Old 12-08-2003, 01:37 AM   #1
raydadick
Guest
Member#:
Default stand alone ecu obd2 emissions test passing?!?!?!
with a stand alone engine control can you still use obd2 to pass the emissions test?
i am swapping an ej22t block into a 98rs and will use the top half of my engine. this creates less wiring than a wrx swap and (i've heard it's more potent) i will use a stand alone or a piggyback. just need some input so i can get this done right.
Old 12-08-2003, 07:28 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you use a standalone that disables OBDII functionality and the test in your state incorporates an OBD scan, you probably won't be able to pass. They have to be able to plug into the port and verify that there are no codes stored and readiness tests are complete.
Old 12-08-2003, 11:04 AM   #3
raydadick
Guest
Member#:
so would a piggyback be the best way to go? doesnt that keep the stock ecu in there and control the engine functions?
Old 12-09-2003, 11:17 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah piggy back
might look into the e-manage and some larger injectors there is some one here using a simmilar setup on a 99RST
Old 12-09-2003, 06:47 PM   #5
raydadick
Guest
Member#:
where can i find out about that? ive never heard of the e-manage. and i wish i could find someone who has done this before cause i feel like im in a little over my head. the 2.2t block is awesome but this seems to be a hassle. maybe i should look into a usdm wrx clip and try the 2.2 block swap
Old 12-09-2003, 09:27 PM   #6
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
There are a lot of us RS-T's using e-manage now. Search in AFI, there's tons of good info already posted.
BTW, you don't need to post this same question in 5 different threads.
http://forums.nasioc.com/forums/show...30#post5183130
http://forums.nasioc.com/forums/show...73#post5182673
http://forums.nasioc.com/forums/show...10#post5182410
http://forums.nasioc.com/forums/show...58#post5182358
http://forums.nasioc.com/forums/show...hreadid=464949
lotusTT is offline   Reply With Quote
Old 12-09-2003, 11:07 PM   #7
raydadick
Guest
Member#:
i posted it all over cause i wasnt getting an answer and i hoped more people would see it if i spread it around
Old 12-10-2003, 08:30 AM   #8
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Rule #9: No CROSS-POSTING of topics is allowed in the forums. Definition of Cross-Posting: posting the same thread, or a link to the original thread, in more than one forum. This will get you put into TimeOut.
oem ecu with stand alone ecu acssa Engine Management & Tuning 1 11-24-2008 12:27 AM
stand alone ecu obd2 emissions test passing?!?!?! raydadick Pre-2002 Factory Turbo Powertrain 1 12-09-2003 08:25 PM
new to stand alone ecu tuning spacemonkey Engine Management & Tuning 0 08-11-2003 06:58 PM
Anyone heard of Autronic?? Stand alone ECU. GregUnd Texas Impreza Club Forum -- TXIC 0 09-12-2002 11:21 AM
Stand alone ECU Subi-fied Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-05-2002 04:27 PM
