09-2003, 07:33 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
annnd it was the distributor, the top contact was missing/broken in 2, the spark was jumpin that far to make contact
Old 12-10-2003, 05:38 PM   #7
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
may want to check out the USMB if you haven't already....much larger old gen subie user base
http://usmb.ultimatesubaru.net/forum/
Legacy777 is offline   Reply With Quote
Old 12-11-2003, 04:28 AM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
no workie
Old 12-11-2003, 10:06 AM   #9
Legacy777
Member#: 4800
they're having server issues for some reason.....try again later today.
Climate control knobs confusion...! Pictures potentially hard for 56k. DakotizzleFoShizzle. Newbies & FAQs 15 09-01-2008 04:57 PM
Lifted '89 GL Wagon MysteriousXTC Private Vehicle 'For Sale' Classifieds 18 06-06-2006 12:08 AM
ej22 in an '89 GL, will it bolt? pilfflip Legacy Forum 5 10-31-2003 01:44 PM
off topic vehicle: need help w/ fuel filter removal in '89 civic 1.5L yuletak Bay Area Impreza Club Forum -- BAIC 6 08-19-2001 02:25 PM
Videos of an airborne '84 GL. Or: How I learned to stop worrying and love the GL Tony General Forum Archive 41 02-02-2001 12:19 PM
