Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-27-2000, 07:04 PM   #1
MrSube2pt5
Member#: 985
Post MY00 airbox problem!
Since I haven't yet heard of a successful intake for my '00 RS I attempted to create my own. I obtained a DC sports civic intake and hacked off an inch or so and flipped it around to fit in my subie. I obvioulsy removed all silencers and whatnot. The problem i faced (besides the "running rich" problem) was keeping my stock airbox sealed. If you remove the drop in stock filter the airbox is left unsealed and vulnerable. What i did was cit the rubber sealer off of the filer and glued it to the inside of my airbox (several times). This worked for a little while. I cant's seem to keep the ba$tard sealed properly. I know that SCC recommended you keep the stock airbox in place because the sensor is so tempermental so where the hell does that leave me. The intake is currently resting in my cozy trunk. Anyone have any idea?
jay
MrSube2pt5 is offline
Old 06-27-2000, 07:11 PM   #2
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
Subaru actually sells a gasket that replaces that filter and keeps a seal. It was for previous model years that had 2 filters. Can't help you out with the part number but I know someone here knows
Strepto is offline
Old 06-28-2000, 01:56 AM   #3
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Post
I think you can get the gasket at www.autocaresubaru.com for $49.00
BTW, what's wrong with the cold-air intake I did, using hi flow air filter in the stock airbox? See it at www.ImprezaRS.com, under "mymods" - it works grrrreat!
Many people here have tried it and comment on how well it works, but you say you haven't heard of a successful intake for the MY00. Also, the intake from www.jcsports.net is supposed to work well with a MY00.
Larry
PS: The SCC article coments are only valid for the older cars with an Mass Air Sensor (MAF) on the intake, and the MY00 doesn't use/need one. It has a MAP sensor in the throttle body. That's why your car still runs with the stock intake removed and your custom intake in place.
[This message has been edited by ImprezaRS dot com (edited June 28, 2000).]
ImprezaRS dot com is offline
Old 06-28-2000, 05:58 AM   #4
OG
Member#: 41
2005 Black LGT wagon
2000 Silverado
Exclamation
IIRC the 2000 airbox is different than the 99's so the gasket won't fit. IMHO forget the DC sports intake. Just get a K&N or Amsoil panel filter and run a tube into the fender(like ImprezaRS.com). You should get the same gains as the intake without running rich or losing bottom end power.
[This message has been edited by OG (edited June 28, 2000).]
OG is offline
HTML code is On
Problems installing filter in stock airbox QwikRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 02-27-2005 04:19 PM
my00 rs oem intake airbox with k&n filter GregBolby Private 'For Sale' Classifieds 0 11-10-2004 10:03 PM
stock airbox problems post experiance nwsurfwakeskate Legacy Forum 8 07-15-2004 01:40 PM
Hacked airbox, same problems as other intakes? atf78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 03-28-2003 09:35 PM
Taking out the airbox in a MY00/01 fellfrosch7 Normally Aspirated Powertrain 1 04-29-2001 11:02 PM
