Old 12-08-2003, 09:10 AM   #1
JayGold
Member#: 7074
Default Heat "ON" = high pitched squeaks
Just recently I started to use the heat on these cold IL mornings, I leave for work at 4:30am and let the car warm for a minute or 2 at idle. After about 2 minutes of driving I can set the heat to #2 and at about 4 minutes I can crank it to #4, the current issue I have is a major squeaking noise emitting from somewhere around the throttle body or stock airbox, but only when the heat is on.
I tested this at #1-#4 heat selection and it always makes noise from a standing start or when I rev match double clutch. When moving from a start in first gear the noise will emit from the beginning of clutch release to about 3 grand, then stop. It will not make noise in any other gear or on any gear change, unless I blip the throttle to rev match double clutch. It will make the noise at the blip.
I checked all my belts, its not them, I recently installed a new OEM starter, the noise is getting unberable, any ideas?
Jay
JayGold is offline   Reply With Quote
Old 12-08-2003, 02:15 PM   #2
trojan9x
Member#: 3169
2001 2.5 RS: Holbert
Memorial Winner 2003
check for any pinhole air leaks? other than the belts, that's about all i could think of. did you try it with the A/C on?
trojan9x is offline   Reply With Quote
Old 12-08-2003, 02:27 PM   #3
JayGold
Member#: 7074
Didn't think of A/C...hehehe
I'll give it a try when I get off of work. I'm going to reinspect the air box to throttle body seal, it could be that.
High Pitched Squeaking noise JLude7 Factory 2.0L Turbo Powertrain 1 06-28-2009 11:36 PM
High pitched squeak from aftermarket intake? BrysImpreza Normally Aspirated Powertrain 11 06-30-2004 02:58 PM
High-pitched squeak during upshifting everbruin Warranty Issues & SOA Problems 4 02-13-2002 09:13 PM
High-pitched squeak during upshifting everbruin Transmission (AT/MT) & Driveline 1 02-13-2002 11:55 AM
annoying, high pitch squeaking driving me nutz! olie General Forum Archive 2 01-11-2001 07:04 AM
Message Board Statistics All times are GMT -4. The time now is 03:16 AM.
